Ubuntu 13.04 - Allwmake - enviromentvariables |
July 21, 2013, 23:28 |
Hi all,
sorry, but I'm a little stuck with this message as I'm trying to building OpenFoam 2.1.x on a 13.04 Ubuntu 64-bit. OpenFOAM/OpenFOAM-2.1.x/Allwmake: 4: OpenFOAM/OpenFOAM-2.1.x/Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. I can't translate the message error very well, but it seems different things: 1 - what is wmakeCheckPwd: not found? 2 - how can I set up environment variables properly? 3 - where can I find, what should I look for, about the dot-iles the system is telling me? How can I source them? I checked my bashrc file, and it seems properly wrtitten, maybe I?missing something, but I don't know what to lok for. thanks very much for anyone want to help!!!!! Regards Michele Last edited by student666; July 21, 2013 at 23:38. Reason: Missing some explanation on bashrc file |
July 22, 2013, 06:33 |
I think it could be of help to solve my problem if I post my bashrc file.
Maybe someone can help me eith that? Code:
#----------------------------------*-sh-*-------------------------------------- # ========= | # \\ / F ield | OpenFOAM: The Open Source CFD Toolbox # \\ / O peration | # \\ / A nd | Copyright (C) 2011 OpenFOAM Foundation # \\/ M anipulation | #------------------------------------------------------------------------------ # License # This file is part of OpenFOAM. # # OpenFOAM is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # OpenFOAM is distributed in the hope that it will be useful, but WITHOUT # ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or # FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License # along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. # # File # etc/bashrc # # Description # Startup file for OpenFOAM # Sourced from ~/.profile or ~/.bashrc # Should be usable by any POSIX-compliant shell (eg, ksh) # #------------------------------------------------------------------------------ export WM_PROJECT=OpenFOAM export WM_PROJECT_VERSION=2.1.x ################################################################################ # USER EDITABLE PART: Changes made here may be lost with the next upgrade # # either set $FOAM_INST_DIR before sourcing this file or set # 'foamInstall' below to where OpenFOAM is installed # # Location of the OpenFOAM installation # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ foamInstall=$HOME/$WM_PROJECT # foamInstall=~$WM_PROJECT # foamInstall=/opt/$WM_PROJECT # foamInstall=/usr/local/$WM_PROJECT # # END OF (NORMAL) USER EDITABLE PART ################################################################################ # # These are the defaults for this version which should generally be # overridden from the prefs.sh file or from command-line specification # #- note the location for later use (eg, in job scripts) : ${FOAM_INST_DIR:=$foamInstall}; export FOAM_INST_DIR #- Compiler location: # foamCompiler= system | ThirdParty (OpenFOAM) foamCompiler=system #- Compiler: # WM_COMPILER = Gcc | Gcc43 | Gcc44 | Gcc45 | Gcc46 | Clang | Icc (Intel icc) export WM_COMPILER=Gcc unset WM_COMPILER_ARCH WM_COMPILER_LIB_ARCH #- Architecture: # WM_ARCH_OPTION = 32 | 64 export WM_ARCH_OPTION=64 #- Precision: # WM_PRECISION_OPTION = DP | SP export WM_PRECISION_OPTION=DP #- Optimised, debug, profiling: # WM_COMPILE_OPTION = Opt | Debug | Prof export WM_COMPILE_OPTION=Opt #- MPI implementation: # WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI # | GAMMA | MPI | QSMPI export WM_MPLIB=OPENMPI #- Operating System: # WM_OSTYPE = POSIX | ??? export WM_OSTYPE=POSIX #- Floating-point signal handling: # set or unset export FOAM_SIGFPE= #- memory initialisation: # set or unset #export FOAM_SETNAN= ################################################################################ # The old dirs to be cleaned from the various environment variables # - remove anything under top-level directory. # NB: the WM_PROJECT_INST_DIR might not be identical between versions foamOldDirs="$FOAM_INST_DIR $WM_PROJECT_SITE $HOME/$WM_PROJECT/$USER" if [ "$WM_PROJECT_INST_DIR" != "$FOAM_INST_DIR" ] then foamOldDirs="$WM_PROJECT_INST_DIR $foamOldDirs" fi # Location of installation # ~~~~~~~~~~~~~~~~~~~~~~~~ export WM_PROJECT_INST_DIR=$FOAM_INST_DIR export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION # Location of third-party software # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ export WM_THIRD_PARTY_DIR=$WM_PROJECT_INST_DIR/ThirdParty-$WM_PROJECT_VERSION # Location of site-specific templates etc # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ # unset is equivalent to $WM_PROJECT_INST_DIR/site if [ -d "$WM_PROJECT_SITE" ] then export WM_PROJECT_SITE else unset WM_PROJECT_SITE fi # Location of user files # ~~~~~~~~~~~~~~~~~~~~~~ export WM_PROJECT_USER_DIR=$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION # Source files, possibly with some verbosity _foamSource() { while [ $# -ge 1 ] do [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "Sourcing: $1" . $1 shift done } # Evaluate command-line parameters _foamEval() { while [ $# -gt 0 ] do case "$1" in -*) # stray option (not meant for us here) -> get out break ;; *=) # name= -> unset name [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "unset ${1%=}" eval "unset ${1%=}" ;; *=*) # name=value -> export name=value [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "export $1" eval "export $1" ;; *) # filename: source it if [ -f "$1" ] then _foamSource "$1" else _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile -silent "$1"` fi ;; esac shift done } # Add in preset user or site preferences: _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile prefs.sh` # Evaluate command-line parameters and record settings for later # these can be used to set/unset values, or specify alternative pref files export FOAM_SETTINGS="$@" _foamEval $@ # Clean standard environment variables (PATH, LD_LIBRARY_PATH, MANPATH) # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ foamClean=$WM_PROJECT_DIR/bin/foamCleanPath #- Clean PATH cleaned=`$foamClean "$PATH" "$foamOldDirs"` && PATH="$cleaned" #- Clean LD_LIBRARY_PATH cleaned=`$foamClean "$LD_LIBRARY_PATH" "$foamOldDirs"` \ && LD_LIBRARY_PATH="$cleaned" #- Clean MANPATH cleaned=`$foamClean "$MANPATH" "$foamOldDirs"` && MANPATH="$cleaned" export PATH LD_LIBRARY_PATH MANPATH # Source project setup files # ~~~~~~~~~~~~~~~~~~~~~~~~~~ _foamSource $WM_PROJECT_DIR/etc/config/settings.sh _foamSource $WM_PROJECT_DIR/etc/config/aliases.sh # Source user setup files for optional packages # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/paraview.sh` _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/ensight.sh` # Clean environment paths again. Only remove duplicates # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #- Clean PATH cleaned=`$foamClean "$PATH"` && PATH="$cleaned" #- Clean LD_LIBRARY_PATH cleaned=`$foamClean "$LD_LIBRARY_PATH"` && LD_LIBRARY_PATH="$cleaned" #- Clean MANPATH (trailing ':' to find system pages) cleaned=`$foamClean "$MANPATH"`: && MANPATH="$cleaned" export PATH LD_LIBRARY_PATH MANPATH #- Clean LD_PRELOAD if [ -n "$LD_PRELOAD" ] then cleaned=`$foamClean "$LD_PRELOAD"` && LD_PRELOAD="$cleaned" export LD_PRELOAD fi # cleanup environment: # ~~~~~~~~~~~~~~~~~~~~ unset cleaned foamClean foamInstall foamOldDirs unset _foamSource _foamEval # ----------------------------------------------------------------- end-of-file source $HOME/OpenFOAM/OpenFOAM-2.2.x/etc/bashrc Last edited by student666; July 23, 2013 at 13:59. |
July 22, 2013, 08:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Michele,
You're trying to build 2.1.x, but you've specified in "~/.bashrc" to source 2.2.x. And please use the "[CODE]" markers for posting code, as indicated in the second link on my signature. Best regards, Bruno
July 22, 2013, 11:25 |
Hi Bruno,
yes you were right, I didn't see it, but the problem still remains. I don't know exactly how to set the correct path. How can't it find the wmakeCheckPwd? How canI set it up? Code:
OpenFOAM/OpenFOAM-2.1.x/Allwmake: 4: OpenFOAM/OpenFOAM-2.1.x/Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR Sorry for previous reply, now I know how to do it. ([CODE]) Last edited by student666; July 22, 2013 at 11:27. Reason: Step performed ( updating / closing / reopening of terminal) |
allwmake, installation of open foam, ubuntu 13.04 |
paraFoam command no longer working after upgrading to Ubuntu 13.04 | c_dowd | OpenFOAM Installation | 9 | June 24, 2013 08:28 |
Installation on ubuntu 13.04 | mvee | OpenFOAM Installation | 7 | June 22, 2013 16:02 |
Compilation Error 1 (Allwmake) on Ubuntu 11.04 | freemankofi | OpenFOAM Installation | 12 | June 14, 2011 06:10 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
