bash: /opt/openfoam230/etc/bashrc: No such file or directory
Old   July 1, 2014, 10:50
Default bash: /opt/openfoam230/etc/bashrc: No such file or directory
Michael Kruger
mich_K is on a distinguished road
I am running ubuntu 14.04
I installed OpenFOAM in my home directory and it seems to be running fine. However when I open a new terminal I get the following error:
The directory referred to in the error is in fact empty.
Has anyone had this problem before?
Thanks in advance.
mich_K is offline   Reply With Quote
Old   July 17, 2014, 15:28
cdm
cdm is on a distinguished road
Not sure if you solved your troubles yet. Sounds like you are trying to source the bashrc file but it's pointing to the wrong directory.
Open up your ~/.bashrc file and check the last line. There should be a line like
source /opt/openfoam230/etc/bashrc
Just change it to point to the correct location. If it's installed in your home directory as you say then it should be:
source $HOME/openfoam230/etc/bashrc
However, a better approach would be to create an alias to source the OF bashrc only when you want to use it (that way the environment variables aren't always loaded and if you decide to add a newer version later there won't be conflicts).
You can change the above line to something like this:
alias foam230='source $HOME/openfoam230/etc/bashrc'
Then type in foam230 in the terminal when you plan on using OpenFOAM.
cdm is offline   Reply With Quote
Old   July 17, 2014, 15:44
Michael Kruger
Thank you cdm. I havent yet so this is very helpful!
Old   July 17, 2014, 15:56
cdm
Glad I could help. Let me know if you have any troubles with the above.
error, installation of open foam
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
