[OpenFOAM.org] Problem of alias in OpenFOAM-2.3.1 |
April 12, 2015, 16:30 |
Rep Power: 11 |
Hi All
I installed OpenFOAM-2.3.1 by following steps on https://openfoamwiki.net/index.php/I...HEL#CentOS_6.5. I run the cavity sample at the moment when installation was finished, both OpenFoam and ParaView are work good. But when I turn off the terminal window and start a new terminal window, do the following again: Code:
[pxe819@takara ~]$ of231 [pxe819@takara ~]$ cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity Code:
bash: cd: /home/pxe819/OpenFOAM/pxe819-2.3.1/run/tutorials/incompressible/icoFoam/cavity: No such file or directory Code:
echo "alias of231='module load openmpi-x86_64; source \$HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc alias of231='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=16 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' alias of231='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc ' Thanks Last edited by wyldckat; April 12, 2015 at 17:02. Reason: Added [CODE][/CODE] |
April 12, 2015, 17:03 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings jzheng,
OK, I see the problem. Sorry about the confusing instructions on the wiki, because I should have emphasized what I meant... where this is written: Quote:
Also, save an alias in the personal .bashrc file, simply by running:------------- In order to fix this problem, please edit the file "~/.bashrc" and change this block of code you have at the end of the file: Code:
echo "alias of231='module load openmpi-x86_64; source \$HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc alias of231='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=16 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' alias of231='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc ' Code:
alias of231='module load openmpi-x86_64; source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=16 foamCompiler=ThirdParty WM_COMPILER=Gcc48 WM_MPLIB=SYSTEMOPENMPI' Bruno
April 12, 2015, 20:59 |
Rep Power: 11 |
Hi Bruno
It works perfect after I changed personal .bashrc. This OpenFOAM was installed on my own virtual machine. I just have another question that can I copy this OpenFOAM and run it on another machine which is using the same CentOS but no root access? Thanks |
April 19, 2015, 14:07 |
#4 | |
Bruno Santos
Rep Power: 128 |
In practice: depends on whether the other machine has all of the same library versions as yours. If not, you might risk some failures while running, due to incompatible library versions. |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview | ditmeyer | OpenFOAM Installation | 3 | May 15, 2017 12:04 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
[OpenFOAM.org] OpenFOAM 2.3.1: installation problem with ParaView 4.1.0 | hjw | OpenFOAM Installation | 5 | November 17, 2015 21:14 |
