[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch
Like Tree8Likes
Old   May 14, 2014, 15:35
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
well, describe what exactly you've done, step by step. Show your bashrc file. As Pstream library was not compiled I guess there was other errors before the one you've posted in your message. Can you show full compilation log?
alexeym is offline   Reply With Quote
Old   May 14, 2014, 16:48
Alexey Matveichev
You've got this line in your bashrc:
export WM_MPLIB=OPENMPI
while it should be
export WM_MPLIB=SYSTEMOPENMPI
as you have OpenMPI installed system-wide with Macports.
And due to this error in configuration, you've got this error in the very beginning of your compilation log:
Making dependency list for source file UOPwrite.C
could not open file mpi.h for source file UOPwrite.C due to No such file or directory
Making dependency list for source file UIPread.C
could not open file mpi.h for source file UIPread.C due to No such file or directory
Making dependency list for source file UPstream.C
could not open file mpi.h for source file UPstream.C due to No such file or directory
Making dependency list for source file PstreamGlobals.C
could not open file mpi.h for source file PstreamGlobals.C due to No such file or directory
SOURCE=UOPwrite.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -
Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/Users/Mowa/OpenFOAM/ThirdParty-2.3
.x/platforms/darwinIntel64Gcc46/openmpi-1.6.5/include -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -
I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46DPOptOPENM
PI/UOPwrite.o
UOPwrite.C:29:17: fatal error: mpi.h: No such file or directory
compilation terminated.
make: *** [Make/darwinIntel64Gcc46DPOptOPENMPI/UOPwrite.o] Error 1
It leads to all other troubles.
Old   May 15, 2014, 12:09
Alexey Matveichev
Can you post output of
$ which mpicc
Did you execute (I don't know exact syntax of the command, you should read port's man page)
$ sudo port select --set mpi <version>
Until you fix your OpenMPI installation there's no point in compiling OpenFOAM again and again (though, guess without Pstream compilation fails rather quickly). Also maybe it'll be easier for both of us to wait till somebody using Macports (and was able to build OF successfully) post an answer.
Old   May 15, 2014, 12:53
Alexey Matveichev
Well, maybe there are some stale dep files; as installation of MPI looks OK, try going to $WM_PROJECT_DIR and executing:
$ wclean all src
$ wclean all applications
to remove old compilation results and then execute ./Allwmake script again.
Old   May 16, 2014, 15:54
Juimo Pierre
Roskiki is on a distinguished road
OpenFOAM to successfully compile with the same error. SEVERAL solver works except interfoam. how to operate Parafoam?
merci encor!!!!
Roskiki is offline   Reply With Quote
Old   May 17, 2014, 03:46
J.-H. Wang
f0208secretx is on a distinguished road
Originally Posted by alexeym View Post
I don't know much about building OF on OS X with Macport's gcc (I've used it successfully 2 years ago for 2.1.1, after I used Linux, and finally recently I've used clang to build OF on OS X).
Concerning your question about scotch, I've used 'grep -r lscotch *' and 'grep -r lptscotch *' in $WM_PROJECT_DIR to get rough estimation of the applications and libraries using Scotch library, and I guess you won't be able to use:
foamyHexMesh
renumberMesh
decomposePar (with scotch decomposition method)
foamyQuadMesh
snappyHexMesh
redistributePar
Also, since you're referencing to the post where I used clang to build OpenFOAM and your error is with gcc, I don't know what's gone wrong during installation process.
Hi alexeym,
Thanks for getting back to me. I downloaded the patch from your blog and apply them to OpenFOAM-2.3.0 from openfoam.org. I followed all the steps and yet am still getting some errors. I have little ideas on how to solve them, so I posted my log file and hopefully someone can help me with it.
Meanwhile I will try the whole process again. Thanks.
JHW
f0208secretx is offline   Reply With Quote
Old   May 17, 2014, 04:09
Alexey Matveichev
Well, in addition to the compilation log, please, attach your OpenFOAM's bashrc file. Cause your log file looks rather strange to me: it use g++ in one place and clang++ in other. Also what patch did you use?
Old   May 17, 2014, 04:16
J.-H. Wang
It seems that I cannot attach another file for my previous post, so I will have to do it here. Sorry for the spam...
