May 23, 2014, 09:17 |
Is OpenFOAM available for Fedora 20?
Peetak Mitra
Rep Power: 14 |
I am trying to install OpenFOAM 2.3.x, on my Fedora 20 OS but it seems I cannot install the Paraview, Scotch and OpenFOAM packages using rpm. It says page does not exist, when I try to do that in the terminal. The link which I am following is as below. http://www.openfoam.org/download/fedora.php Even the link doesnt talk about the newer version of Fedora. The last update is for Fedora 19. So should I find a way to revert back to Fedora 19 or am I looking in the wrong direction. I know I can also do it from the source itself but I am not very sure about my linux skills hence would like to take it a bit easy with the OS for which everything is spelt out. Thanks, Peetak |
May 24, 2014, 04:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Peetak,
Fedora is currently not supported as RPM packages for OpenFOAM 2.3.0. That page is currently being kept only for possibly bring it back in the future. You can check this yourself, if you try to reach that page through the menu links, starting from the main website www.openfoam.org Therefore, you'll have to install from source code. Instructions written by the community (well, in this case, by me ) are available here: http://openfoamwiki.net/index.php/In...dora#Fedora_20 (since 2nd of March 2014) Best regards, Bruno
May 24, 2014, 05:03 |
Peetak Mitra
Rep Power: 14 |
Dear Bruno,
Thank you for your reply and thanks for the link. I am sure it will get the job done. If there are any issues still, I hope you will guide me with that. Regards, Peetak |
fedora20, installation of open foam, openfoam 2.1.x |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 04:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 08:14 |
