[foam-extend.org] foam-extend. cudaSolvers compilation
Old   April 7, 2015, 04:42
Default foam-extend. cudaSolvers compilation
Svensen is on a distinguished road
I'm trying to compile cudaSolvers but I've got errors like the following. Does anyone successfully compiled these solvers on their computers ??
/usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply/coo_serial.cu: In function ‘void cusp::system::cuda::spmv_coo_serial_device(const Matrix&, const Array1&, Array2&)’:
/usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply/coo_serial.cu:66:51: error: expected primary-expression before ‘<’ token
spmv_coo_serial_kernel<IndexType,ValueType> <<<1,1>>>
/usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply/coo_serial.cu:66:57: error: expected primary-expression before ‘>’ token
In file included from /usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply.h:21:0,
from /usr/local/cuda-6.5/include/cusp/system/cuda/execution_policy.h:50,
from /usr/local/cuda-6.5/include/cusp/execution_policy.h:34,
from /usr/local/cuda-6.5/include/cusp/convert.h:25,
from /usr/local/cuda-6.5/include/cusp/detail/coo_matrix.inl:18,
from /usr/local/cuda-6.5/include/cusp/coo_matrix.h:597,
from cudaSolver/cudaTypes.H:53,
from cudaSolver/cudaSolver.H:42,
from cudaSolver/cudaSolver.C:26:
/usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply/coo_flat_spmv.h: In function ‘ValueType cusp::system::cuda::segreduce_warp(IndexType, IndexType, ValueType, IndexType*, ValueType*)’:
/usr/local/cuda-6.5/include/cusp/system/cuda/detail/multiply/coo_flat_spmv.h:40:10: error: ‘threadIdx’ was not declared in this scope
rows[threadIdx.x] = row;
Svensen is offline   Reply With Quote
Old   April 7, 2015, 08:46
Elvis
elvis will become famous soon enough
My guess is that Dominik Christ did that, he works for http://wikki.co.uk
http://www.cfd-online.com/Forums/mem...ik_christ.html
elvis is offline   Reply With Quote
Old   September 6, 2015, 08:05
Default cudaSolvers compilation => toward a solution
Thierry Rochemont
ThierryRochemont is on a distinguished road
I was struggling also with cudaSolver compilation. I found out that by reverting to cusp library v0.4.0 might do the trick.
git clone --branch v0.4.0 https://github.com/cusplibrary/cusplibrary.git cusplibray
cd cusplibrary
git checkout -b v0.4.0
copy cusp directory to your cuda install path
I had also to change cuda_lib_dir to lib64 in customized etc/prefs.sh
export cuda_lib_dir=$cuda_dir/lib64
go to $FOAM_SRC/cudaSolvers
./Allwmake
Regards,
OS system:
ubuntu 14.04
grapic video = Geforce 970, with cuda_6.5.19_linux64.run
openfoam: foam-extend-3.2 (nextRelease branch)
gcc (Ubuntu 4.8.4-2ubuntu1~14.04) 4.8.4
ThierryRochemont is offline   Reply With Quote
Old   September 24, 2015, 12:20
zhihongliu is on a distinguished road
Hi,ThierryRochemont
have you solved this problem?
I followed your step by add the "export cuda_lib_dir=$cuda_dir/lib64" to the path foam/foam/foam-extend-3.1/etc
and I used the cusp v0.5.1, cuda7.0
but I still get the same problem.
I hope I can get your help which will save me from the debug nightmare.
zhihongliu is offline   Reply With Quote
Old   September 25, 2015, 03:23
You need to switch to cusp library v0.4.0
Old   September 26, 2015, 12:18
Thank you, Svensen
I have compiled it correctly by using the cusp library v0.4.0
But I am still confused why cusp v0.5.0 show the error: expected primary-expression before ‘<’ token.
Old   October 21, 2015, 15:54
Paul Handy
phandy is on a distinguished road
This is what got mine to compile.
phandy is offline   Reply With Quote
cuda, foam-extend-3.1
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