I suspect it was because I had not removed everything completely from the failed attempt in the past. I removed the entire folder and am re-doing the whole process. This time it seems more... promising. If you can confirm this conjecture will be the best. Thank you.
I am using the patch linked from your blog:
https://dl.dropboxusercontent.com/u/...-2.3.0-2.patch
https://dl.dropboxusercontent.com/u/...-2.3.0-1.patch
JHW
Old   May 17, 2014, 04:24
Alexey Matveichev
Though now log file looks more consistent, I don't like the errors with flex (finally they lead to complete fail of installation). Can you post output of
$ which flex
and
$ flex --version
commands?
Do you have Macports installed?
Old   May 17, 2014, 11:52
J.-H. Wang
$ which flex
and
$ flex --version
commands?
As follows:
dhcp-128-253-143-174:OpenFOAM-2.3.0 jui-hsienwang$ which flex
/opt/local/bin/flex
dhcp-128-253-143-174:OpenFOAM-2.3.0 jui-hsienwang$ flex --version
flex 2.5.37
dhcp-128-253-143-174:OpenFOAM-2.3.0 jui-hsienwang$ sudo port
MacPorts 2.2.1
Entering interactive mode... ("help" for help, "quit" to quit)
[OpenFOAM-v2.3/OpenFOAM-2.3.0] > q
Goodbye
The second attempt still failed. I attached the log file and bashrc for your reference. Thanks so much.
https://dl.dropboxusercontent.com/u/...-17-2014-2.zip
JHW
Old   May 17, 2014, 12:42
Alexey Matveichev
Well,
as you've got Macports installed, you should use the patch from the beginning of the thread (and use gcc installed with Macports for compilation).
My patch rely on the software shipped with OS X (clang, flex etc), so ex. there's no problem with include path for flex. As you've got Macports installed, during compilation clang is used from OS X developer tools, and flex is used from Macports installation, due to certain incompatibilities between these two, you've got the error:
Make/darwinIntel64ClangDPOpt/STLsurfaceFormatASCII.C:5981:18: error: out-of-line definition of 'LexerInput' does not match any decla
ration in 'yyFlexLexer'
int yyFlexLexer::LexerInput( char* buf, int max_size )
Old   May 17, 2014, 13:20
Default error compiling interFoam
  #72
Juimo Pierre
g++-mp-4.6 -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -lpthread -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/dummy -lPstream Make/darwinIntel64Gcc46DPOpt/interFoam.o -L/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
-limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interFoam
Undefined symbols for architecture x86_64:
"Foam::transportModel::~transportModel()", referenced from:
Foam::incompressibleTwoPhaseMixture::~incompressib leTwoPhaseMixture() in interFoam.o
Foam::immiscibleIncompressibleTwoPhaseMixture::~im miscibleIncompressibleTwoPhaseMixture() in interFoam.o
"Foam::interfaceProperties::calculateK()", referenced from:
Foam::immiscibleIncompressibleTwoPhaseMixture::cor rect() in interFoam.o
_main in interFoam.o
"Foam::incompressibleTwoPhaseMixture::read()", referenced from:
vtable for Foam::immiscibleIncompressibleTwoPhaseMixture in interFoam.o
"Foam::incompressibleTwoPhaseMixture::calcNu() ", referenced from:
"Foam::incompressibleTwoPhaseMixture::typeName ", referenced from:
Foam::incompressibleTwoPhaseMixture::type() const in interFoam.o
"Foam::interfaceProperties::nearInterface() const", referenced from:
"Foam::interfaceProperties::surfaceTensionForc e() const", referenced from:
"typeinfo for Foam::incompressibleTwoPhaseMixture", referenced from:
typeinfo for Foam::immiscibleIncompressibleTwoPhaseMixture in interFoam.o
"vtable for Foam::incompressibleTwoPhaseMixture", referenced from:
NOTE: a missing vtable usually means the first non-inline virtual member function has no definition.
"non-virtual thunk to Foam::incompressibleTwoPhaseMixture::read()", referenced from:
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make: *** [/Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interFoam] Error 1
any idea?
