[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 |
April 15, 2015, 05:34 |
Stephanie
Rep Power: 11 |
Hello everyone,
yesterday I tried to install foam-extend-3.1 this page: http://sourceforge.net/p/openfoam-ex...u/Ubuntu_14.04 Befor I did the installation I installed Ubuntu 14.04 again. I folowed all steps and the installation worked. Unfortunately when I want to try openfoam extend 3.1 there is allways the mistake: command not found. Do I have to recall the openfoam environment? Or did I do something wrong while the installation? If one of you might help me, I would be very grateful! Thank you for your help! Best regards, Stephie |
April 15, 2015, 06:16 |
Stephanie
Rep Power: 11 |
Okay, so I have to say, my computer turned off while the first installation. At this morning I repeat the last step : ./Allwmake.firstInstall
Now, I repeat this step again and here here are the last lines of the terminal.. there are many mistakes. /thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/chemkinToFoam.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lreactionThermophysicalModels -lbasicThermophysicalModels -lspecie -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/chemkinToFoam g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/stressDifferences.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lfiniteVolume -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/stressDifferences /usr/bin/ld: cannot find -lreactionThermophysicalModels /usr/bin/ld: cannot find -lbasicThermophysicalModels collect2: error: ld returned 1 exit status make[2]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/chemkinToFoam] Fehler 1 make[1]: *** [chemkinToFoam] Fehler 2 /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/stressDifferences] Fehler 1 make[2]: *** [stressDifferences] Fehler 2 make[2]: »/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/equilibriumCO« ist bereits aktualisiert. make[2]: »/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/equilibriumFlameT« ist bereits aktualisiert. g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/stressSymmComponents.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lfiniteVolume -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/stressSymmComponents make[2]: »/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT« ist bereits aktualisiert. make[1]: Das Target »application« wurde wegen Fehlern nicht aktualisiert. make: *** [thermophysical] Fehler 2 /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/stressSymmComponents] Fehler 1 make[2]: *** [stressSymmComponents] Fehler 2 make[2]: Das Target »application« wurde wegen Fehlern nicht aktualisiert. make[1]: *** [viscoelastic] Fehler 2 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/wallGradU.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lfiniteVolume -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallGradU g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/compressible/RAS/RASModel -I/home/stephanie/foam/foam-extend-3.1/src/thermophysicalModels/specie/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/thermophysicalModels/reactionThermo/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/thermophysicalModels/basic/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/wallHeatFlux.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lcompressibleRASModels -lreactionThermophysicalModels -lfiniteVolume -lspecie -lbasicThermophysicalModels -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallHeatFlux /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallGradU] Fehler 1 make[2]: *** [wallGradU] Fehler 2 /usr/bin/ld: cannot find -lcompressibleRASModels /usr/bin/ld: cannot find -lreactionThermophysicalModels /usr/bin/ld: cannot find -lfiniteVolume /usr/bin/ld: cannot find -lbasicThermophysicalModels collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallHeatFlux] Fehler 1 make[2]: *** [wallHeatFlux] Fehler 2 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/transportModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/incompressible/RAS/RASModel -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/wallShearStress.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lincompressibleRASModels -lincompressibleTransportModels -lfiniteVolume -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallShearStress g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/meshTools/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/incompressible/LES/LESModel -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/transportModels -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/yPlusLES.