[OpenFOAM.org] ParaView Error - error while loading shared libraries: libQtWebKit.so.4 |
August 20, 2014, 18:11 |
Yijiu Jiang
Rep Power: 13 |
Hi all,
I got the following error message when I launched ParaView on my cluster today. Anyone has idea on this? /home/jaq526/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc45/paraview-3.12.0/lib/paraview-3.12/paraview: error while loading shared libraries: libQtWebKit.so.4: connot open share object file: No such file or directory My ParaView runs without problem before this. Any suggestion? Thanks. Yijiu |
August 30, 2014, 10:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Yijiu,
Either the Linux Distribution in your cluster was updated and/or something happened to the Qt4 installation that your ParaView build is looking for. You will probably have to ask your cluster administrator for more information on any changes that occurred. Although either way you will have to rebuild ParaView once again from source code. Best regards, Bruno
July 23, 2015, 23:29 |
Petya Stoyanova
Rep Power: 11 |
It's my first time trying to run Paraview in OpenFOAM and I got the same message? How can I fix it? What does rebuilding ParaView once again from source code mean and how do I do that? (sorry for the possibly stupid questions)
July 25, 2015, 08:42 |
Bruno Santos
Rep Power: 128 |
Quick answer: Please provide more details. It all depends on where you installed (Linux?) and how you installed OpenFOAM and ParaView. Namely, in what Operating System and which installation instructions did you follow.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 04:01 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
