Version of OpenFoam
Old   July 21, 2014, 13:37
Default Version of OpenFoam
Javad
javadrasooli is on a distinguished road
Hello every one,
I just want to know how can I find the version of my OpenFoam!
and also want to know should I enter to the special terminal to employ it!
Thank you
javadrasooli is offline   Reply With Quote
Old   September 12, 2014, 14:05
Default How to see the version of the current OpenFOAM installed
Mr. Howlin
Mr.Howlin is on a distinguished road
Hello, javadrasooli.
I was wondering myself the same question. And, for the case you still don't know the answer, I've figured out a way to do that.
On the prompt command, you should run a case, e.g cavity.
start typing blockMesh and then enter.
After that, scrow up with the mouse until you see the header of OpenFOAM.
Well, on this header there will be the current version of the package installed on
your computer.
I hope this help..
bye..
Mr.Howlin is offline   Reply With Quote
Old   September 13, 2014, 16:12
Retired Super Moderator
Bruno Santos
Greetings to all!
For future reference, the following wiki page might come in handy, in terms of how to use the shell/terminal and how to deal with one or more versions of OpenFOAM from said shell/terminal: http://openfoamwiki.net/index.php/In...with_the_Shell
Best regards,
Bruno
Old   June 3, 2019, 07:01
benoit favier
Benben is on a distinguished road
Try the command line:
apt-cache policy openfoam6
Benben is offline   Reply With Quote
Old   March 16, 2022, 04:46
eric1024 is on a distinguished road
Hello everyone,
Try the command below
icoFoam -help
The version information should be displayed. For example,
  1. OpenFOAMv2106
    Usage: icoFoam [OPTIONS]
    Options:
      -case <dir>       Specify case directory to use (instead of cwd)
      -decomposeParDict <file>
                        Use specified file for decomposePar dictionary
      -dry-run          Check case set-up only using a single time step
      -dry-run-write    Check case set-up and write only using a single time step
      -parallel         Run in parallel
      -postProcess      Execute functionObjects only
      -doc              Display documentation in browser
      -help             Display short help and exit
      -help-full        Display full help and exit
    Transient solver for incompressible, laminar flow of Newtonian fluids.
    Using: OpenFOAM-2106 (2106) - visit www.openfoam.com
  2. OpenFOAM8
    options:
      -case <dir>       specify alternate case directory, default is the cwd
      -fileHandler <handler>
                        override the fileHandler
      -hostRoots <(((host1 dir1) .. (hostN dirN))>
                        slave root directories (per host) for distributed running
      -libs <(lib1 .. libN)>
                        pre-load libraries
      -listFunctionObjects
                        List functionObjects
      -listRegisteredSwitches
                        List switches registered for run-time modification
      -listScalarBCs    List scalar field boundary conditions (fvPatchField<scalar>)
      -listSwitches     List switches declared in libraries but not set in
                        etc/controlDict
      -listUnsetSwitches
                        etc/controlDict
      -listVectorBCs    List vector field boundary conditions (fvPatchField<vector>)
      -noFunctionObjects
                        do not execute functionObjects
      -parallel         run in parallel
      -roots <(dir1 .. dirN)>
                        slave root directories for distributed running
      -srcDoc           display source code in browser
      -doc              display application documentation in browser
      -help             print the usage
    Using: OpenFOAM-8 (see https://openfoam.org)
I hope this could be helpful.
eric1024 is offline   Reply With Quote
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Which Linux version best for OpenFOAM? yewebis OpenFOAM 7 June 10, 2009 07:31
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 19:06
OpenFOAM Version 1.2 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 22, 2005 18:42
