February 21, 2014, 11:01 |
Double Slash bug during BuildingProc.
Rep Power: 13 |
actually I'm trying to build&install OpenFOAM 2.3.0 on a cluster. During the building processes the making script is using "//" behind the defined foamInstall path in the pathcommands to includefiles and libraryfiles (e.g.: -I/mypath//OpenFOAM...InInclude). I changed it to foamInstall=/mypath/$WM_PROJECT ... Software on the system: gcc4.7.3 kernel2.6.32-5-amd64 (debian squeezy) make 3.81 Even if I use the preset-settings this error occurs. I really don't know what I've to do...so I would be really glad if someone could give me a hint. Kind Regards Alex |
February 21, 2014, 12:13 |
I guess between these two slashes environment variable should be (and as it is not set it is expanded to empty string and you've got two slashes). You've provided not enough information for more suggestions. |
February 21, 2014, 12:39 |
Rep Power: 13 |
Hi Alexey,
thank you very much for your answer. Indeed, it is difficult to describe this problem, because I'm new to the cluster. I followed to this proccedings http://levlafayette.com/node/357 . The only changes I made are foamInstall=/hera/fmt/alex/src/$WM_PROJECT and WM_MPLIB=SYSTEMOPENMPI Despite of the double slash the dependency making process seems to be normal. e.g.: -I/hera/fmt/alex/src//OpenFOAM-2.3.0/src/OSspecific/POSIX/lnIncude Hopefully this information will help you to guess the problem. Otherwise please tell me which information do you need? Thank you so far Best regards, Alex |
March 1, 2014, 20:23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Alex: The big question is, where exactly did you define this line : Code:
foamInstall=/hera/fmt/alex/src/$WM_PROJECT If not, then it's the same as this: Code:
foamInstall=/hera/fmt/alex/src/ Best regards, Bruno
March 3, 2014, 05:52 |
Rep Power: 13 |
Hi Bruno,
thank you very much. I changed the line in the etc/bashrc script. The error disappeared after a rebuild from scratch. With a newer gcc version. Up to now it seems to work fine. Best regards, Alex @all thank you for all your suggestions |
bug, building, openfoam |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 04:34 |
New densitybased solver AeroFoam | giulio_romanelli | OpenFOAM Running, Solving & CFD | 48 | January 15, 2016 09:20 |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 07:09 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
