Error when generating pdfLatex using Doxygen
Old   April 23, 2014, 12:06
Smile Error when generating pdfLatex using Doxygen
Felix_Lee is on a distinguished road
Dear everyone,
It is my first posting in cfd-online forum. Thanks for all kind reply in advance.
I want to generate Doxygen document of OpenFOAM. First, I generated latex file using Doxygen. Then I use command make pdf to get pdf output from the latex output. But this step didn't success. The error info :
pdfTeX warning: pdflatex (file ./a01981_a63dde5ed963ede3c2c7a3681dd742999_icgra
ph.pdf): PDF inclusion: multiple pdfs with page group included in a single page.
And I don't know what does it mean. Anyone can help me?
Felix_Lee is offline   Reply With Quote
Old   April 25, 2014, 15:39
Retired Super Moderator
Bruno Santos
Greetings Felix_Lee,
I have to say that last time I tried to generate a LaTeX based PDF file from the OpenFOAM code documentation was a long time ago. And the conclusion at the time was that it was a very lousy format for OpenFOAM's code documentation, simply because the formatting scheme used is not applicable to paper format. It is designed for web-browsing only.
The error seems to indicate that there is an issue with overlapping pages or that a graph is too large to fit in a single page.
If you Google the error message:
you'll find several answers on this topic.
Looks like it is as what the message states at the beginning, namely:
pdfTeX warning
as in: it's just a warning. There was a new feature introduced into the PDF format by Adobe and the warning is possibly a bug. A fix seems to be to use pdf2ps and ps2pdf to convert the PDF file to PS and then back to PDF again.
Best regards,
Bruno
Old   April 29, 2014, 02:21
Dear Bruno,
You said the formatting scheme is designed for web browsing only.I think you are right. And I will use the html files only. It's enough for using.
Thank you for your answer.
Best regards,
Felix
doxygen, pdflatex
run Doxygen offline anishtain4 OpenFOAM 8 November 27, 2014 10:36
Gambit vs. Ansys workbench mesh generating sanlee39 Main CFD Forum 2 April 8, 2013 07:09
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
Could Somebody Please Explain Doxygen to me dandalf OpenFOAM 0 March 24, 2011 10:35
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 04:16
