[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch |
February 4, 2015, 00:00 |
#141 |
Andre Mas
Rep Power: 11 |
I have created a fork here, with the patches applied:
https://github.com/ajmas/OpenFOAM-2....-forum-patched That eliminates one step. I did also patch the etc/bashrc file to handle paths with spaces in it, but other tools also fail with spaces in the the path, so best avoid spaces in path names. Edit: if you have changes with regards to the Mac code, maybe the best thing to do is make a fork and the submit a pull request? Changes should not break the Linux build. Last edited by ajmas; February 5, 2015 at 17:11. |
February 5, 2015, 16:38 |
#142 | |
Jonathan
Rep Power: 11 |
It would be helpful to include the changes recommended in comment #82 of this thread. I suggest modifying readme.html to indicate how this branch is different from the main branch. I am making progress on working out my own installation. Once I have things better figured out, I will try to contribute. Thanks! |
February 5, 2015, 18:15 |
#143 |
Andre Mas
Rep Power: 11 |
Current status update on my efforts:
- https://github.com/ajmas/OpenFOAM-2.3.x master branch includes most of the changes available in this thread - I have created a build script, attached to this post that should make building much easier. Doing the following: -- Creating and mounting case-sensitive HFS+ disk image -- Getting the necessary MacPorts (if you use another tool, please contribute changes) -- Cloning the git repository (uses mine, since it is already patched) -- Configuring bashrc -- initiating the build -- Ensuring the build is outputted to log Please let me know if this helps you and please provide any pull-requests or change suggestions. Note, I still waiting for my current build to finish, so will see if it is successful. Edit: updated build file 2015-03-07 Last edited by ajmas; March 7, 2015 at 16:01. |
February 9, 2015, 15:58 |
#144 | |
Jonathan
Rep Power: 11 |
February 9, 2015, 16:10 |
#145 |
Jonathan
Rep Power: 11 |
Following from reply #137, those uploaded errors occurred when building with gcc-4.7. I found that using built-in (Apple) clang-5.1 avoided the errors. However, I prefer to use gcc via macports, and made another attempt with gcc-4.9. Similar errors resulted, but I was able to get past them by applying the attached patch. It is just additional '#include "vector.H"' lines in several files; it is a hack at best and is probably not the best approach. I presume that this will help with building with gcc-4.7 and 4.8 also, but I have not tested.
February 14, 2015, 12:46 |
#146 |
Andre Mas
Rep Power: 11 |
Does anyone know how to resolve this issue:
ld: library not found for -lpmpich Code:
bash-3.2$ ls -1 /opt/local/lib/mpich-gcc47 libfmpich.dylib libmpi.12.dylib libmpi.a libmpi.dylib libmpich.dylib libmpichcxx.dylib libmpichf90.dylib libmpicxx.12.dylib libmpicxx.a libmpicxx.dylib libmpifort.12.dylib libmpifort.a libmpifort.dylib libmpl.dylib libopa.dylib libpmpi.12.dylib libpmpi.a libpmpi.dylib pkgconfig Last edited by ajmas; February 19, 2015 at 09:31. |
February 26, 2015, 12:20 |
#147 |
Davide D.
Rep Power: 14 |
Tried to compile OpenFoam 2.3.1 on MacBook Air Yosemite. Gcc46 used.
The compilation fails several times, the first of which while building multiphaseSystem libraries. I am attaching the log file. Thank you in advance |
February 26, 2015, 14:32 |
#148 |
Peter
Rep Power: 11 |
February 27, 2015, 12:37 |
#149 | |
Davide D.
Rep Power: 14 |
Thank you for the link. I followed the guide, but I still have errors. Here is a link to my logfile. https://www.dropbox.com/s/mu02hr4nxa...xt.tar.gz?dl=0 |
February 27, 2015, 14:36 |
#150 |
Peter
Rep Power: 11 |
Had a look at your log. A couple of questions: 1) Are you sure you are compiling the git repository version? If you try to use the guide with the release version, you're gonna have a bad time... 2) Are you sure you followed the guide completely (i.e., are using the macports gcc48 compiler, and the openmpi-gcc48 package)? Installing the packages is not enough, you must also run: Code:
$ sudo port select --set gcc mp-gcc48 Code:
$ sudo port select --set mpi openmpi-gcc48-fortran You can test this with: Code:
$ which mpicc Code:
$ which gcc Also, could you run: Code:
$ port select --summary Code:
$ mpicc --version Cheers, Peter |
February 27, 2015, 19:46 |
#151 | |
Davide D.
