March 5, 2014, 17:40 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Dimitris,
I strongly suggest that you undo the installation of those other packages, by running (as root): Code:
yum remove --nogpgcheck qtwebkit qtwebkit-devel yum remove --nogpgcheck CGAL CGAL-devel Nonetheless, there is a trick to not build the "ImageIO" library in CGAL, which is not needed and is the one to be blamed for the need for "libGL". Follow these steps:
Best regards, Bruno
March 5, 2014, 18:14 |
#22 |
Rep Power: 17 |
Dear Bruno
I 've installed the graphics card drivers to my pc and I have to say it was very laborious process. Given that I started from scratch without any serious background I think or thought that the graphics card drivers installation was closed I attached a screen dump of Nvidia settings Could you please tell what do I have to do with this? Thank once again |
March 5, 2014, 18:42 |
#23 |
Rep Power: 17 |
Hi Bruno
Problem with step 13. See attached file Best regards Dimitris |
March 6, 2014, 16:13 |
#24 |
Bruno Santos
Rep Power: 128 |
Hi Dimitris,
Sorry, I didn't look carefully enough to the first log file you had provided. Please edit the file "makeCGAL" again and change the same block of code to this: Code:
cmake \ -DCMAKE_INSTALL_PREFIX=$CGAL_ARCH_PATH \ -DCMAKE_BUILD_TYPE=Release \ -DWITH_CGAL_ImageIO=OFF \ -DWITH_CGAL_Qt3=OFF \ -DWITH_CGAL_Qt4=OFF \ $configBoost $configGmpMpfr \ $CGAL_SOURCE_DIR \ Either way, with some luck, ParaView can be built without problems, if its build process is able to find automatically the necessary OpenGL libraries. If not, then it would be helpful to know which instructions you've followed to install the NVidia drivers (which seem to be working just fine), so that I can try and figure out where the necessary library files are and to write down the commands necessary for creating symbolic links to them. Best regards, Bruno
March 7, 2014, 13:17 |
#25 |
Rep Power: 17 |
Hi Bruno
I followed the guidelines you gave and I dislodged from step 13 till 16 but I stack to step 17 with the ParaView compilation. Attached you will find the log file with the compilation errors I stand especially to the last error which has to do with this message: Code:
make[2]: *** No rule to make target `/usr/lib64/libGL.so', needed by `lib/libvtkftgl-pv4.1.so.1'. Stop. make[1]: *** [VTK/ThirdParty/ftgl/CMakeFiles/vtkftgl.dir/all] Error 2 Code:
ls -l /usr/lib64/libGL.so Code:
lrwxrwxrwx. 1 root root 14 Jan 21 19:51 /usr/lib64/libGL.so -> libGL.so.1.2.0 Also looking more on this I got Code:
[Dimitris@CFD13 ThirdParty-2.3.0]$ ls -l /usr/lib64/libGL* lrwxrwxrwx. 1 root root 16 Feb 19 15:54 /usr/lib64/libGLEW.so.1.5 -> libGLEW.so.1.5.5 -rwxr-xr-x. 1 root root 382160 Oct 5 2010 /usr/lib64/libGLEW.so.1.5.5 -rw-r--r--. 1 root root 656 Jan 21 19:42 /usr/lib64/libGL.la lrwxrwxrwx. 1 root root 14 Jan 21 19:51 /usr/lib64/libGL.so -> libGL.so.1.2.0 lrwxrwxrwx. 1 root root 15 Jan 21 19:42 /usr/lib64/libGL.so.1 -> libGL.so.331.38 -rwxr-xr-x. 1 root root 1165176 Jan 21 19:42 /usr/lib64/libGL.so.331.38 lrwxrwxrwx. 1 root root 15 Jan 21 19:51 /usr/lib64/libGLU.so -> libGLU.so.1.3.1 lrwxrwxrwx. 1 root root 15 Jan 21 18:52 /usr/lib64/libGLU.so.1 -> libGLU.so.1.3.1 -rwxr-xr-x. 1 root root 525792 Dec 13 12:42 /usr/lib64/libGLU.so.1.3.1 Code:
[Dimitris@CFD13 ThirdParty-2.3.0]$ sudo find / -name libGL.so.1.2.0 /usr/lib/libGL.so.1.2.0 Code:
[Dimitris@CFD13 ThirdParty-2.3.0]$ sudo find / -name libGL.so /home/Dimitris/Gambit2.4.6/Fluent.Inc/gambit2.4.6/lnamd64/so_post/libGL.so /usr/lib/libGL.so /usr/lib64/libGL.so Could it be overcame ? Looking for your answer. Best Regards Dimitris |
March 7, 2014, 15:36 |
#26 |
Bruno Santos
Rep Power: 128 |
Hi Dimitris,
Nice! Many thanks for the thorough searching and reporting you've done, because this makes it a lot easier to provide the solution! As root, run: Code:
unlink /usr/lib64/libGL.so ln -s /usr/lib64/libGL.so.1 /usr/lib64/libGL.so Side note: The file "/usr/lib/libGL.so" is for 32 bit. Now you can exit from root and try to build ParaView once again! Best regards, Bruno
March 8, 2014, 10:43 |
#27 |
Rep Power: 17 |
Hi Bruno
All are working fine!! Thanks once again. Your assistance is very precious in general for the forum. Keep up the good work!!! Best regards Dimitris |
paraview, qmake, rhel6 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 14:24 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 03:32 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
Building Paraview, Redhat | PaulK | OpenFOAM Installation | 6 | October 12, 2009 14:01 |
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit | sek | ParaView | 4 | August 17, 2006 17:26 |
