Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 |
March 15, 2014, 05:54 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Sangamesh,
OK, check if the file "/home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/scotch-5.1.10b.tar.gz" does really exist in your file system, by running: Code:
ls -l /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/scotch-5.1.10b.tar.gz Code:
tar -tf /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/scotch-5.1.10b.tar.gz As for the other error during the build of OpenFOAM: indeed, it's very strange that it happens and it does seem to be related with the problem with Scotch. Next I'm going to look into building the "DensityBasedTurbo" repository. Best regards, Bruno
March 15, 2014, 08:16 |
#22 |
Bruno Santos
Rep Power: 128 |
OK, I've finally managed to give a good look into building the DensityBasedTurbo toolkit and I've updated the installation instructions at the wiki: http://openfoamwiki.net/index.php/Ex...o#Installation
In your case, since you've already downloaded the source code, use these steps, with the 1.6-ext environment turned on: Code:
cd $FOAM_RUN/.. cd DensityBasedTurbo/src cp -r timeStepping/MRF/* $FOAM_SRC/finiteVolume/cfdTools/general/MRF/ wmake libso $FOAM_SRC/finiteVolume ./Allwmake edit: Instructions for building on foam-extend 3.0 are also available here: http://openfoamwiki.net/index.php/Ex...oam-extend_3.0 Last edited by wyldckat; March 15, 2014 at 08:50. Reason: see "edit:" |
March 17, 2014, 00:06 |
#23 |
Rep Power: 13 |
Hi Bruno,
I managed to install But when I run the case cavity and check for paraFoam then i am getting the following error. Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/run/cavity$ paraFoam created temporary 'cavity.foam' /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: 129: /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: paraview: not found Last edited by sam.ho; March 17, 2014 at 02:45. |
March 17, 2014, 03:00 |
Segmentation fault (core dumped) in transonicMRFDyMFoam
#24 |
Rep Power: 13 |
I followed your procedure to compile DensityBasedTurbo and hopefully it compiled well but when I ran the Axial_Rotor_MRF turorial then i am gettint the following error. Could you please help me to run this case successfully ? Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF$ transonicMRFDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : transonicMRFDyMFoam Date : Mar 17 2014 Time : 12:26:34 Host : BMH301562 PID : 16550 Case : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh staticFvMesh Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Segmentation fault (core dumped) Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext Exec : blockMesh Date : Mar 17 2014 Time : 11:48:51 Host : BMH301562 PID : 15860 Case : /home/sml5kor/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/sml5kor/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 136 Number of boundary faces : 112 Number of defined boundary faces : 112 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points with scale 0.001 Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty There are no merge patch pairs Adding cell zones 0 rotor Writing cell zones as cellSets Writing polyMesh End Code:
sml5kor@BMH301562:~/OpenFOAM/sml5kor-1.6-ext/DensityBasedTurbo/run/Axial_Rotor_MRF$ paraFoam created temporary 'Axial_Rotor_MRF.foam' /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: 129: /home/sml5kor/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: paraview: not found |
March 22, 2014, 07:17 |
#25 |
Bruno Santos
Rep Power: 128 |
Hi sam.ho,
I thought that the issue with ParaView was already solved, but apparently it's not. Edit the file "/etc/apt/sources.list" once again and modify it to this: Code:
deb http://archive.ubuntu.com/ubuntu/ precise main universe deb http://security.ubuntu.com/ubuntu/ precise-security main universe deb http://archive.ubuntu.com/ubuntu/ precise-updates main universe Then run: Code:
sudo apt-get update
In addition, if you already have FOAM-Extend 3.0 working as intended, then you can also build the DensityBasedTurbo toolkit in this version, as long as you follow the dedicated instructions for it: http://openfoamwiki.net/index.php/Ex...oam-extend_3.0 And for this version, you can use the latest swak4Foam 0.3.0. Best regards, Bruno
March 24, 2014, 00:43 |
#26 | |
Rep Power: 13 |
My source.list contains the following Code:
deb http://archive.ubuntu.com/ubuntu precise main universe deb-src http://archive.ubuntu.com/ubuntu precise main universe deb http://security.ubuntu.com/ubuntu/ precise-security main universe deb http://archive.ubuntu.com/ubuntu/ precise-updates main universe I obtained following on the terminal. Code:
sml5kor@BMH301562:~$ sudo gedit /etc/apt/sources.list [sudo] password for sml5kor: sml5kor@BMH301562:~$ sudo apt-get update Err http://security.ubuntu.com precise-security Release.gpg Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise Release.gpg Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://www.openfoam.org precise Release.gpg Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates Release.gpg Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Ign http://www.openfoam.org precise Release Ign http://archive.ubuntu.com precise Release Ign http://security.ubuntu.com precise-security Release Ign http://archive.ubuntu.com precise-updates Release Ign http://www.openfoam.org precise/main TranslationIndex Ign http://security.ubuntu.com precise-security/main TranslationIndex Ign http://security.ubuntu.com precise-security/universe TranslationIndex Ign http://archive.ubuntu.com precise/main TranslationIndex Ign http://archive.ubuntu.com precise/universe TranslationIndex Err http://www.openfoam.org precise/main amd64 Packages Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) Ign http://archive.ubuntu.com precise-updates/main TranslationIndex Err http://www.openfoam.org precise/main i386 Packages Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) Ign http://archive.ubuntu.com precise-updates/universe TranslationIndex Err http://www.openfoam.org precise/main Translation-en_IN Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) Err http://www.openfoam.org precise/main Translation-en Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/main amd64 Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/universe amd64 Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/main i386 Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/universe i386 Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/main Translation-en_IN Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/main Translation-en Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/universe Translation-en_IN Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://security.ubuntu.com precise-security/universe Translation-en Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/main Sources Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/universe Sources Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/main amd64 