Error in compiling pisoFoam after some changes
Old   July 23, 2014, 06:05
Default Error in compiling pisoFoam after some changes
anonymous
Man Yue is on a distinguished road
I have installed openfoam 1.7.0 into ubuntu 12.04 LTS to perform LES. To allow timesteps to be determined by CFL number (maxCo), I modify the file:
/opt/openfoam170/applications/solvers/incompressible/pisoFoam/pisoFoam
to add the lines:
#include "readTimeControls.H"
below #include "readTimeControls.H"
#include "setDeltaT.H"
below #include "CourantNo.H"
And then compile pisoFoam with the following inputs in the terminal:
cd $FOAM_SOLVERS/incompressible/pisoFoam
sudo bash
wmake
However, error message comes:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam170/src/turbulenceModels/incompressible/turbulenceModel     -I/opt/openfoam170/src/transportModels     -I/opt/openfoam170/src/transportModels/incompressible/singlePhaseTransportModel     -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/pisoFoam.o -L/opt/openfoam170/lib/linux64GccDPOpt \
         -lincompressibleRASModels     -lincompressibleLESModels     -lincompressibleTransportModels     -lfiniteVolume     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /opt/openfoam170/applications/bin/linux64GccDPOpt/pisoFoam
/usr/bin/ld: Make/linux64GccDPOpt/pisoFoam.o: undefined reference to symbol 'Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
/usr/bin/ld: note: 'Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)' is defined in DSO /opt/openfoam170/lib/linux64GccDPOpt/openmpi-system/libPstream.so so try adding it to the linker command line
/opt/openfoam170/lib/linux64GccDPOpt/openmpi-system/libPstream.so: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make: *** [/opt/openfoam170/applications/bin/linux64GccDPOpt/pisoFoam] Error 1
Any ideas as to what happened? I read some people suggesting a change in Gcc used in the compilation. Does it work? If yes, then how?
Thank you
Man Yue is offline   Reply With Quote
Old   July 24, 2014, 03:47
Default I have got the answer
anonymous
The material here works for me:
http://www.cfd-online.com/Forums/openfoam-installation/78360-openfoam-1-7-x-fedora-13-a.html
In the file: wmake/rules/linux64Gcc/general, I do
PROJECT_LIBS = -l$(WM_PROJECT) -liberty -ldl $(FOAM_MPI_LIBBIN)/libPstream.so $(FOAM_LIBBIN)/libcompressibleTurbulenceModel.so
, to include both $(FOAM_MPI_LIBBIN)/libPstream.so and $(FOAM_LIBBIN)/libcompressibleTurbulenceModel.so, then in the EXE_LIBS option in the file ./Make/options in the solver directory, I add:
-lincompressibleTurbulenceModel
Then I can compile. For curiousity, I have a question. The drive for this change is for Fedora 13 (and in fact fixed as seen in their discussion), however, I need this change for installing openfoam-1.7.0 in ubuntu 12.04 LTS. Why?
Old   July 24, 2014, 06:09
Default does not recognize turbulence model due to compilation problem
anonymous
After I compile pisoFoam with wmake and run, I found:
--> FOAM FATAL ERROR:
Unknown turbulenceModel type RASModel
Valid turbulenceModel types:
1
(laminar)
I then follow http://www.cfd-online.com/Forums/ope...ype-error.html and http://www.openfoam.org/mantisbt/view.php?id=316#c751
I've changed the link lines in wmake/rules/linux64Gcc/c++ to
LINKLIBSO = $(CC) $(c++FLAGS) -shared -Xlinker --add-needed -Xlinker --no-as-needed
LINKEXE = $(CC) $(c++FLAGS) -Xlinker --add-needed -Xlinker --no-as-needed
and changed the link lines in wmake/rules/linux64Gcc/c to
LINKLIBSO = $(CC) -shared -Xlinker --add-needed -Xlinker --no-as-needed
LINKEXE = $(CC) -Xlinker --add-needed -Xlinker --no-as-needed
and then re-compile pisoFoam with wmake. Problem solved.
However, my way of changing pisoFoam is still problematic, such that the time step does not change correctly. I am still finding a way.
compile, error, openfoam-1.7.0, ubuntu 12.04, wmake
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 7 August 6, 2023 10:12
pisoFoam, pimpleFoam - Fluent user's questions RodriguezFatz OpenFOAM Running, Solving & CFD 0 September 4, 2013 05:26
Error compiling pisoFOAM EVBUCF OpenFOAM Programming & Development 6 January 25, 2012 20:00
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
