foam-extend-3.0 installation in Ubuntu 14.04
Old   May 16, 2014, 10:52
Default foam-extend-3.0 installation in Ubuntu 14.04
ok
Maimouna is on a distinguished road
Dear OF users,
how could I install foam-extend-3.0 in ubuntu 14.04. I was working in that version of OpenFOAM but I updated ubuntu from 13.10 to 14.04 and the old foam-extend-3.0 is not working in ubuntu 14.04. It gives me such this error for example for cavity test case
owner@owner-HP-Pavilion-Sleekbook-15-PC:~/foam/foam-extend-3.0/tutorials/incompressible/icoFoam/cavity$ blockMesh
blockMesh: error while loading shared libraries: libmpi.so.0: cannot open shared object file: No such file or directory
How can I solve this problem?
Maimouna is offline   Reply With Quote
Old   May 16, 2014, 12:16
blacksquirrel is on a distinguished road
Hi Maimouna,
here you can find instructions on how to install extend-3.0 from source code for your ubuntu 14.04:
http://wikki.gridcore.se/foam-extend/download
If unsure, what they mean in the first instruction, the OF 13.10 instruction is easier to understand and it should work nearly the same for Ubuntu 14.04:
http://openfoamwiki.net/index.php/In...end-3.0/Ubuntu
Regards
Squirrel
blacksquirrel is offline   Reply With Quote
Old   May 16, 2014, 12:23
ok
Dear Squirrel,
many thanks for your help.
Regards
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