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/universe amd64 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/main i386 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/universe i386 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/main amd64 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/universe amd64 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/main i386 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/universe i386 Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/main Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/main Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/universe Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise/universe Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/main Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/main Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/universe Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) Err http://archive.ubuntu.com precise-updates/universe Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/Release.gpg Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/Release.gpg Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/Release.gpg Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/precise/Release.gpg Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/precise/main/binary-amd64/Packages Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/precise/main/binary-i386/Packages Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/main/source/Sources Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/universe/source/Sources Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/main/binary-amd64/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/universe/binary-amd64/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/main/binary-i386/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/universe/binary-i386/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/main/binary-amd64/Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/universe/binary-amd64/Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/main/binary-i386/Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/universe/binary-i386/Packages Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/main/binary-amd64/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/universe/binary-amd64/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/main/binary-i386/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/universe/binary-i386/Packages Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/precise/main/i18n/Translation-en_IN Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/precise/main/i18n/Translation-en Something wicked happened resolving 'www.openfoam.org:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/main/i18n/Translation-en_IN Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/main/i18n/Translation-en Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/universe/i18n/Translation-en_IN Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/precise-security/universe/i18n/Translation-en Something wicked happened resolving 'security.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/main/i18n/Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/main/i18n/Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/universe/i18n/Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise/universe/i18n/Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/main/i18n/Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/main/i18n/Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/universe/i18n/Translation-en_IN Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/precise-updates/universe/i18n/Translation-en Something wicked happened resolving 'archive.ubuntu.com:http' (-5 - No address associated with hostname) E: Some index files failed to download. They have been ignored, or old ones used instead. And regarding Axial_Rotor_MRF I have run the case successfully. By compiling simpleFunctionObjects from Breeder-1.6 Thank you bruno |
March 24, 2014, 05:32 |
Installing foam-extend-3.0 from a binary package
#27 |
Sita Drost
Rep Power: 18 |
Hi all,
When installing foam-extend-3.0 from a binary (foam-extend_3.0-1_amd64.precise.deb, on Ubuntu 12.04 LTS, 64 bits), it ends up under /opt/foam. However, the instructions for installing from source tell me to install it under /home/OpenFOAM. Is that a problem? When I run foamInstallationTest, it gives errors, but these might also be caused by something else of course. Best, Sita |
March 24, 2014, 23:41 |
#28 |
Rep Power: 13 |
could you post the error obtained ? |
March 25, 2014, 04:35 |
#29 |
Sita Drost
Rep Power: 18 |
Sure:
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.6.3 Minimum required: 4.3.1 gcc 4.6.3 WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.4 /bin/gzip tar 1.26 /bin/tar icoFoam 3.0 ...am-extend-3.0/applications/bin/linux64GccDPOpt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. The warnings are the same as in my previous OpenFOAM version (1.6-ext), but the critical error is new to me. |
March 25, 2014, 04:41 |
#30 |
Rep Power: 13 |
Hi ,
I feel you need to install it home/OpenFOAM .. Or else you need to change environmental variables. If you change the installation path then you have to change the environmental variables according to it. Regards, Sangamesh Hosur |
March 25, 2014, 09:58 |
#31 |
Sita Drost
Rep Power: 18 |
Thanks, I'll try installing it from source.
Best, Sita 27 Mar 2014 update: I installed foam-extend-3.0 from source, works fine up to now (except that I have to choose a reader every time I open paraFoam) Last edited by sita; March 27, 2014 at 09:03. Reason: update |
March 25, 2014, 23:21 |
#32 | |
Rep Power: 13 |
Paraview issue also got resolved. The problem was the repository. As i cant excess the universal repository in my organization. Hence I used my organization repository to resolve this issue. I thank you very much for support. Regards, Sangamesh Hosur |
March 27, 2014, 07:18 |
fluent3DMeshToFoam problem in OpenFOAM-1.6-ext
#33 |
Rep Power: 13 |
Hi Bruno,
I have installed openFOAM-1.6-ext and truing to convert fluent mesh to OpenFOAM mesh but it gives an error that "command not found" And the same i checked with OpenFOAM-2.3.0. Here its working absolutely fine. What could be the reason ? |
March 28, 2014, 18:35 |
#34 | ||
Bruno Santos
Rep Power: 128 |
Greetings to all!
@sam.ho: Quote:
@sita: Quote:
Best regards, Bruno
March 31, 2014, 04:37 |
#35 | |
Sita Drost
Rep Power: 18 |
I followed the installation instructions on wikki.gridcore.se, starting from the part "Set environment variables", and also occasionally checked the README that came with foam-extend-3.0. The pc that I installed foam-extend-3.0 on is not allowed on sourceforge (company policy...), so I first downloaded foam-extend-3.0_349d2a5.tar.gz using my private pc, then ran foamSystemCheck, and when everything turned out to be OK, I started the installation. Did I skip something essential? Best, Sita |
April 5, 2014, 16:31 |
#36 | |
Bruno Santos
Rep Power: 128 |
Hi Sita,
Best regards, Bruno
