[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 |
November 24, 2014, 04:35 |
Rep Power: 13 |
Hello fellow foamers;
As you know it is take a long time for compiling OpenFOAM from source. To save the time in compiling and configuring , then actually learning about it , I precompiled OpenFOAM with Paraview 4.2.0 installation for Ubuntu x64 and created a script to install it on your Ubuntu Machine , (tested with Kubuntu 14.04) Following are the steps you need to follow 1.Extract OpenFOAM.tar.gz 2.Type in terminal Code:
chmod +x OpenFOAM_install.sh Code:
./OpenFOAM_install.sh Code:
sudo -s Code:
of230 PS:I have built OpenFOAM from latest git repository and paraview 4.2.0 with python support .I have also installed OpenFOAM in my system dir /opt/OpenFOAM no error and it worked fine. http://uberlinux.blogspot.in/2014/11...or-ubuntu.html Last edited by p0kerus; November 25, 2014 at 07:59. Reason: Forgot link |
November 29, 2014, 18:20 |
Mike Hersee
Rep Power: 12 |
HI, I had previously tried the standard installation instruction for Ubuntu 14.04 on my Mint 17 installation (based on Ubuntu 14.04). That failed because it couldn't find the opengl_include_dir, even though opengl was installed and working. I deleted the libraries created by that installation and tried your one, but when I do of230, it just doesn't do anything - no error message either. What might be going wrong?
Mike |
December 2, 2014, 08:54 |
Rep Power: 13 |
did you try icoFoam -help
and if you get normal screen , with usage screen then your installation works try reading openfoam user guide for how to use go about using openfoam Last edited by p0kerus; December 2, 2014 at 14:48. |
openfoam 2.3.0, paraview 4.2, ubuntu 14.04 lts |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 15:30 |
[OpenFOAM.org] Problems with Paraview (OpenFOAM 2.4.0 from source code in Ubuntu 14.04) | Gerrit | OpenFOAM Installation | 4 | August 15, 2015 12:05 |
[OpenFOAM] Problem running Paraview on Ubuntu 14.04 | aminthefresh | ParaView | 0 | November 4, 2014 13:34 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 16:42 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
