paraview not working after installing OpenFOAM in Ubuntu 12.04
Old   October 7, 2014, 07:02
Default paraview not working after installing OpenFOAM in Ubuntu 12.04
chen long
Jackie Chen is on a distinguished road
Hello all.
I just installed OF-2.3.0 on Ubuntu 12.04 following these instructions: http://www.openfoam.org/download/ubuntu.php
The paraView cannot run properly
When I try to run it the following error arises:
Anyone knows the problem?Thanks in advance
FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake
Jackie Chen is offline   Reply With Quote
Old   October 7, 2014, 10:57
blacksquirrel is on a distinguished road
Hi Jackie,
Try this instructions:
http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu
The paraview for OF2.3.0 needs a newer cmake and you need to custom build your paraview.
blacksquirrel is offline   Reply With Quote
Old   October 8, 2014, 02:56
chen long
Hi
Thanks for your reply. However, when i reach step 5. it shows failed to create symbolic link. and no such file or directory.
Do you know what is the problem?
Thanks
Old   October 8, 2014, 04:12
chen long
BTW, can i uninstall the latest version of OF and use the previous version?Thanks
Old   October 8, 2014, 06:26
Hi Jackie,
Yes, you can uninstall the new version of OF and use an older one.
In the step by step instruction in the CFD wiki: step5 is an optional step and not related to your paraview problem. Important steps are 8-10.
And if that not works, have a look at this thread:
http://www.cfd-online.com/Forums/ope...not-exist.html
This is a similar problem, the other way round. (new system, old OF)
Old   October 9, 2014, 07:28
chen long
Thanks, it works now!
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 AHutchison OpenFOAM Installation 6 June 4, 2013 13:11
Installing OpenFOAM 1.6-ext on Ubuntu 11.10 immortality OpenFOAM Installation 17 May 6, 2013 18:43
Whats the video card recommended for Paraview 3120 in Ubuntu 12.04? chujeh2020 Hardware 1 July 14, 2012 13:03
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Installing OpenFOAM 1.7.0 on Ubuntu Hardy 64bit nuovodna OpenFOAM 2 July 1, 2010 10:24
