an error found in Installation/Linux/foam-extend-3.0 at openfoamwiki.net
Old   April 8, 2014, 00:48
Smile an error found in Installation/Linux/foam-extend-3.0 at openfoamwiki.net
xuhe-openfoam
bieshuxuhe is on a distinguished road
hello !
I found an small error in http://openfoamwiki.net/index.php/In...oam-extend-3.0
there is
Compile
Set the environment variables
On bash (if unsure whether you are using bash, run "echo $SHELL"):
cd ~/foam/foam-extend-3.0 <>
source etc/cshrc
On csh:
source etc/cshrc
the red is wrong ! it should be "source etc/bashrc" .
best wishes!
xuhe
bieshuxuhe is offline   Reply With Quote
Old   April 8, 2014, 09:40
Retired Super Moderator
Bruno Santos
Greetings xuhe,
Many thanks for reporting! I've fixed the error on the wiki page.
But you do know that since it's a wiki, you could register yourself on the wiki, edit the page and fix the error yourself!
Best regards,
Bruno
Old   April 8, 2014, 22:44
xuhe-openfoam
ok , thank you. it sounds great !
i will register myself on the wiki and try .
error
[blockMesh] could anyone post a simple cylinder mesh guilherme OpenFOAM Meshing & Mesh Conversion 46 October 23, 2020 18:18
Negative Cell Volume with moveDyMEngineMesh with Foam Extend 3.0 RJ87 OpenFOAM 2 May 8, 2014 13:13
[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 mnobrega OpenFOAM Community Contributions 6 April 1, 2014 02:47
problem in running icoFoam Alucard OpenFOAM 2 March 17, 2012 10:01
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
