[OpenFOAM.com] Problem installing OpenFoam 1.5 on Ubuntu 12.04????
Old   June 30, 2015, 09:09
Default Problem installing OpenFoam 1.5 on Ubuntu 12.04????
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Foamres,
I have been trying to install OpenFoam 1.5 on Ubuntu 12.04. I have found and followed instructions in this website:
https://openfoamwiki.net/index.php/I...OAM-1.5/Ubuntu
I have done all the steps, however, I have got an issue not getting it to work. I am attaching the error that I have got and asking if anyone of you could guide to resolve the issue.
Regards,
make.log.tar.gz
tareqkh is offline   Reply With Quote
Old   July 5, 2015, 16:59
Retired Super Moderator
Bruno Santos
Quick question: What does the following command give you?
uname -m
I ask this because I suspect that you might have missed the detail about which architecture to follow the instructions for. In other words, I need to know if you have a 32-bit or 64-bit Ubuntu 12.04 installed, for which the answer is given by the command above.
Old   July 5, 2015, 21:57
Default Hey Bruno
tareqkh's Avatar
CFD
Hello Bruno,
Thank you for your reply. Using the command (uname -m) has given x86_64. I hope this help you to understand the error.
Thank you again,
Old   July 19, 2015, 14:52
Bruno Santos
Greetings tareqkh,
Sorry for the late reply, but only today did I finally manage to give a quick look into this.
Please zip and attach the file "~/OpenFOAM/OpenFOAM-1.5/etc/bashrc" to your next post, so that I can inspect the contents of the file. I should have asked for this on my previous post, but I was in a hurry
You can zip the file if you run these commands:
cd
gzip < ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc > bashrc.gz
pwd
Then attach the file "bashrc.gz" to your next post. The file should be located in your own home folder, as indicated by the last command.
Best regards,
Bruno
Old   July 19, 2015, 15:46
Default Hello
tareqkh's Avatar
CFD
Hello Mr. Santos,
Thank you again for your kind help and support. The problem has been resolved. I have just posted a question in the following link: http://www.cfd-online.com/Forums/ope...r-problem.html - about the flow around a flanged diffuser. I was wondering if you could help me resolve the problem.
Kind regards,
Tariq
Old   July 19, 2015, 16:10
Bruno Santos
Sorry, but I don't have enough time in the next couples of weeks to look into this... and at a first glance, it doesn't seem to be something that I would be able to diagnose with my current level of experience.
In addition, you are not providing enough details there for helping you, which means that it will be very unlikely that anyone will be willing to spare 10 or more hours trying to figure out what you want/need
[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04 tareqkh OpenFOAM Installation 1 September 2, 2017 11:10
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 arieljeds OpenFOAM Installation 6 August 19, 2015 08:39
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware zandi OpenFOAM Installation 5 March 31, 2014 04:57
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 11:20
Problem Installing OF 1.6 Ubuntu 9.10 (64 bit) - How to use GCC 4.4.1 Future Science OpenFOAM Installation 43 November 10, 2011 08:17