Rep Power: 14 |
Hi, thank you again. Unfortunately I still have errors.
As regards the other suggestions, yes, I installed the macports and run port select command: Code:
$ port select --summary Name Selected Options ==== ======== ======= db db48 db48 none gcc mp-gcc48 mp-gcc46 mp-gcc48 mp-gcc49 none llvm mp-llvm-3.5 mp-llvm-3.3 mp-llvm-3.5 none mpi openmpi-gcc48-fortran mpich-mp-fortran openmpi-gcc46-fortran openmpi-gcc48-fortran openmpi-mp-fortran none python python27 python26-apple python27 python27-apple none Code:
$ which mpicc /opt/local/bin/mpicc Code:
$ which gcc /opt/local/bin/gcc Code:
$ which mpicc $ mpicc --version Apple LLVM version 6.0 (clang-600.0.56) (based on LLVM 3.5svn) Target: x86_64-apple-darwin14.1.0 Thread model: posix https://www.dropbox.com/s/vuw0bdepo3...-2.tar.gz?dl=0 Thank you, Davide |
February 27, 2015, 23:06 |
#152 |
Peter
Rep Power: 11 |
Hi Davide,
It seems that something is amiss in your environment regarding which mpicc and mpicxx you are using. When you run: Code:
$ mpicc --version gcc-mp-4.8 (MacPorts gcc48 4.8.4_0) 4.8.4 Copyright (C) 2013 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Code:
$ mpicxx --version g++-mp-4.8 (MacPorts gcc48 4.8.4_0) 4.8.4 Copyright (C) 2013 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Code:
$ mpicc --version Apple LLVM version 6.0 (clang-600.0.56) (based on LLVM 3.5svn) Target: x86_64-apple-darwin14.1.0 Thread model: posix You can "manually" correct this by appending this to the openfoam/etc/bashrc: Code:
echo "WM_CC=mpicc-openmpi-gcc48" >> /path/to/OpenFOAM-2.3.x/etc/bashrc echo "WM_CXX=mpicxx-openmpi-gcc48" >> /path/to/OpenFOAM-2.3.x/etc/bashrc Code:
echo "WM_CC=mpicc" >> /path/to/OpenFOAM-2.3.x/etc/bashrc echo "WM_CXX=mpicxx" >> /path/to/OpenFOAM-2.3.x/etc/bashrc |
February 28, 2015, 07:41 |
#153 | |
Davide D.
