[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library |
June 11, 2015, 05:32 |
#21 |
chubb87
Rep Power: 15 |
my case also contains an ACMI and I had the same error while decomposing, which I can avoid by using your "hack", thanks Bruno for the effort. Yet when I start a solver in parallel with that case, I get this MPI-error: Code:
*** An error occurred in MPI_Recv *** reported by process [715390977,1] *** on communicator MPI_COMM_WORLD *** MPI_ERR_TRUNCATE: message truncated *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) Does anyone else have this problem? BTW I tried the same case with an AMI and that works in parallel. The reason I would lik to use the ACMI setup is the bad scaling behaviour of the AMI setup. |
June 12, 2015, 18:10 |
#22 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings chubb87,
If your case runs with AMI, then you probably shouldn't even try ACMI... furthermore, ACMI only works in some cases, it's not yet fully operational: http://www.openfoam.org/mantisbt/view.php?id=1450#c3913 Best regards, Bruno
June 15, 2015, 05:08 |
#23 |
chubb87
Rep Power: 15 |
Hi Bruno,
then I'll probably have to stick with the AMI setup. The ACMI setup of course has the interface at a lower radius, so that it is not needed for the whole 360° but only for about 1 % of the area, where an outlet hole exists (see schematic mesh in the picture). The rest is to be modelled as a rotating wall (blocked region), I am not sure if this is possible with the ACMI. This reduced area of the ACMI compared to the AMI should reduce the computational demand ernormously, if it would work. |
June 15, 2015, 15:49 |
#24 |
Bruno Santos
Rep Power: 128 |
Quick answer: That image looks familiar... ah HA, found it: http://www.cfd-online.com/Forums/ope...cmi-patch.html
Here are some related threads on this topic: |
[OpenFOAM.com] Pstream library error in parallel mode | begou | OpenFOAM Installation | 12 | July 31, 2023 12:40 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
Problems running in parallel - Pstream not available | dark lancer | OpenFOAM Installation | 14 | October 13, 2013 15:13 |
what's dummy Pstream for?? | quaintchewster | OpenFOAM Installation | 2 | March 4, 2012 14:29 |
Prallel run error Pstream library | tsjb00 | OpenFOAM Running, Solving & CFD | 1 | April 12, 2008 09:43 |
