openfoam installed but refuse to start.
Old   June 25, 2013, 04:53
Default openfoam installed but refuse to start.
izna O'connor
izna is on a distinguished road
Hello..
i am a user of openfoam for quite some time.
recently due to my PC crashed i had to install openfoam again.
i install it correctly using this:
http://www.openfoam.org/download/ubuntu.php
but when i add the
At the bottom of that file, add the following line (see Note 1) and save the file source /opt/openfoam220/etc/bashrc
i get the following errors:
bash: /home/user/OpenFOAM/openfoam220/bin/foamEtcFile: No such file or directory
bash: /home/user/OpenFOAM/openfoam220/bin/foamCleanPath: No such file or directory
bash: /home/user/OpenFOAM/openfoam220/etc/config/settings.sh: No such file or directory
bash: /home/user/OpenFOAM/openfoam220/etc/config/aliases.sh: No such file or directory
then when i run icoFoam i get the error
user@user-MS-7592:~$ icoFoam -help
icoFoam: command not found
can anyone guide me please
izna is offline   Reply With Quote
Old   June 25, 2013, 18:20
Retired Super Moderator
Bruno Santos
Quick answer - Please check if the following thread: http://www.cfd-online.com/Forums/ope...ses-start.html
Old   July 4, 2013, 06:11
zaynah K.
zaynah04 is on a distinguished road
hello
My problem is strange one
i have installed successfully openfoam//
but when i do icoFoam -help
i get the following error..
when i check in Opt i see my openfoam and all folders etc..
so why the command is not seen?
zaynah04 is offline   Reply With Quote
Old   July 6, 2013, 03:15
izna O'connor
my mistake was in adding the line to the bash file..
after successfully adding this line it all turns out fine..
Thanks
Old   July 7, 2013, 06:19
Bruno Santos
Greetings to all!
@zaynah04:
Please read the following blog post: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
[OpenFOAM.com] Moving already Installed OpenFOAM to different machine (user) lokendra OpenFOAM Installation 16 January 28, 2019 06:35
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 12:51
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 12:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