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/yPlusLES /usr/bin/ld: cannot find -lincompressibleRASModels /usr/bin/ld: cannot find -lincompressibleTransportModels /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/wallShearStress] Fehler 1 make[2]: *** [wallShearStress] Fehler 2 /usr/bin/ld: cannot find -lincompressibleLESModels /usr/bin/ld: cannot find -lincompressibleTransportModels /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/yPlusLES] Fehler 1 make[2]: *** [yPlusLES] Fehler 2 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/stephanie/foam/foam-extend-3.1/src/meshTools/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/transportModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/stephanie/foam/foam-extend-3.1/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/stephanie/foam/foam-extend-3.1/src/thermophysicalModels/basic/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stephanie/foam/foam-extend-3.1/src/foam/lnInclude -I/home/stephanie/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/yPlusRAS.o -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lincompressibleTransportModels -lincompressibleRASModels -lbasicThermophysicalModels -lspecie -lcompressibleRASModels -lfiniteVolume -lmeshTools -lsampling -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/yPlusRAS /usr/bin/ld: cannot find -lincompressibleTransportModels /usr/bin/ld: cannot find -lincompressibleRASModels /usr/bin/ld: cannot find -lbasicThermophysicalModels /usr/bin/ld: cannot find -lcompressibleRASModels /usr/bin/ld: cannot find -lfiniteVolume /usr/bin/ld: cannot find -lsampling collect2: error: ld returned 1 exit status make[3]: *** [/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/yPlusRAS] Fehler 1 make[2]: *** [yPlusRAS] Fehler 2 make[2]: Das Target »application« wurde wegen Fehlern nicht aktualisiert. make[1]: *** [wall] Fehler 2 make[1]: Das Target »application« wurde wegen Fehlern nicht aktualisiert. make: *** [postProcessing] Fehler 2 make: Das Target »application« wurde wegen Fehlern nicht aktualisiert. This system rpm command: rpm --force-debian ======================================== Starting ThirdParty Allwmake ======================================== ======================================== Starting ThirdParty AllMake: Stage5 ======================================== The source code for swak4Foam is already present under ./rpmBuild/BUILD/swak4Foam-0.3.1 Please remove this directory if you want to refresh your installation of swak4Foam ======================================== Done ThirdParty AllMake: Stage5 ======================================== ======================================== Done ThirdParty Allwmake ======================================== stephanie@stephanie:~/foam/foam-extend-3.1$ Perhaps anyone can help me to solve all of these mistake, I would be very gratefull! Thank you for your help! best regards, Stephie |
April 15, 2015, 06:54 |
Håkan Nilsson
Rep Power: 18 |
You should redirect the output of the Allwmake.firstInstall to a file: ./Allwmake.firstInstall > log_Allwmake.firstInstall Then you search that file for the first error message. The errors we see here are because some libraries did not compile successfully. The solvers depend on those libraries, so they will of course also not be compiled. Best regards, Håkan |
April 15, 2015, 07:51 |
Stephanie
Rep Power: 11 |
sorry, but I have to aks again...
I run your task and I get a logfile. I read through this file but there is no message with error. Instead of this the terminal shows the same mistakes like in my post before. How can I solve the problem? Do I have to install all files, the programm cannot find? How do I do this? I'm sorry, but I'm quite new. I tried it with sudo apt-get install -lfiniteVolume but it doesn't work. best regards, Stephie |
April 15, 2015, 08:23 |
Håkan Nilsson
Rep Power: 18 |
Sorry, my command should say:
./Allwmake.firstInstall >& log_Allwmake.firstInstall (so that also the error messages are written) The first error message we see here is: /usr/bin/ld: cannot find -lreactionThermophysicalModels It means that the library reactionThermophysicalModels did not compile properly. You should be able to find an error message saying why it did not compile. Search your log file for "error" and "reactionThermophysicalModels". All the libraries shown in the error message are libraries that are part of OpenFOAM, and must be successfully compiled before the applications can be compiled. The finiteVolume library is a central library in OpenFOAM. Håkan |
April 15, 2015, 08:42 |
Stephanie
Rep Power: 11 |
Okay so the logfile shows me the text from the terminal.
I had a look for "reactionThermophysicalModels" and I found this: -L/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt \ -lreactionThermophysicalModels -lbasicThermophysicalModels -lspecie -lfoam -liberty -ldl -lrt -lm -o /home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/chemkinToFoam make[2]: »/home/stephanie/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/surfaceFind« ist bereits aktualisiert. /usr/bin/ld: cannot find -lreactionThermophysicalModels /usr/bin/ld: cannot find -lbasicThermophysicalModelsrs and collect2: error: ld returned 1 exit status make: *** [/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt/libreactionThermophysicalModels.so] Fehler 1 + wmake libso laminarFlameSpeed /usr/bin/ld: cannot find -lfiniteVolume collect2: error: ld returned 1 exit status make: *** [/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt/liblaminarFlameSpeedModels.so] Fehler 1 + wmake libso chemistryModel /usr/bin/ld: cannot find -lbasicThermophysicalModels /usr/bin/ld: cannot find -lreactionThermophysicalModels I guess this is the location where the file is missing? because the file is not found. Pherhaps the mistake might be "ist bereits aktualisiert", in english --> has been updated Or might something like "collect2: error: ld returned 1 exit status" might be the problem? But how can I solve it? Regards, Stephie |
April 15, 2015, 08:49 |
Håkan Nilsson
Rep Power: 18 |
As I also said, try searching for the VERY FIRST error message. Like when finiteVolume is compiled.
