[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch
Like Tree8Likes
Old   March 28, 2015, 07:38
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
As the path in error is
/bin/tools/RunFunctions
I would suppose you did not set up environment variables, because this is the line in the script where it sources RunFunctions
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
as your environment was not set up, $WM_PROJECT_DIR is expanded into empty string.
alexeym is offline   Reply With Quote
Old   March 31, 2015, 11:03
KateEisenhower is on a distinguished road
I am not sure if I understand what you are trying to tell me. Has it something to do with the post-configuration part of the Hopscotch Building OpenFOAM on OS X guide (http://matveichev.blogspot.fr/2014/0...on-os-x.html)?
I didn't understand this part and I guess it didn't work on my machine.
How do I set up environment variables?
Originally Posted by alexeym View Post
KateEisenhower is offline   Reply With Quote
Old   March 31, 2015, 11:12
Alexey Matveichev
Maybe here it is written clearer - https://github.com/mrklein/openfoam-...-configuration.
If you were able to build OpenFOAM, then once you have set up environment variables. In general it is done with 'source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc' command. But before issuing this command you have to mount disk image with case sensitive file system you have created.
Old   March 31, 2015, 11:20
everytime I reboot my mac I am typing the following:
hdiutil attach -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle
So I guess that is not the problem. Am I wrong?
p.s.: Thank you for the post configuration guide. I will try this!
Old   March 31, 2015, 11:28
Alexey Matveichev
Well, commands seems to be OK. What is the output of the commands?
Post-configuration guide is just trying to automate the commands you are entering. If they do not work then re-reading the guide in general will not help.
Old   March 31, 2015, 11:37
The output is:
Kates-MacBook-Pro:~ kateeisenhower$ hdiutil attach -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle
/dev/disk2          	GUID_partition_scheme
/dev/disk2s1        	EFI
/dev/disk2s2        	Apple_HFS                      	/Users/kateeisenhower/OpenFOAM
Kates-MacBook-Pro:~ kateeisenhower$ source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc
Using paraview in directory /Applications/paraview.app
Old   March 31, 2015, 11:39
Alexey Matveichev
And then you open new terminal and try to run tutorial case? You have to do 'source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc' every time you open new terminal session.
Old   March 31, 2015, 11:40
I never close terminal.
Old   March 31, 2015, 11:42
Alexey Matveichev
And you always work in one tab/window? You never open new windows/tabs?
Old   March 31, 2015, 11:46
Not within the terminal app.
Ah, now I got it. When I double click on the Allrun script, it opens in a new window automatically. I will try to follow the guide you recommended me for automating the process of mounting disk image and setup environment variables. This will solve the problem, right?
Thank you very much for your help!
Old   April 1, 2015, 04:50
I tried to follow the default version approach but I have two questions:
1) In which directory do I have to be when I make the directory .OpenFOAM?
2) Where is my ~/.profile?
Thanks in advance
Old   April 1, 2015, 05:08
Alexey Matveichev
1. Really, I have omitted this in guide. You should be in $HOME folder (/Users/kateeisenhower).
2. In general on Unices ~ refers to home folder, so your ~/.profile is /Users/kateeisenhower/.profile.
You can check if installation succeeded by executing Allrun in Terminal instead of Finder. I.e. in the terminal, where you have mounted disk image and then executed 'source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc', you write (text starting from # is a commentary)
tut # will got to tutorials folder
cd incompressible/simpleFoam/motorBike # go to motorBike tutorial
./Allrun # run tutorial
Old   April 1, 2015, 06:17
1) I read the guide another time but I couldn't find it. However I tried to create a file with the version inside:
Kates-MacBook-Pro:~ kateeisenhower$ mkdir -p .OpenFOAM
Kates-MacBook-Pro:~ kateeisenhower$ echo '2.3.1' > .OpenFOAM/OpenFOAM-release
2) I know that, but in my home folder there is no such file. So I asked again.
Old   April 1, 2015, 06:31
Alexey Matveichev
And the result of these operations? Do you still have problems with tutorial execution or it started to work?
Old   April 1, 2015, 06:33
There was no result. I have posted everything which I could see in terminal.
I did not try the tutorials because I was not able to do step two of the post configuration guide because of the missing .profile.
Old   April 1, 2015, 06:45
Alexey Matveichev
And you can not create it? Even with just
echo 'source $HOME/openfoam-env-setup.sh' > $HOME/.profile
Old   April 1, 2015, 06:50
No, it doesn't work. I looked again, but there are only my documents, music, pictures... folders as well as my OpenFOAM image and OpenFOAM.sparsebundle.
Old   April 1, 2015, 06:52
Alexey Matveichev
How did you do 'I looked again...'? With Finder? Or with 'ls -la' in Terminal?
Old   April 1, 2015, 06:56
Okay, this worked. I can see the file now. Yes, I looked with the Finder. I don't know why but I really can't see all the files there. I am trying to complete the post configuration now.
Thank you for your help!
Old   April 1, 2015, 07:54
Okay, I managed to change the .profile. It looks like this now:
Kates-MacBook-Pro:~ kateeisenhower$ cat .profile
source $HOME/openfoam-env-setup.sd
if [ -f "$HOME/.OpenFOAM/OpenFOAM-release" ]; then
    FOAM_DISK_IMAGE=$HOME/OpenFOAM.sparsebundle
    FOAM_MOUNT_POINT=$HOME/OpenFOAM
    FOAM_VERSION=$(cat $HOME/.OpenFOAM/OpenFOAM-release)
    if [ ! -f "$HOME/OpenFOAM/OpenFOAM-$FOAM_VERSION/etc/bashrc" ]; then
        hdiutil attach -quiet -mountpoint "$FOAM_MOUNT_POINT" "$FOAM_DISK_IMAGE" &&
                . "$HOME/OpenFOAM/OpenFOAM-$FOAM_VERSION/etc/bashrc"
    else
        source "$HOME/OpenFOAM/OpenFOAM-$FOAM_VERSION/etc/bashrc"
    fi
fi
The first line already existed. I guess I was not supposed to delete this file.
After rebooting my mac and starting Terminal I got the following:
-bash: /Users/kateeisenhower/openfoam-env-setup.sd: No such file or directory
I think the error relates to the first line in my .profile. Do I have to worry about it?
Also i ran the motorBike tutorial and snappyHexMesh worked fine.
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
