[OpenFOAM.org] Installation of OpenFOAM 2.3.1 on RHEL 6.3
Old   March 24, 2015, 02:27
Default Installation of OpenFOAM 2.3.1 on RHEL 6.3
Jack B.
Turbulent is on a distinguished road
Is it possbile to install OpenFOAM 2.3.1 on RHEL Server 6.3?
The latest upgradable GCC version for the system is 4.4.7 while OpenFOAM demands GCC 4.5.0 and above.
Any help would be appreciated.
Thanks,
Jack
Turbulent is offline   Reply With Quote
Old   March 24, 2015, 11:55
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Yes, it is possible. You even have two possibilities:
1. Build newer version gcc (using makeGcc script from ThirdParty folder, http://openfoamwiki.net/index.php/In...HEL#CentOS_6.5)
2. Install newer version of Gcc using Sofware Collections (https://access.redhat.com/documentat...e_Collections/).
alexeym is offline   Reply With Quote
Old   March 26, 2015, 04:32
Al
donQi is on a distinguished road
Hi Jack,
here comes another way I used [but before try Alexey's suggestion that is a more elegant solution]
Similarly to you, I had a redhat server 6.4 Santiago, and gcc 4.4.7 without the possibility to become root.
Therefore I did the following:
1) take an hard disk with some GB of space and install on it virtual box portable http://www.vbox.me/
2) create a virtual machine installing CentOS 6.6
3) follow the instruction from http://www.openfoam.org/download/git.php
4) copy the compiled version of the virtual machine into your redhat 6.4 server
5) modify the environment variables
I test some tutorials and they are running well.
If you are interested in more details I copy below my diary of command executed:
In the virtual machine centOS6.6:
as root:
yum install git
download the sources
 cd /home/donQi/OpenFOAM
as normal user [not Root]
git clone git://github.com/OpenFOAM/OpenFOAM-2.3.x.git
    cd OpenFOAM-2.3.x
    git pull
save in /home/donQi/OpenFOAM the ThirdParty-2.3.1.tgz
(always as normal user)
tar xzf ThirdParty-2.3.1.tgz
    mv ThirdParty-2.3.1 ThirdParty-2.3.x
now as root:
yum groupinstall 'Development Tools'
    yum install openmpi openmpi-devel
    yum-config-manager --nogpgcheck --add-repo http://dl.atrpms.net/el6-x86_64/atrpms/stable
    yum install --nogpgcheck qtwebkit qtwebkit-devel
    yum install --nogpgcheck CGAL CGAL-devel
then :
 ln -s /usr/lib64/libboost_thread-mt.so /usr/lib64/libboost_thread.so
then as normal user
 gedit ~/.bashrc
add the lines:
 export PATH=/usr/lib64/openmpi/bin/:$PATH
    export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH
then in terminal
source ~/.bashrc
    mpirun --version
you should see the message:
mpirun (Open MPI) 1.8.1
then as root:
 yum-config-manager --nogpgcheck --add-repo http://springdale.princeton.edu/data/puias/6.5/x86_64/os
    yum-config-manager --nogpgcheck --add-repo http://springdale.princeton.edu/data/puias/DevToolset/6.5/x86_64
    yum install --nogpgcheck devtoolset-1.1-runtime devtoolset-1.1-gcc.x86_64 devtoolset-1.1-gcc-c++.x86_64
This creates an isolated installation of GCC which can be used by sourcing the relevant script by typing the following in a local terminal:
   source /opt/rh/devtoolset-1.1/enable
then as normal user
    gcc --version
and we get
 gcc (GCC) 4.7.2 20121015 (Red Hat 4.7.2-5)
        Copyright (C) 2012 Free Software Foundation, Inc.
        This is free software; see the source for copying conditions.  There is NO
        warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Finally!!!
ENVIRONMENT VARIABLES
in thunder VirtualMachine where we had /home/donQi/OpenFOAM/ we have just add in ~/.bashrc :
source $HOME/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc
type:
foam
and you should be in the directory OpenFOAM-2.3.x
let's check
 foamSystemCheck
we get:
System check: PASS
Jeremy Clarkson get the vietnamese driving license!!! OK!!!!
Then
cd $WM_PROJECT_DIR
to avoid an error [ "/usr/bin/ld: cannot find -lz" ] before launching the Allrun install also
    yum install zlib-static
    yum install glibc-static
NOTE: if you get an error "NOKEY.." then use:
    yum install --nogpgcheck zlib-static
    yum install --nogpgcheck glibc-static
Then launch:
./Allwmake > make.log 2>&1
OK zero errors.
Now back to copy in our server.
>> Copying the compiled openFOAM to Redhat6.4 /
In the thunder VirtualMachine, copy all the files inside the OpenFOAM directory into the share directory:
sudo su -
    cd -rL /home/donQi/OpenFOAM/* /media/sf_ShareThunder
NOTE: we add the L option to avoid the error "ERROR Cannot create symlink to"
Then back to the RedHat6.4 machine:
we copy the directory from the virtual machine (OpenFOAM-2.3.x, donQi-2.3.x and ThirdParty-2.3.x) into
/net/lnx6/home/donQi/OpenFOAM/thunderCompiled
In ~/.bashrc set :
 alias OF23x='. /net/lnx6/home/donQi/OpenFOAM/thunderCompiled/OpenFOAM-2.3.x/etc/bashrc'
e nella ect/bash
 foamInstall=/net/lnx6/home/donQi/OpenFOAM/thunderCompiled/
new terminal
  source ~/.bashrc
  OF23x
  tut
  cd incompressible/icoFoam
  blockMesh
OK works
[1034 cavity] >> blockMesh
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.x-c70d1f3c1beb
Exec   : blockMesh
Date   : Mar 26 2015
donQi is offline   Reply With Quote
rhel 6.3
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
RHEL 6.3 Installation problem Turbulent STAR-CCM+ 0 September 3, 2014 08:01
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 12:43
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 14:16
