[OpenFOAM.org] Paraview not found when installing OpenFoam to Ubuntu 14.04 |
September 28, 2014, 11:15 |
#21 |
Alessandro
Rep Power: 17 |
...well, not all Sunday tests are not going fine, Bruno!
I moved everything to my local folder, but the error on PV build remained the same... I post here the logfiles for sharing. Suggestions are still welcome! Thanks again & again, Alex |
September 28, 2014, 12:09 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Alex,
I've looked a bit into Mint 17 and it seems to be derived from Ubuntu 14.04. The step #9 at http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 states these commands: Code:
#First make very certain that the correct Qt version is being used, by running this command: export QT_SELECT=qt4 #this will take a while... somewhere between 30 minutes to 2 hours or more ./makeParaView4 > log.makePV 2>&1 As for the files you've attached, they are giving the output of the feature discovery procedure, which can be rather misleading as it's looking for every feature the hard way, hence so many errors. But since you didn't provide "log.makePV", I can't make an assessment as to what happened. Best regards, Bruno |
September 28, 2014, 12:46 |
#23 |
Alessandro
Rep Power: 17 |
Hi Bruno,
yeah, you're right!! I read them carefully, but seems they will soon guide me out of the way. But here's the logfile you need! Totally novice, but it seems complaining about a missing OpenGL. Anyway Code:
glxinfo | grep "OpenGL version" Code:
OpenGL version string: 3.0 Mesa 10.1.0 Code:
echo $OPENGL_gl_LIBRARY OPENGL_INCLUDE_DIR Code:
OPENGL_INCLUDE_DIR What about? Thank you!!! Ale |
September 28, 2014, 12:54 |
#24 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
You need to properly install the graphics card drivers for the graphics card in your machine. Either that, or install the "mesa-dev" package... Best regards, Bruno |
September 29, 2014, 05:28 |
Building ParaView 4.1.0 and OF 2.3.x on Linux Mint 17 Cinnamon
#25 |
Alessandro
Rep Power: 17 |
Hi Bruno,
and thanks a lot for all your patience and good suggestions! Finally I managed to build everything on Mint 17. And I know that you should deserve something better than this, but in order to thank you for all your support last Sunday I close our discussion with some points that could be useful for others Mint users. Essentially if you like the polished look of Mint 17 Cinnamon and you want to easily build OF-2.3.x and ParaView 4.1.0 just follows the guide for Ubuntu 14.04 by Bruno but after step 2 remember to add: Code:
apt-get install libqtwebkit-dev [Before this key step I also tried to install libgl1-mesa-dev libglew-dev libglm-dev but they did not solve the issue.] ...Sounds like advertising, but I am pretty happy of my nightly build! Thanks again & best regards, Alex |
October 4, 2014, 13:30 |
#26 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
Many thanks for sharing your findings! I've added the instruction to also install "libqtwebkit-dev" just in case Ubuntu 14.04 decides to change a bit the dependencies. Best regards, Bruno
October 6, 2014, 04:51 |
#27 |
Alessandro
Rep Power: 17 |
Hi Bruno,
that was definitely the least I could do for our community, since in many cases I found out quick solutions following your suggestions! Glad to know that I was able to give my contribution somehow! Best regards and thanks again, Alex |
October 6, 2014, 08:17 |
#28 | |
Thomas
Rep Power: 16 |
Hey,
I am also having trouble installing ParaView 4.1.0, and they are very similar to AleDR's. System is Linux Mint 17 (based on Ubuntu 14.04) aswell. Been following the wiki guide to the letter, but having trouble with OpenGL with the ParaView installation. I did not notice that this installation did not work, so I have installed the remaining software already. I tried installing the packages suggested by AleDR aswell, but they did not fix the problem. I seem to have a different version of Mesa though. Quote:
Thomas |
October 7, 2014, 16:27 |
#29 |
Bruno Santos
Rep Power: 128 |
Greetings Thomas,
Looks like Mesa doesn't have the necessary OpenGL implementations that ParaView needs. But... have you installed the correct drivers for the graphics cards in your machine? Because the Mesa packages should only be used as a last resort. Best regards, Bruno
October 8, 2014, 05:08 |
#30 | |
Thomas
Rep Power: 16 |
Hi Bruno,
I am very new to Linux, so bear with me. I have now switched from Nouveau driver back to Nvidia. I originally had Nvidia drivers, but upon discovering that "direct rendering" was not working I switched to Nouveau. Today I installed a new nvidia driver and now direct rendering is functioning. This then gives, for glxinfo: Quote:
Thank you for taking the time to assist me! Thomas |
