[Other] Soureces guide
Old   November 12, 2014, 04:55
Default Soureces guide
Yongxiao Wang
Yanci is on a distinguished road
why cant I open this webpage ?
http://www.openfoam.org/docs/cpp/
Yanci is offline   Reply With Quote
Old   November 12, 2014, 05:33
Joachim Herb
jherb is on a distinguished road
Your link does not contain the ":" (at least if you click on it)
http://www.openfoam.org/docs/cpp/ does work
jherb is offline   Reply With Quote
Old   November 12, 2014, 06:05
Yongxiao Wang
Thank you for your reply. But I cant open your link.
I want to get the sources guide, but I do not generate it using the method in OpenFOAM website. http://www.openfoam.org/docs/
When I execute “doxygen” from within the doc directory, there will be the following information.
Doxyfile not found and no input file specified!
Doxygen version 1.7.6.1
Copyright Dimitri van Heesch 1997-2011
You can use doxygen in a number of ways:
1) Use doxygen to generate a template configuration file:
doxygen [-s] -g [configName]
If - is used for configName doxygen will write to standard output.
2) Use doxygen to update an old configuration file:
doxygen [-s] -u [configName]
3) Use doxygen to generate documentation using an existing configuration file:
doxygen [configName]
If - is used for configName doxygen will read from standard input.
4) Use doxygen to generate a template file controlling the layout of the
generated documentation:
doxygen -l layoutFileName.xml
5) Use doxygen to generate a template style sheet file for RTF, HTML or Latex.
RTF: doxygen -w rtf styleSheetFile
HTML: doxygen -w html headerFile footerFile styleSheetFile [configFile]
LaTeX: doxygen -w latex headerFile footerFile styleSheetFile [configFile]
6) Use doxygen to generate an rtf extensions file
RTF: doxygen -e rtf extensionsFile
If -s is specified the comments in the config file will be omitted.
If configName is omitted `Doxyfile' will be used as a default.
How should I do ?
Old   November 12, 2014, 06:11
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. I guess the link jherb has posted was to demonstrate the error in the link you've posted as a thread starter.
2. In doc folder there's Allwmake script which calls doxygen with all necessary parameters. You should use it.
alexeym is offline   Reply With Quote
Old   November 12, 2014, 06:34
Yongxiao Wang
When I execute Allwmake, there will be error as follows:
+ chmod a+rX /doc Doxygen
chmod: cannot access "/doc": directory does not exist
+ Doxygen/Allwmake
Error: WM_PROJECT_DIR directory does not exist
Check the OpenFOAM entries in your dot-files and source them.
WM_PROJECT_DIR=
Old   November 12, 2014, 06:38
Alexey Matveichev
You did not set up environment with 'source /opt/openfoam230/etc/bashrc' after becoming root.
Old   November 12, 2014, 10:15
Yongxiao Wang
The html directory has been successfully generated.
Thanks a lot to you.
[Other] Non-official OpenFOAM Guide for beginners Casacuberta OpenFOAM Community Contributions 15 July 17, 2018 14:52
Ansys CFX: Theory Guide Nurzhan CFX 5 February 14, 2015 05:31
CFX-Mesh, guide vanes (baffles) and problems. R. Janny CFX 2 October 1, 2012 05:57
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 22:58
CFD Books Guide Pre-Release, Help Needed David & Jonas Main CFD Forum 1 March 2, 2000 03:57
