OpenFOAM tests cases
Old   August 7, 2013, 16:02
Default OpenFOAM tests cases
cfdivan is on a distinguished road
Dear all,
I already installed different versions of Open FOAM and in all of them I was not able to explore too much the potencial of the code. I realized that even in the version that I installed recentelly (2.2.2) I can not work with the motorbike case, once the *.obj file is missing in triSurface folder.
I would like to know if it is related with installation issues, or if I am looking in wrong folder or something else...
Thank you very much for your help!
cfdivan is offline   Reply With Quote
Old   August 8, 2013, 04:53
romant's Avatar
Roman Thiele
romant is on a distinguished road
did you follow the installation instructions on http://openfoam.org/download/ubuntu.php under getting started to get the tutorials into the "run" folder? if not, do so and if you did it this way, navigate into the motorbike folder by typing
run && cd tutorials/mesh/snappyHexMesh/motorBike/
then execute
./Allrun
This should run the motorbike example and copy and run all the files in this case. you can then investigate the case and how it is run by looking into the file Allrun inside the folder. It will show you all the things that need to be executed in order to run this case.
~roman
romant is offline   Reply With Quote
Old   August 14, 2013, 16:33
Hi Roman,
Sorry for the delay replying you.
./All run, and now it is working.
Thanks a lot!
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 06:43
Convertation axisymmetric cases from Fluent to OpenFOAM Svensson OpenFOAM 0 April 19, 2011 07:08
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 14:14
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