October 9, 2014, 06:44 |
Problem with paraFoam
#31 |
Javad
Rep Power: 12 |
Hello Bruno,
I have the same problem. I installed paraView and used it before. Now it is also workin with command : paraFoam -builtin . But in the output messages, some errors are appeared: Code:
ERROR: In /home/dell-2014-d/OpenFOAM/ThirdParty-2.3.0/ParaView-4.1.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 8453 vtkPOpenFOAMReader (0x2e99e40): /home/dell-2014-d/dell-2014-d.foam contains no timestep data. ERROR: In /home/dell-2014-d/OpenFOAM/ThirdParty-2.3.0/ParaView-4.1.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x2ea2860): Algorithm vtkPOpenFOAMReader(0x2e99e40) returned failure for request: vtkInformation (0x2eb0b40) Debug: Off Modified Time: 89162 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 Best regards, Javad Last edited by wyldckat; October 11, 2014 at 14:55. |
October 11, 2014, 15:43 |
#32 | ||
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Thomas: Quote:
sudo apt-get remove mesa-dev --------------------- @Javad: If you look at the specific part of the error message: Quote:
mkdir -p $FOAM_RUN cp -r $FOAM_TUTORIALS $FOAM_RUN cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity blockMesh icoFoam paraFoam -builtin Best regards, Bruno |
October 12, 2014, 04:49 |
#33 | |
Thomas
Rep Power: 16 |
Hi Bruno,
Removing mesa-common-dev did not work. i did however get it installed. I googled the error message I got and ended up adding the lines Quote:
Anyways, thank you for taking the time to help me! Cheers, Thomas |
November 14, 2014, 20:24 |
Error installing openFoam 2.3
#34 |
Nat
Rep Power: 13 |
Hi Bruno,
I'm trying to install openFoam 2.3 and 2.1.1 on Ubuntu 14.04 but I run into problems with both. And I think my problems (both concerned with ParaView) are different from the ones in this post. I start with the problem installing openFoam 2.3 on Ubuntu 14.04: I followed by word the instructions here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 I've got an error in step 8 around here (attached log file): Code:
make[1]: Leaving directory `/home/natasa/OpenFOAM/ThirdParty-2.3.0/scotch_6.0.0/src/libscotchmetis' + make prefix=/home/natasa/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/scotch_6.0.0 libdir=/home/natasa/OpenFOAM/ThirdParty-2.3.0/platforms/linux64GccDPOpt/lib/openmpi-system includedir=/home/natasa/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/scotch_6.0.0/include/openmpi-system install mkdir /home/natasa/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/scotch_6.0.0/include/openmpi-system cp -f ../bin/[agm]* /home/natasa/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/scotch_6.0.0/bin cp: cannot stat ‘../bin/[agm]*’: No such file or directory make: [install] Error 1 (ignored) There was no error in step 9. In step 10 I've got numerous errors (attached log file). First one is: Code:
make[3]: `/home/natasa/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/plot3dToFoam' is up to date. vtkPV4Readers.C:35:35: fatal error: vtkDataArraySelection.h: No such file or directory #include "vtkDataArraySelection.h" ^ If I understand right it does not find certain headers belonging to ParaView which I seemingly installed correctly in step 9. openFoam works, but when I try to use paraFoam I get the infamous error message which urges me to build PV4Reader. What should I do to build it properly? Thanks in advance for any help! |
November 14, 2014, 22:35 |
Problem installing openFoam 2.1.1
#35 |
Nat
Rep Power: 13 |
To install 2.1.1 on Ubuntu 14.04 I've followed these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04
I understand that these instructions are for Ubuntu 12.04, but I did not find any for 14.04 so I tried these (and yes, they did not work). I've got error in step 9 when I tried to build ParaView and the first error was: Code:
[ 83%] Building CXX object Plugins/Moments/CMakeFiles/Moments.dir/vtkSMMomentsInstantiator.cxx.o In file included from /home/natasa/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqAnimationScene.cxx:57:0: /home/natasa/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h:75:30: error: calls to overloaded operators cannot appear in a constant-expression ClearAndSelect = Clear | Select ^ make[2]: *** [Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o] Error 1 make[1]: *** [Qt/Core/CMakeFiles/pqCore.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 83%] Building CXX object Plugins/Moments/CMakeFiles/Moments.dir/Moments_Plugin.cxx.o Linking CXX shared library ../../bin/libMoments.so [ 83%] Built target Moments make: *** [all] Error 2 Any thoughts on that? Thanks in advance! |
November 16, 2014, 17:39 |
#36 |
Bruno Santos
Rep Power: 128 |
Greetings Nat and welcome to posting on the forum!