Old   May 18, 2014, 01:05
J.-H. Wang
Well,
Hi alexeym,
Thanks for getting back to me. I followed the instruction and cloned the git version. While I was following the instruction listed in the wiki, http://openfoamwiki.net/index.php/In...OpenFOAM_2.2.2, I found a line that looks different. In the wiki it says for the file src/renumber/SloanRenumber/Make/options,
Change this line:
-L$(BOOST_ARCH_PATH)/lib -lboost_thread \
into this:
-L$(BOOST_ARCH_PATH)/lib -lboost_thread-mt \
But instead the file I pulled from github looks like
LIB_LIBS = \
    -L$(BOOST_ARCH_PATH)/lib -lboost_thread$(BOOST_THREAD_EXTENSION) \
    -lmeshTools \
    -ldecompositionMethods \
    -lrenumberMethods
I wasn't so sure if I can just change it to
LIB_LIBS = \
    -L$(BOOST_ARCH_PATH)/lib -lboost_thread-mt$(BOOST_THREAD_EXTENSION) \
If I do this naively it appears to cause trouble in the compilation. If you can give me an advise or two will be great. Thanks!
JHW
Old   May 18, 2014, 05:56
Alexey Matveichev
@Roskiki: I think due to certain errors libincompressibleTransportModels was not built. So you've got undefined symbols.
@f0208secretx: You should leave the line as it is, BOOST_THREAD_EXTENSION variable is filled during environment initialization. If you have single threaded boost version it will be empty, if you've got multithreaded boost version, it will contain "-mt" string.
f0208secretx likes this.
Old   May 18, 2014, 10:47
Juimo Pierre
I added '-lincompressibleTransportModels \' in Make/option:
EXE_INC = \
-I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
-I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/fvOptions/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
-limmiscibleIncompressibleTwoPhaseMixture \
-lincompressibleTurbulenceModel \
-lincompressibleRASModels \
-lincompressibleLESModels \
-lfiniteVolume \
-lfvOptions \
-lmeshTools \
-lsampling
2-wmake:
-limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lfvOptions -lincompressibleTransportModels -lmeshTools -lsampling -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interFoam
any idea?
LtInterFoam, interFoam and interDyMFoam does not work
Old   May 18, 2014, 10:57
Alexey Matveichev
If addition of the linking flag helped, add another one:
-linterfaceProperties
Old   May 18, 2014, 11:18
Juimo Pierre
thank you very much
Old   May 18, 2014, 12:59
J.-H. Wang
I got a very similar error to Roskiki. Something like
+ wmake
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -IincompressibleTwoPhaseInteractingMixture -ImixtureViscosityModels/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/TurbulenceModels/compressible/lnInclude -I./relativeVelocityModels/lnInclude -IlnInclude -I. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport-gcc46 -lPstream Make/darwinIntel64Gcc46DPOpt/incompressibleTwoPhaseInteractingMixture.o Make/darwinIntel64Gcc46DPOpt/compressibleTurbulenceModels.o Make/darwinIntel64Gcc46DPOpt/driftFluxFoam.o -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
	     -ldriftFluxTransportModels -ldriftFluxRelativeVelocityModels -lfiniteVolume -lmeshTools -lsampling -lfvOptions -lincompressibleTransportModels -lturbulenceModels -lcompressibleTurbulenceModels -lOpenFOAM -ldl   -lpthread -lm -o /Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/driftFluxFoam
  "Foam::twoPhaseMixture::twoPhaseMixture(Foam::fvMesh const&, Foam::dictionary const&)", referenced from:
      Foam::incompressibleTwoPhaseInteractingMixture::incompressibleTwoPhaseInteractingMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in incompressibleTwoPhaseInteractingMixture.o
make[2]: *** [/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/driftFluxFoam] Error 1
make[1]: *** [driftFluxFoam] Error 2
I searched online and people suggested this might be a problem of the different implementations of the standard C++ library after OS X 10.9. The discussion can be found at, for example,
http://stackoverflow.com/questions/1...-9-xcode-5-0-1
Could this be the problem? Or like Roskiki I have some models weren't built? (How do I know?) If I want to manually choose the library libstdc++, where and what should I change? Thanks a lot for your continuous help
JHW
Old   May 18, 2014, 13:10
Juimo Pierre
As there were two posts with error in compilation of this solver, I've decided to post a way to correct it. The guide is valid for commit 6f6bc2f78679cffacf479cb58cc74497bbf3963c (IIRC there's no such problem on Linux, so guess this correction will be valid for later commits as error won't be fixed in repository).
