OpenFoam 2.3.0 installation on SUSE Linux Enterprise Server 11 |
AI
Rep Power: 12 ![]() |
Can anyone provide a list of instructions on installing OpenFoam 2.3.0 on a cluster running SUSE Linux Enterprise Server 11 (x86_64) operating system?
We tried the instructions for OpenSUSE listed on OpenFoam.org, but it was unable to build OpenFOAM executables. Updating the operating system is not an option at this point. Thank you in advance for your help. |
#2 | |
Derek Mitchell
Rep Power: 13 ![]() |
are you using gcc 4.7? thats a requirement for 2.3
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET |
#3 | |
AI
Its currently running gcc (SUSE Linux) 4.3.4. If it is going to be doable with gcc 4.7, I'll try to update it. Is this my main problem? I appreciate any help on this issue. Thanks. |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings to all!
A compatibility matrix on GCC to OpenFOAM versions is being kept here: http://openfoamwiki.net/index.php/In...ibility_Matrix @sherif35: Yes, GCC 4.3.4 is too old for OpenFOAM 2.3. Either you will need to ask the system administrator to install a more recent GCC version or try following these instructions: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10 - they are meant for CentOS 5.10, so try starting at the step #5. Best regards, Bruno
AI
Thank you Bruno, I'll give it a try.
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 05:11 |
How to install OpenFOAM 2.3.0 into a cluster based on centOS linux | eddykendo | OpenFOAM Installation | 1 | June 16, 2014 08:52 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
