October 10, 2014, 12:16 |
I think I made a mistake with bashrc file
Keith
I just started using openFOAM, and first I had just installed it and got everything to work in the tutorials, but I screwed some things up and ended up reinstalling. I also tried to use HELYX-OS and I kept getting weird errors like:
Inconsistency detected by ld.so: dl-version.c: 224: _dl_check_map_versions: Assertion `needed != ((void *)0)' failed! Code:
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=2 WM_MPLIB=SYSTEMOPENMPI alias of230='source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc ' Code:
/home/datacollector/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc: line 182: /home/datacollector/OpenFOAM-2.3.0/bin/foamEtcFile: Code:
/home/datacollector/OpenFOAM-2.3.0/bin/foamEtcFile Code:
/home/datacollector/OpenFOAM/OpenFOAM-2.3.0/bin/foamEtcFile Thanks |
October 11, 2014, 17:56 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Keith and welcome to the forum!
Why do I have the feeling you copy-pasted those two lines of code to the wrong "bashrc" file? The correct file should be "$HOME/.bashrc" . In addition, knowing which Linux Distribution you're using and which installation instructions you followed for installing OpenFOAM and HelyxOS, would make it a lot easier for us to diagnose the problem. Beyond this, I believe this problem is very similar to the one reported here: http://www.cfd-online.com/Forums/ope...u-14-04-a.html In the second post there is a solution reported there. Best regards, Bruno
October 16, 2014, 13:37 |
Keith
I reinstalled Ubuntu 14.04 and OpenFOAM 2.3.0, and now I can run everything just fine. However, I still can not get Helyx-OS v2.1.1 to run no matter what I try.
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 16:14 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