Rep Power: 14 |
Cannot open configuration file /opt/local/share/openmpi-mp/openmpi/mpicc-openmpi-gcc48-wrapper-data.txt Error parsing data file mpicc-openmpi-gcc48: Not found make: *** [<OpenFOAM directory>/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/dirToString] Error 243 Code:
$ ls -l /opt/local/share/openmpi-mp/openmpi/mpicc-* lrwxr-xr-x 1 root admin 22 Feb 27 09:40 /opt/local/share/openmpi-mp/openmpi/mpicc-openmpi-mp-wrapper-data.txt@ -> mpicc-wrapper-data.txt -rw-r--r-- 1 root admin 598 Feb 27 09:40 /opt/local/share/openmpi-mp/openmpi/mpicc-vt-wrapper-data.txt -rw-r--r-- 1 root admin 938 Feb 27 09:40 /opt/local/share/openmpi-mp/openmpi/mpicc-wrapper-data.txt |
February 28, 2015, 08:24 |
OpenFOAM Installation Error
#154 | |
Paolo
Rep Power: 11 |
I'm new here, and I have no experiences with these kind of things. I'm trying to install OpenFOAM on my Mac OS X 10.10.1 since some days without any result. I also tried to run different installation process, but everytime there are some errors. As I told you, I can not figure out where is the problem. Hope some of you can help me. Here is the first error I found in the log.Allwmake (apparently this is the most important): Quote:
February 28, 2015, 13:29 |
#155 |
Peter
Rep Power: 11 |
Hi Davide,
So, there are still some inconsistencies in your environment. I suspect that it has something to do with the fact that you have both the "default" openmpi and the openmpi-gcc48 variant (and a whole bunch of others) installed. It is looking for the "mpicc-openmpi-gcc48-wrapper-data.txt" file in the "openmpi-mp" directory (which is where the "default" macports openmpi package lives), when it should be looking here: Code:
/opt/local/share/openmpi-gcc48/openmpi/ 1) Remove all installed ports to get a "clean" environment (probably a good idea anyway, since you have so many variants installed), i.e.: Code:
$ sudo port uninstall installed Code:
sudo port install gcc48 sudo port select --set gcc mp-gcc48 sudo port install openmpi-gcc48 sudo port select --set mpi openmpi-gcc48-fortran sudo port install boost +openmpi sudo port install cgal sudo port install ccache sudo port install flex sudo port install scotch -mpich +gcc48 +openmpi sudo port install metis +gcc48 Hope this will do the trick! Peter |
February 28, 2015, 13:36 |
#156 |
Peter
Rep Power: 11 |
Petru,
I don't know which guide you are following. I tried several without success. In the end, this is what worked for me: http://openfoamwiki.net/index.php/In...OpenFOAM_2.3.x To avoid issues with your environment, especially if you've made multiple attempts using different packages and/or package managers (MacPorts/Homebrew/Fink/etc...), I suggest you remove all previously installed (possibly conflicting) variants of packages. Good luck, Peter |
February 28, 2015, 19:52 |
#157 |
Davide D.
Rep Power: 14 |
Hi Peter,
I removed all the ports to get a clean environment, and then attempted to re-install all the packages. Now I have the correct output for the select command: Code:
$ port select --summary Name Selected Options ==== ======== ======= db db48 db48 none gcc mp-gcc48 mp-gcc48 none llvm mp-llvm-3.5 mp-llvm-3.5 none mpi openmpi-gcc48-fortran openmpi-gcc48-fortran none python python27 python26-apple python27 python27-apple none Code:
$ port installed | grep openmpi openmpi-gcc48 @1.7.5_3+fortran (active) I circumvented the issue at the boost installation by adding the -openmpi-default string: Code:
sudo port install boost +gcc48 +openmpi-gcc48-fortran -openmpi-default Code:
sudo port install scotch -mpich +gcc48 +openmpi-gcc48-fortran -openmpi-default -gcc49 ---> Fetching archive for scotch Warning: Your DNS servers incorrectly claim to know the address of nonexistent hosts. This may cause checksum mismatches for some ports. See this page for more information: <https://trac.macports.org/wiki/MisbehavingServers> ---> Attempting to fetch scotch-6.0.0_0.darwin_14.x86_64.tbz2 from http://mse.uk.packages.macports.org/sites/packages.macports.org/scotch ---> Attempting to fetch scotch-6.0.0_0.darwin_14.x86_64.tbz2 from http://lil.fr.packages.macports.org/scotch ---> Attempting to fetch scotch-6.0.0_0.darwin_14.x86_64.tbz2 from http://nue.de.packages.macports.org/macports/packages/scotch ---> Fetching distfiles for scotch Error: org.macports.fetch for port scotch returned: must set at least one mpi variant Please see the log file for port scotch for details: /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_science_scotch/scotch/main.log To report a bug, follow the instructions in the guide: http://guide.macports.org/#project.tickets Error: Processing of port scotch failed Thank you, Davide |
March 1, 2015, 14:13 |
#158 |
Paolo
Rep Power: 11 |
