[foam-extend.org] extend-3.0 cuda installation
Like Tree8Likes
Old   October 21, 2015, 13:25
Exclamation Foam-extend 3.1 cuda build fails on archlinux
  #41
Paul Handy
phandy is on a distinguished road
Update: I installed Cusp v 0.4.0, and it compiled just fine.
I'm also trying to install v3.1 with cuda on archlinux. I downloaded and extracted the rpm package from https://sourceforge.net/projects/ope...am-extend-3.1/, which already had most things built.
I've installed cuda from community/cuda arch repo, version 7.5.18, and cusp from the arch user repository, version 0.5.1-1.
in prefs.sh, my cuda options are:
export CUDA_SYSTEM=1
export CUDA_DIR=/opt/cuda
export CUDA_BIN_DIR=$CUDA_DIR/bin
export CUDA_LIB_DIR=$CUDA_DIR/lib64
export CUDA_INCLUDE_DIR=$CUDA_DIR/include
export CUDA_ARCH=sm_30
After sourcing $FOAM_INST_DIR/foam-extend-3.1/etc/bashrc, I change to the src/cudaSolvers directory and run:
$ ./Allwmake
Attached are two build logs for my attempts to get a working build. Due to the size of the logs, i gzipped them.
The first, allwmake.txt, comes from my noticing that the *.C files were being compiled with g++ instead of nvcc. Noting this, I decided to move *.C files in cudaSolvers/* to *.cu, and changing any references to their filenames (such as Make/files). The output of that attempt is in allwmakeAttempt1.log. It failed.
Not knowing what modifications @Aleksey_R mentioned in his point,
1. I've downloaded cusplibrary and modified options file as it was mentioned before in this thread.
I went ahead and changed "#include <cusp/blas.h>" to "#include <cusp/blas/blas.h>" in all files, and changed CUDA_LIB_DIR=$CUDA_DIR/lib to CUDA_LIB_DIR=$CUDA_DIR/lib64. I moved the *.cu files previously changed to their original *.C locations and adjusted Make/files to note that.
Unsurprisingly, this build also failed, as it is attempting to use g++ to build cudaSolver.C - a laundry list of errors in all cusp related libraries.
I really wish I could figure out how to get this to compile.
phandy is offline   Reply With Quote
Old   October 22, 2015, 04:20
jipai is on a distinguished road
For information, at the first compilation of foam-ext, I had set compilation options in the c++Opt and cOpt files according to this site :
https://sites.google.com/site/jordim...am-compilation
So I removed the option -march=native in the c++Opt and cOpt files and cudaSolvers compiled successfully.
Hope this message could help
jipai
jipai is offline   Reply With Quote
Old   October 22, 2015, 10:14
Paul Handy
jipai,
I'm glad it worked out for you. What version of cusp and cuda are you using?
Old   October 24, 2015, 04:12
Here are the versions for cusp and cuda :
- cusp 0.4.0
- CUDA Driver Version = 7.5, CUDA Runtime Version = 7.5
Old   August 17, 2018, 09:58
Johannes
Mexes is on a distinguished road
Hi Everybody,
I want to install foam-extend-4.x on my Lenovo T500 but I'm not sure what number I have to put in for the "30" in:
"export CUDA_ARCH=sm_30"
Results for running different commands are:
lspci -vnn | grep VGA -A 12
00:02.0 VGA compatible controller [0300]: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller [8086:2a42] (rev 07) (prog-if 00 [VGA controller])
Subsystem: Lenovo Mobile 4 Series Chipset Integrated Graphics Controller [17aa:20e4]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f4400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 1800 [size=8]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
00:02.1 Display controller [0380]: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller [8086:2a43] (rev 07)
lshw -numeric -C display
*-display:0
Beschreibung: VGA compatible controller
Produkt: Mobile 4 Series Chipset Integrated Graphics Controller [8086:2A42]
Hersteller: Intel Corporation [8086]
Physische ID: 2
Bus-Informationen: pci@0000:00:02.0
Version: 07
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: vga_controller bus_master cap_list rom
Konfiguration: driver=i915 latency=0
Ressourcen: irq:16 memory:f4400000-f47fffff memory:d0000000-dfffffff ioport:1800(Größe=8) memory:c0000-dffff
*-display:1 UNGEFORDERT
Beschreibung: Display controller
Produkt: Mobile 4 Series Chipset Integrated Graphics Controller [8086:2A43]
Physische ID: 2.1
Bus-Informationen: pci@0000:00:02.1
Version: 07
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: bus_master cap_list
Konfiguration: latency=0
Ressourcen: memory:f4200000-f42fffff
glxinfo | grep OpenGL
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Mobile Intel® GM45 Express Chipset x86/MMX/SSE2
OpenGL version string: 2.1 Mesa 18.0.5
OpenGL shading language version string: 1.20
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 18.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
Thanks for your help!
Mexes is offline   Reply With Quote
Old   August 17, 2018, 14:56
Retired Super Moderator
Bruno Santos
Quick answer @Mexes: Your machine does not seem to have an Nvidia graphics card, therefore you should not define anything for that installation step.
Old   August 19, 2018, 17:48
Johannes
Hi Bruno,
thanks for your reply and your help!
[foam-extend.org] A problem about installation of open foam extend 3.1 Toalchemist OpenFOAM Installation 1 May 31, 2018 09:58
[foam-extend.org] problems with openFoam extend 3.0 installation AmirBaqa1987 OpenFOAM Installation 1 December 20, 2016 20:17
problem with RBF in tho Foam 3.0 extend Vesek OpenFOAM Programming & Development 4 June 16, 2014 05:22
ParaView-4.0.1 did not compile for foam extend 3.0 installation mhkenergy OpenFOAM Installation 8 June 4, 2014 03:26
[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 mnobrega OpenFOAM Community Contributions 6 April 1, 2014 02:47
