[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch |
July 29, 2015, 08:34 |
#221 |
Rep Power: 11 |
I chose your second suggestion and added -lscotch to the Options' code myself - it worked perfectly fine!
What can I say, once again thank you very much for taking your time and helping |
August 6, 2015, 02:20 |
#222 | ||||
Paul W. Fontana
Rep Power: 13 |
I have been trying to install OpenFOAM on Mac OS X 10.10.4 following the steps at https://openfoamwiki.net/index.php/I...OpenFOAM_2.3.x. Everything goes smoothly until I enter
sudo port select --set db db48 I get Selecting 'db48' for 'db' failed: The configuration file '/opt/local/etc/select/db/base' could not be opened. When I enter ls /opt/local/etc/select/db/ it just lists db48 When I type 'port select --summary' I get Name Selected Options ==== ======== ======= db none db48 none gcc mp-gcc48 mp-gcc48 mp-gcc49 none llvm mp-llvm-3.5 mp-llvm-3.5 none mpi openmpi-gcc48-fortran openmpi-gcc48-fortran openmpi-mp-fortran none python python27 python26-apple python27 python27-apple none python2 none python26-apple python27 python27-apple none (sorry I don't know how to do the nice formatting.) How do I fix my files and get db48 selected? What does a healthy /opt/local/etc/select/db/base have in its contents? I can just try constructing the file and hope that its being missing is the only problem. [ --- Moderator merge --- ] I'm trying to install OpenFOAM on Mac OS X 10.10.4. I followed the instructions step by step and got as far as Quote:
Last edited by wyldckat; August 7, 2015 at 18:21. Reason: merged two posts posted on the same day, same question, similar details |
August 9, 2015, 08:50 |
#223 |
nasir musa yakubu
Rep Power: 12 |
hello, my advice, if you wanna quick get up and running, i would recommend using parallel to run ubuntu on mac, then install open foam, very easy way to go i reckon....goodluck having fun with open foam
August 12, 2015, 11:43 |
problem with openmpi-gcc48
#224 | |
Ali
Rep Power: 13 |
I'm trying to get OpenFOAM to work on my mac, but one thing is holding the process up. openmpi will not install, as my c compiler isn't working.
When i do the command Quote:
I've tried installing openmpi, but something is obviously wrong with the compiler. I'm running 10.10.4, with xcode6.4, and command line tools installed. Any help would be appreciated! EDIT: I deleted macports, and started again. Now everything works, except db48. I'm at the same stage as #222, in my '/opt/local/etc/select/db/' I just have db, and no 'base' file. Last edited by ali.m.1; August 13, 2015 at 04:56. |
August 25, 2015, 19:33 |
#225 |
Andres F.
Hello, I am having the same issue just mention few post above.
I am not able to fix: db ---> db48 anyhelp is welcome. regards, Andres ------------ Paul Fontana, did you were able to fix it? Last edited by wyldckat; August 26, 2015 at 17:46. Reason: merged posts that were a few minutes apart |
August 25, 2015, 19:43 |
#226 |
Paul W. Fontana
Rep Power: 13 |
No. I gave up and installed with Homebrew instead. I did get that to work using the instructions at https://github.com/mrklein/openfoam-...20&%20Homebrew, but I still had some trouble and had to increase my maxfiles and maxproc settings, and there were a couple of other minor issues. It's working now, though.
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
