OpenFOAM version 2.3.0 RPM on SuSE linux 12.2
Old   May 22, 2014, 14:11
Default OpenFOAM version 2.3.0 RPM on SuSE linux 12.2
Gautami Erukulla
gautami is on a distinguished road
Dear All,
I am trying to install OpenFOAM version 2.3.0 on SuSE linux 12.2.
I am following the steps given in the link below:
http://www.openfoam.org/download/suse.php
As I come to this step:
download and install Scotch, Paraview and OpenFOAM for 64 bit.
and execute the following command
sudo rpm -i http://www.openfoam.org/download/sus...0-1.x86_64.rpm
I get an error:
curl: (22) The requested URL returned error: 403
error: skipping http://www.openfoam.org/download/sus...0-1.x86_64.rpm - transfer failed
In the original command I changed the SuSE version from 12.3 to 12.2.
Kindly can somebody help me with this issue.
Thank you
gautami is offline   Reply With Quote
Old   May 24, 2014, 04:26
Retired Super Moderator
Bruno Santos
Greetings Gautami,
Quoting from that page:
Originally Posted by www.openfoam.org/download/suse.php
Version 2.3.0, SuSE 12.3 released 17/02/14
SuSE Versions
OpenFOAM and Paraview are currently available for version 12.3 of SuSE.
In other words: SuSE 12.2 is not supported as RPM packages.
You'll have to install from source code. You can try the instructions provided here: http://openfoamwiki.net/index.php/In...#openSUSE_12.3
Best regards,
Bruno
Old   May 25, 2014, 12:37
Gautami Erukulla
Hello Bruno,
Thank you very much for your reply.
I have installed OpenFOAM version 2.2.0 on SuSe 12.2 (RPM) package and it works.
Regards,
Gautami.
[OpenFOAM.org] OpenFOAM 2.1.1 installation on openSUSE 12.2 32 bit saturn_53 OpenFOAM Installation 13 February 1, 2015 05:17
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 10:07
OpenFOAM Version 1.4 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 April 11, 2007 19:56
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 19:06
