September 10, 2014, 11:12 |
paraFoam Build Issues
Chris L
Rep Power: 14 |
Hi Foamers,
I am building a new version of parafoam on a Ubuntu 14.04 from the source pack. However, I get the following error, FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake I have attached a log file of the build process. Any help appreciated. Edit: From another thread Using sed -i -e 's=CUDA_FOUND=OFF=g' ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeLists.txt The new log file stops at 12% and gives the following error [ 12%] Building CXX object VTK/ThirdParty/ftgl/CMakeFiles/vtkftgl.dir/src/FTSize.cpp.o make[2]: *** No rule to make target `/usr/lib/x86_64-linux-gnu/libGL.so', needed by `lib/libvtkftgl-pv4.1.so.1'. Stop. make[1]: *** [VTK/ThirdParty/ftgl/CMakeFiles/vtkftgl.dir/all] Error 2 make: *** [all] Error 2 |
September 13, 2014, 15:23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Chris,
Are you following the installation instructions from here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 ? Best regards, Bruno
SU2 3.0 build failure | waku2005 | SU2 Installation | 4 | January 24, 2014 12:40 |
Hardware build review/advise for student desktop | AerE | Hardware | 10 | July 5, 2013 06:03 |
[OpenFOAM] How to use paraFoam on a cluster | andreas | ParaView | 1 | March 6, 2013 17:11 |
Region Status issues in paraFoam | oldschool | OpenFOAM | 2 | January 29, 2010 11:29 |
[OpenFOAM] Building Paraview with reader builtin instead of parafoam script | tj22 | ParaView | 2 | April 7, 2006 12:55 |