April 15, 2015, 08:57 |
Stephanie
Rep Power: 11 |
the first erro message comes here:
'/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt/libmeshTools.so' is up to date. + wmake libso finiteVolume cyclicGgiFvPatchFields.o: Datei nicht erkannt: Datei abgeschnitten collect2: error: ld returned 1 exit status make: *** [/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so] Fehler 1 so this is the mistake: cyclicGgiFvPatchFields.o: Datei nicht erkannt: Datei abgeschnitten? |
April 15, 2015, 09:03 |
#9 |
Håkan Nilsson
Rep Power: 18 |
Try:
cd $FOAM_SRC/finiteVolume wclean lib wmake libso wmake libso >& log_wmake And post the log file. |
April 15, 2015, 16:22 |
#10 |
Stephanie
Rep Power: 11 |
Hey,
so this is the content of the logfile: '/home/stephanie/foam/foam-extend-3.1/lib/linux64GccDPOpt/libfiniteVolume.so' is up to date. |
April 15, 2015, 17:37 |
#11 |
Håkan Nilsson
Rep Power: 18 |
Ok, try:
foam ./Allwmake.firstInstall >& log_Allwmake.firstInstall It shouldn't complain about that library again. It was 25 years since I learnt German, and it was 23 years since I forgot it, but it seemed like there was a truncated object file that destroyed the compilation of the finiteVolume library. Let's see if you are lucky with the above. Håkan |
April 16, 2015, 04:39 |
#12 |
Stephanie
Rep Power: 11 |
Good morning,
I run your command after cd ~/foam/foam-extend-3.1 . etc/bashrc and I had a look into the logfile. There are any "errors" or mistakes anymore. That might be good sign. Instead of this I opened up an other terminal to test if cavity workes - unfortunateöy is does not. When I start it in same terminal where I did the installation it works. Where is still the problem? Do I have to set the shell (the openfoam environment) befor I can start working with OpenFoam? And how can I do this? Best regards |
April 16, 2015, 06:46 |
#13 |
Håkan Nilsson
Rep Power: 18 |
You have to set up the OpenFOAM environment in each terminal window you want to use OpenFOAM in.
That is nicely described in the installation instructions. I think that you should spend a lot of time to learn more about both Linux and OpenFOAM from scratch. Good luck! Håkan |
April 16, 2015, 08:33 |
#14 |
Stephanie
Rep Power: 11 |
You are right, I have to spend a lot of time to lern how to work with Linux and OpenFoam. It is not easy for me, but I try my best and I am really gratefull for everyones help.
So this was the step a miss, wasn't it? * Set environment variables: cd ~/foam/foam-extend-3.1 . etc/bashrc here I just copied and pasted it in the terminal, but I really have to search the bachrc file and enter at the end: source $HOME/foam/foam-extend-3.1/etc/bashrc but when I try to type in: $HOME/.bashrc in the terminal to get the environment.. the terminal says, I have no authority. is this the right way? but where is the last mistake? It would be amazing if you would help me one more time. Thank you so much |
April 16, 2015, 09:10 |
#15 |
Håkan Nilsson
Rep Power: 18 |
One more time, and then you must learn yourself.
The bashrc files should be sourced. When you type: $HOME/.bashrc you try to execute it, which is not allowed. Try: source $HOME/.bashrc On the other hand, that bashrc file is always sourced when you open a terminal window. That is the purpose of that file. So in most cases you shouldn't source it again (unless you modified it and want the modifications to be activated in an already open terminal window - but then I suggest that you close down the terminal window and open a new one) If you will always use only one OpenFOAM version, I suggest that you do the following (only once!): echo "source \$HOME/foam/foam-extend-3.1/etc/bashrc" >> $HOME/.bashrc Then close down all terminal windows. When you open a new terminal window it will already have the OpenFOAM environment of that version. When you need a new OpenFOAM version you have hopefully gained the skills to switch between versions. Best regards, Håkan |
April 23, 2015, 08:21 |
#16 |
Stephanie
Rep Power: 11 |
Okay.. I hope you know how unlikely ask again for help.. but I have to. Sice yesterday morning I I try to install foam-extend 3.1 on an other computer where OpenFoam 2.3.1 is already installed. I tried this time the installation by binary packages. A downloaded them and today I moved them to /opt/foam/foam-extend-3.1
Now I have the same problmen like last time. I want to set the envirnment. I opened up the bashrc file an wrote down: source /opt/foam/foam-extend-3.1/etc/bashrc Than I tried the following lines: cd /foam/foam-extend-3.1 . etc/bashrc But when I try source /.bashrc, I can see the computer is working, but it seems like he is stucking. This command can run more than one houre..but nothing changes. So I stoped it. Sometimes I also can read: bash: ./bashrc file or directory not found bash: opt/foam/foam-ectend-3.1/bin/foamCleanPath: Argument list too long. I really don't know, where the mistake is located. I also tried it to act as root, but nothing changes. Might you helpt me agein, hopefully for the last time? Thank you so much, best regards, Stephie |
April 23, 2015, 17:18 |
#17 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
FYI: Detailed answer given here: http://www.cfd-online.com/Forums/ope...tml#post543457 - post #10
[foam-extend.org] Trying to install foam-extend 3.1 on Ubuntu 14.04 | mbcx4jc2 | OpenFOAM Installation | 3 | February 11, 2015 13:54 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 10:45 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 in Ubuntu 14.04 | iafpython | OpenFOAM Installation | 8 | November 10, 2014 17:43 |
[Other] Problem in Open foam installation in ubuntu 14.04 | zannatul | OpenFOAM Installation | 2 | November 3, 2014 21:56 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