1. Go to $FOAM_APP/solvers/multiphase/driftFluxFoam
2. Open Make/options in an editor
3. Make it look like:
EXE_INC = \
-IincompressibleTwoPhaseInteractingMixture \
-ImixtureViscosityModels/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
EXE_LIBS = \
-lfiniteVolume \
-lmeshTools \
-lsampling \
-lfvOptions \
-ltwoPhaseMixture \
-ldriftFluxTransportModels \
in fact it's just addition of a line "-ltwoPhaseMixture \" after "-lincompressibleTransportModels \"
4. run wmake
Solver should compile now without errors.
from alexym
Old   May 18, 2014, 15:39
J.-H. Wang
EXE_INC = \
EXE_LIBS = \
-lfiniteVolume \
-lmeshTools \
-lsampling \
-lfvOptions \
-ltwoPhaseMixture \
4. run wmake
from alexym
Thanks for the reply. It does fix one of the errors. But I still have errors from other solvers, in particular,
in interFoam:
+ wmake
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport-gcc46 -lPstream Make/darwinIntel64Gcc46DPOpt/interFoam.o -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
	     -limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lOpenFOAM -ldl   -lpthread -lm -o /Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interFoam
      Foam::incompressibleTwoPhaseMixture::~incompressibleTwoPhaseMixture() in interFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::~immiscibleIncompressibleTwoPhaseMixture() in interFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::correct()     in interFoam.o
  "Foam::incompressibleTwoPhaseMixture::calcNu()", referenced from:
  "Foam::incompressibleTwoPhaseMixture::typeName", referenced from:
  "Foam::interfaceProperties::surfaceTensionForce() const", referenced from:
make[2]: *** [/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interFoam] Error 1
in interDyMFoam:
+ wmake interDyMFoam
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I.. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/dynamicMesh/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport-gcc46 -lPstream Make/darwinIntel64Gcc46DPOpt/interDyMFoam.o -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
	     -limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -ldynamicMesh -ldynamicFvMesh -ltopoChangerFvMesh -lmeshTools -lfvOptions -lsampling -lOpenFOAM -ldl   -lpthread -lm -o /Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interDyMFoam
      Foam::incompressibleTwoPhaseMixture::~incompressibleTwoPhaseMixture() in interDyMFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::~immiscibleIncompressibleTwoPhaseMixture() in interDyMFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::correct()     in interDyMFoam.o
      _main in interDyMFoam.o
      vtable for Foam::immiscibleIncompressibleTwoPhaseMixture in interDyMFoam.o
      Foam::incompressibleTwoPhaseMixture::type() const in interDyMFoam.o
      typeinfo for Foam::immiscibleIncompressibleTwoPhaseMixture in interDyMFoam.o
make[2]: *** [/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/interDyMFoam] Error 1
in porousInterFoam:
+ wmake porousInterFoam
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I.. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport-gcc46 -lPstream Make/darwinIntel64Gcc46DPOpt/porousInterFoam.o -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
	     -limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -lOpenFOAM -ldl   -lpthread -lm -o /Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/porousInterFoam
      Foam::immiscibleIncompressibleTwoPhaseMixture::correct()     in porousInterFoam.o
      _main in porousInterFoam.o
make[2]: *** [/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/porousInterFoam] Error 1
in LTSInterFoam:
+ wmake LTSInterFoam
g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I.. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -lpthread -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport-gcc46 -lPstream Make/darwinIntel64Gcc46DPOpt/LTSInterFoam.o -L/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib \
	     -limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -lOpenFOAM -ldl   -lpthread -lm -o /Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/LTSInterFoam
      Foam::incompressibleTwoPhaseMixture::~incompressibleTwoPhaseMixture() in LTSInterFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::~immiscibleIncompressibleTwoPhaseMixture() in LTSInterFoam.o
      Foam::immiscibleIncompressibleTwoPhaseMixture::correct()     in LTSInterFoam.o
      _main in LTSInterFoam.o
      vtable for Foam::immiscibleIncompressibleTwoPhaseMixture in LTSInterFoam.o
      Foam::incompressibleTwoPhaseMixture::type() const in LTSInterFoam.o
      typeinfo for Foam::immiscibleIncompressibleTwoPhaseMixture in LTSInterFoam.o
make[2]: *** [/Users/jui-hsienwang/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/LTSInterFoam] Error 1
log file attached for your reference. Thanks
JHW
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
