[foam-extend.org] Having trouble following the installation instructions for foam-extend 3.1
Old   February 8, 2015, 06:40
Default foam-extend 3.1
  #21
mojtaba
cliff is on a distinguished road
Originally Posted by wyldckat View Post
OK, so apparently you compressed and provided the wrong file.
Start a new terminal and run:
source $HOME/foam/foam-extend-3.1/etc/bashrc
foam
tar -czf log.make.tar.gz log.make
pwd
The last command will tell you the full path to the folder where the file log.make.tar.gz" is located.
http://www.mediafire.com/download/00...og.make.tar.gz
cliff is offline   Reply With Quote
Old   February 8, 2015, 07:49
Retired Super Moderator
Bruno Santos
OK, finally, we now have a clear picture of what went wrong.
The problem is that you're not able to access the website sourceforge.net. If you open the file "make.log" with a simple text editor, search for the following error message:
ERROR 504: Gateway Time-out.
The first one you'll find is this block:
Download openmpi-1.6.5.tar.gz from : http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/openmpi-1.6.5.tar.gz
--2015-02-07 20:32:46--  http://downloads.sourceforge.net/project/openfoam-extend/foam-extend-3.1/ThirdParty/openmpi-1.6.5.tar.gz
Resolving downloads.sourceforge.net (downloads.sourceforge.net)... 216.34.181.59
Connecting to downloads.sourceforge.net (downloads.sourceforge.net)|216.34.181.59|:80... connected.
HTTP request sent, awaiting response... 504 Gateway Time-out
2015-02-07 20:33:01 ERROR 504: Gateway Time-out.
The first line shown above tells which file is being downloaded and from where.
For example, for this first file, you need to search online for the file "openmpi-1.6.5.tar.gz", download it and place it inside the folder "~/foam/foam-extend-3.1/ThirdParty/rpmBuild/SOURCES".
Then do the same for all other files that have been reported in "make.log" that were not downloaded.
Old   February 8, 2015, 09:04
  #23
mojtaba
Hi Bruno i've done what you said. There was 6 "Gateway Time-out" error including not downloading these 6 files:
metis-5.1.0.tar.gz
mesquite-2.1.2.tar.gz
scotch-6.0.0.tar.gz
PyFoam-0.6.1.tar.gz
hwloc-1.7.2.tar.gz
i downloaded them from this link http://sourceforge.net/projects/open....0/ThirdParty/
and copied to that direction. Please tell me the next step.
Old   February 8, 2015, 09:19
Bruno Santos
OK, now it's the same as before, namely:
OK, then try to follow these steps:
foam
./Allwmake.firstInstall > log.make 2>&1
which icoFoam
which paraview
and if all goes well, please indicate what the last 2 lines give you.
Old   February 8, 2015, 09:29
  #25
mojtaba
How long "./Allwmake.firstInstall > log.make 2>&1"
takes to compile?
Old   February 8, 2015, 09:30
Bruno Santos
takes to compile?
6 to 8 hours, if compiled with only one core.
Old   February 8, 2015, 09:47
mojtaba
It seems like compiling is done after 10 minutes.
This time just last command gave nothing.
Here is my terminal window:
sepinood@sepinood-Inspiron-N5010:~$ source $HOME/foam/foam-extend-3.1/etc/bashrc
sepinood@sepinood-Inspiron-N5010:~$ foam
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ ./Allwmake.firstInstall > log.make 2>&1
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ source $HOME/foam/foam-extend-3.1/etc/bashrc
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ which icoFoam
/home/sepinood/foam/foam-extend-3.1/applications/bin/linuxGccDPOpt/icoFoam
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ which paraview
Old   February 8, 2015, 09:50
Bruno Santos
Have a look into the file "log.make" to try and see where the error is now.
If you cannot understand what the error is, compress the latest file and attach it or provide a link for it.
Old   February 8, 2015, 10:00
  #29
mojtaba
Here is the link of my log file http://www.mediafire.com/download/sb...make.tar(2).gz
Old   February 8, 2015, 10:15
Bruno Santos
OK, here we go, another lap around the block... hopefully this time ParaView will build... run the following commands:
export QT_SELECT=qt4
export QT_BIN_DIR=$(which qmake)
echo "export QT_BIN_DIR=$QT_BIN_DIR" >> etc/prefs.sh
foam
which icoFoam
which paraview
Old   February 8, 2015, 10:21
  #31
mojtaba
foam
which icoFoam
which paraview
The third command have a problem.
Terminal window:
sepinood@sepinood-Inspiron-N5010:~$ export QT_SELECT=qt4
sepinood@sepinood-Inspiron-N5010:~$ export QT_BIN_DIR=$(which qmake)
sepinood@sepinood-Inspiron-N5010:~$ echo "export QT_BIN_DIR=$QT_BIN_DIR" >> etc/prefs.sh
bash: etc/prefs.sh: No such file or directory
Old   February 8, 2015, 10:29
Bruno Santos
Sorry, I forgot that the shell environment had to already be readied... try this:
foam
which icoFoam
which paraview
Old   February 8, 2015, 10:40
  #33
mojtaba
foam
which icoFoam
which paraview
The last command gave nothing again
Terminal window:
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ export QT_SELECT=qt4
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ export QT_BIN_DIR=$(which qmake)
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ echo "export QT_BIN_DIR=$QT_BIN_DIR" >> etc/prefs.sh
Old   February 8, 2015, 10:49
Bruno Santos
I need the latest log file to see what went wrong: "log.make"
Old   February 8, 2015, 11:01
  #35
mojtaba
Here it is.
log.make.tar.gz
Old   February 8, 2015, 11:24
Bruno Santos
What do the following commands give you?
which qmake
which qmake-qt4
If neither one give you anything, then run:
sudo apt-get install qt4-dev-tools libqt4-dev libqtwebkit-dev
Then try again running the two commands above. If they now work, then do again the commands from my previous post.
Old   February 8, 2015, 11:28
  #37
mojtaba
which qmake
which qmake-qt4
these cpmmands gave some directories
Terminal window:
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ which qmake
/usr/bin/qmake
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ which qmake-qt4
/usr/bin/qmake-qt4
Old   February 8, 2015, 11:37
Bruno Santos
This is strange... OK, I need to see the output from these commands:
foam
cat etc/prefs.sh
Old   February 8, 2015, 11:51
  #39
mojtaba
foam
cat etc/prefs.sh
sepinood@sepinood-Inspiron-N5010:~$ source $HOME/foam/foam-extend-3.1/etc/bashrcsepinood@sepinood-Inspiron-N5010:~$ foam
sepinood@sepinood-Inspiron-N5010:~/foam/foam-extend-3.1$ cat etc/prefs.sh
export QT_BIN_DIR=/path/to/qmake
export CUDA_ARCH=sm_30
export QT_BIN_DIR=/usr/bin/qmake
Old   February 8, 2015, 12:00
Bruno Santos
OK, try this:
foam
echo "export QT_BIN_DIR=/usr/bin/qmake" > etc/prefs.sh
which icoFoam
which paraview
[foam-extend.org] A problem about installation of open foam extend 3.1 Toalchemist OpenFOAM Installation 1 May 31, 2018 09:58
[foam-extend.org] Foam extend 3.2 wrong installation directory geop OpenFOAM Installation 0 May 11, 2016 06:52
[foam-extend.org] Error during the installation of foam-extend 3.1 shipman OpenFOAM Installation 6 April 18, 2016 07:37
ParaView-4.0.1 did not compile for foam extend 3.0 installation mhkenergy OpenFOAM Installation 8 June 4, 2014 03:26
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
