[OpenFOAM.org] Running OpenFOAM
Old   March 7, 2015, 06:53
Default Running OpenFOAM
KateEisenhower is on a distinguished road
Hi guys,
Finally I managed to install OpenFOAM 2.3.0 following this guide:
http://matveichev.blogspot.fr/2014/0...m-on-os-x.html
However there are still a few questions left:
1) When I have started ParaView via typing "paraFoam" in the terminal, the cursor jumps to the next line, but the
usersmbp:~ mbp$
line is missing. Does this mean I cannot use the terminal while running ParaView? When I close ParaView the missing line reappears in terminal.
2) How do I start OpenFOAM after rebooting my MacBook Pro? Somehow the OpenFOAM folder is empty after rebooting. When I double-click on OpenFOAM.sparsebundle, a OpenFOAM ?disk image? appears on the desktop. It contains the folders which are normally in the OpenFOAM folder. But the cavity example still doesn't work.
3) How do I upgrade from OpenFOAM 2.3.0 to 2.3.1 for example?
Thanks a lot for your help,
Kate
KateEisenhower is offline   Reply With Quote
Old   March 7, 2015, 08:14
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. You can not use terminal if paraview is running in foreground (well, terminal will echo everything you type but will not execute the commands). If you would like to use terminal after you started paraFoam use "paraFoam &" command. Ampersand will send paraview in background so you can continue to use terminal.
2. You have to use this command to mount disk image:
hdiutil attach -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle
And then set up environment with
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
In fact it is described in Post-configuration part of the post.
3. You do not upgrade 2.3.0 to 2.3.1. Either you install 2.3.1 along with 2.3.0, or you remove 2.3.0 and install 2.3.1. Patch for 2.3.1 can be found in this repository. In the wiki you will find updated guide for installation.
alexeym is offline   Reply With Quote
Old   March 10, 2015, 14:42
Thanks a lot for your help!
This works perfectly. Thank you! I think you mean the following code:
alias of2NM='hdiutil attach -quiet -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle; sleep 1; source $HOME/OpenFOAM/OpenFOAM-2.N.M/etc/bashrc'
This didn't work for me. Is there any way to mount the disk image and set up the environment automatically after rebooting?
Old   March 10, 2015, 14:56
Alexey Matveichev
This piece of code never worked for me also.
The way I set up the environment is described in https://github.com/mrklein/openfoam-...two-approaches.
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. MBttR OpenFOAM Running, Solving & CFD 0 June 13, 2016 11:58
Difficulty running an inviscid compressible nozzle flow using OpenFOAM rbozinoski OpenFOAM Running, Solving & CFD 11 December 29, 2015 08:19
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
