[Other] openFoam 2.3.x for windows from cfdsupport.com
Like Tree2Likes
Old   April 23, 2015, 08:07
Algis Dziugys
Algis is on a distinguished road
Originally Posted by andras View Post
1) Start "OpenFOAM-2.3.x-reg.bat" with admin rights (right click -> Run as Administrator). The install instructions from cfdsupport.com are missing this crucial step. Admin rights are needed for the registry key "HKLM\SYSTEM\CurrentControlSet\Control\SessionMana ger\kernel".
Is it correct to use "SessionManager" while originally MS Windows 7 registers contains "Session Manager" (with space)?
Regards,
Algis
Algis is offline   Reply With Quote
Old   October 21, 2015, 14:42
Default Some problems fixed by changing windows account name consisting of two words
  #42
lancelott is on a distinguished road
Dear Foamers,
I tried to install the OpenFOAM package 15.06 provided by CFD Support on my Win 7 Computer that I updated to Win 10 recently. Using Win 7 and Win 10 I had problems with some commands mentioned in this thread (e.g. "paraFoam", "paraview" didn't work [see Ananthakrishnan]). I figured out in my case the problem was my windows account name. It consisted of two words (First and last name) leadind to automatically created folder-/filenames in OpenFOAM containing a blank. Since OpenFOAM doesn't like blanks I tried the following:
1) Uninstall openFOAM and all related programs
(I also removed the C++ 2010 Redistributable Packages and Microsoft MPI --> solves the newer version problem of saucisse volante)
2) Change your windows account name so it doesn't contain a space (I even created a completely new "CFD-account")
3) Reinstall the OpenFOAM Package with all components
Since then everything works well. Hope that helps someone.
Best regards from Heidelberg, Germany
lancelott is offline   Reply With Quote
Old   January 8, 2016, 21:04
BlnPhoenix is on a distinguished road
Will there be an update with the new OpenFoam 3.0 code to this package from cfdsupport.com?
BlnPhoenix is offline   Reply With Quote
Old   March 15, 2016, 16:51
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am using the cfd support openFoam from the windows command prompt (ie not from cygwin). Everything works fine, but for parallel processing. I tried quite a few setup for MS-MPI but it looks like there is some conflict with another MPI installation as I am getting these kinds of errors:
Aborting: mpi appplication on POSEIDON is unable to connect to the smpd manager on (null):60026 error 1722
Aborting: mpi appplication on POSEIDON is unable to connect to the smpd manager on (null):60025 error 1722
job aborted:
[ranks] message
[1] fatal error
Fatal error in MPI_Init: Other MPI error, error stack:
MPI_Init(argc_p=0x000000000023FE60, argv_p=0x000000000023FE68) failed
Der RPC-Server ist nicht verfügbar.  (errno 1722)
job aborted:
[ranks] message
[0] fatal error
Any idea?
julien.decharentenay is offline   Reply With Quote
Old   May 18, 2016, 06:09
Default OpenFOAM for Windows 16.06 released!
  #45
Paritosh Vasava
vasava will become famous soon enough
The new package includes fully functional and natively compiled OpenFOAM-3.0.x.
http://www.cfdsupport.com/openfoam-for-windows.html
vasava is offline   Reply With Quote
openfoam, windows
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] OpenFOAM 2.3.x for Mac at GitHub ajmas OpenFOAM Installation 2 April 20, 2015 17:23
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 samiam1000 OpenFOAM Installation 4 January 26, 2015 03:44