Hi Peter,
Thank you for you answer. I tried to apply your suggests, but I still have an Error. Code:
mpicc -m64 -fsignaling-nans -ftrapping-math -Wall -O2 -fPIC -Ddarwin dirToString.c -o /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/dirToString dyld: Library not loaded: /usr/local/lib/libopen-pal.6.dylib Referenced from: /usr/local/bin/mpicc Reason: Incompatible library version: mpicc requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0 make: *** [/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/dirToString] Trace/BPT trap: 5 no ThirdParty sources found - skipping + wmakePrintBuild -check version changed from previous build + /bin/rm -f 'OpenFOAM/Make/*/global.?' + wmakeLnInclude OpenFOAM wmakeLnInclude: linking include files to OpenFOAM/lnInclude + wmakeLnInclude OSspecific/POSIX wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude + Pstream/Allwmake + wmake libso dummy wmakeLnInclude: linking include files to ./lnInclude /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory SOURCE=UPstream.C ; mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/UPstream.o dyld: Library not loaded: /usr/local/lib/libopen-pal.6.dylib Referenced from: /usr/local/bin/mpicxx Reason: Incompatible library version: mpicxx requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0 /bin/sh: line 1: 79047 Trace/BPT trap: 5 mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/UPstream.o make: *** [Make/darwinIntel64GccDPOpt/UPstream.o] Error 133 + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers wclean mpi wmake libso mpi wmakeLnInclude: linking include files to ./lnInclude /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory SOURCE=UOPwrite.C ; mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/opt/local/include/openmpi-mp -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o dyld: Library not loaded: /usr/local/lib/libopen-pal.6.dylib Referenced from: /usr/local/bin/mpicxx Reason: Incompatible library version: mpicxx requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0 /bin/sh: line 1: 79134 Trace/BPT trap: 5 mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/opt/local/include/openmpi-mp -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o make: *** [Make/darwinIntel64GccDPOptMACPORTOPENMPI/UOPwrite.o] Error 133 + OSspecific/POSIX/Allwmake wmakeLnInclude: linking include files to ./lnInclude /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory /bin/sh: /Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/wmake/platforms/darwinIntel64Gcc/wmkdep: No such file or directory SOURCE=signals/sigFpe.C ; mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/sigFpe.o dyld: Library not loaded: /usr/local/lib/libopen-pal.6.dylib Referenced from: /usr/local/bin/mpicxx Reason: Incompatible library version: mpicxx requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0 /bin/sh: line 1: 79294 Trace/BPT trap: 5 mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Paolo/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/sigFpe.o make: *** [Make/darwinIntel64GccDPOpt/sigFpe.o] Error 133 I can't understand where is the problem, but maybe it is due to the sudo port installation: Code:
port select --summary Name Selected Options ==== ======== ======= db db48 db48 none gcc mp-gcc48 mp-gcc48 mp-gcc49 none ipython none none llvm none mp-llvm-3.5 none mpi openmpi-gcc48-fortran openmpi-gcc48-fortran openmpi-mp-fortran none python python27 python26-apple python27 python27-apple none Code:
Selecting 'mp-llvm-3.5' for 'llvm' failed: symlink: /opt/local/etc/select/llvm/current -> mp-llvm-3.5: file already exists Do you have any ideas? Thank you again, for your time Paolo |
March 5, 2015, 09:59 |
#159 | ||||
Rep Power: 12 |
Hello guys,
I have some problems installing OpenFOAM 2.3.1 on an MacBook Pro running Yosemite. I've followed the recommended guide for installing 2.2.2 (http://openfoamwiki.net/index.php/In....2#Final_Steps) and somehow it did'nt work. I think about starting from scratch again but I don't really understand some of the notes in the readme file from gschaider(http://sourceforge.net/p/openfoam-ex...acPatch/README). Quote:
I would really appreciate an explanation. Cheers, Kate |
March 13, 2015, 17:42 |
#160 | |
Andre Mas
Rep Power: 11 |
I found this due issues resulting from the using of the version of flex at /usr/bin/flex. The MacOS X default version will fail in certain cases. I have also now put the script for the build script on GitHub: https://github.com/ajmas/scripts-et-...sx-macports.sh And with all this it all builds Last edited by ajmas; March 14, 2015 at 00:17. |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 03:01 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