For the installation of OpenFOAM 2.3.0, something definitely went wrong while building ParaView 4.1.0, because that error message you got clearly states that a relevant file from ParaView's installation is missing. If you run this command: Code:
ls -l $HOME/OpenFOAM/ThirdParty-2.3.0/ParaView-4.1.0/include/paraview-4.1 Either way, if you could attach the compressed file of "log.makePV", that would make it easier to diagnose. For the installation of OpenFOAM 2.1.1, see the fix made in the step #8 from this page: http://openfoamwiki.net/index.php/In...dora#Fedora_18 - section "Fedora 18". It's the lines before running "makeParaView" that fix the problem you're seeing on Ubuntu. Best regards, Bruno
November 17, 2014, 20:47 |
#37 |
Nat
Rep Power: 13 |
Hi Bruno,
Thanks for the fast replay and the very kind welcome I wanted to attach the log.makePV (for 2.3.0) but since it was larger than the allowed limit (in compressed format) and I was just lazy, finally I did not do it. Please find it attached now in two parts. As you wrote, there is no such directory as $HOME/OpenFOAM/ThirdParty-2.3.0/ParaView-4.1.0/include/paraview-4.1 About the installation of the 2.1.1: I went to the link, performed the action requested and now it works. Thank you! Last edited by Nat9; November 17, 2014 at 22:25. Reason: typo |
November 18, 2014, 17:51 |
#38 |
Bruno Santos
Rep Power: 128 |
Hi Nat,
Well, this is somewhat odd... There is no indication of a failure during the build process of ParaView 4.1.0 in OpenFOAM 2.3.0. Everything was built and installed without any problems. The folder mentioned in your log file "log.make" has this path: Code:
$HOME/OpenFOAM/ThirdParty-2.3.0/ParaView-4.1.0/include/paraview-4.1 Code:
$HOME/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0/include/paraview-4.1 Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake > log.make 2>&1 Best regards, Bruno |
November 20, 2014, 23:42 |
#39 |
Nat
Rep Power: 13 |
First of all thank you for your kind help Bruno!!
Second I have to admit it was all my fault with OF2.3. When I read your last post I remembered something. Some time ago when I installed OF2.3 I did all the steps by word (at least I think) except the one to check for errors. So I did not realized there was an error installing paraView. When I tried to use paraFoam and I got the message about installing PV4Reader, I tried to do so, but I got some error message about not finding paraView at some location. Since I installed paraView long before from the ubuntu software center, I thought that the problem is in the environmental variables, so I started to change them and I completely forget that. When I read your post I remembered, so I downloaded everything again, and went through all the steps. This time checking for errors. There was none. It works perfectly. Now both 2.3 and 2.1.1 too. Thanks again and sorry for wasting your time with something that stupid |
November 21, 2014, 11:18 |
Paraview and Linux Mint 17
#40 |
Mike Hersee
Rep Power: 12 |
Hi, I'm also struggling with an installation of OpenFOAM 2.3.0 on Linux Mint 17.
I originally had a problem where it couldn't reach an IP address it needed to in order to download all the source. That seemed to fix itself without changing anything when I ran it later. However, I had mistakenly assumed it had created paraview correctly when it didn't specifically throw up an error on the screen and I didn't check the log.makepv file at the time. When I tried to run paraFOAM in the first tutorial it came up with the line, 'FATAL ERROR: ParaView reader module libraries do not exist...(etc)' I followed those instructions but it didn't work, and I have reviewed the other messages where paraview has not worked and I have tried what seemed to be relevant commands, which have also not worked. I'm pretty certain I followed the instructions for installing OpenFOAM in Ubuntu 14.04 to the letter, by copying and pasting the commands directly from the instructions, although it's possible I've made a mistake. I'd be grateful for any guidance. I've attached the log.makepv file. It looks to me as though something to do with VTK isn't right, but I've no idea how to fix it, and I don't know if that's the fatal error at the root of it. Mike |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 15:30 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 | p0kerus | OpenFOAM Installation | 2 | December 2, 2014 08:54 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
