[OpenFOAM.org] openfoam-2.2.0 installation on cluster of Redhat 4.1.2-48 |
October 26, 2013, 13:08 |
#21 | |
Yijiu Jiang
Rep Power: 13 |
Thanks Bruno, I think that's the reason. Unfortunately, I did use the option "WM_MPLIB=SYSTEMOPENMPI". The which mpirun gave me this: /usr/lib64/openmpi/bin/mpirun So, I think I need to modify the following section in $Home/OpenFoam/OpenFoam-2.2.0/etc/bashrc ------------------------------------------------------------------------------------------------------------------------------- #- MPI implementation: # WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI # | GAMMA | MPI | QSMPI | SGIMPI export WM_MPLIB=OPENMPI -------------------------------------------------------------------------------------------------------------------------------- Is this the right reason of my problem? Do you have any idea on solving this? Best regards, JYJ |
October 26, 2013, 13:57 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi JYJ,
Here's what you should do:
Bruno
October 27, 2013, 00:26 |
#23 | |
Yijiu Jiang
Rep Power: 13 |
I followed your suggestion and edited .bashrc. Now it is as the following: (jaq526 is the user's name) # .bashrc # Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi source $HOME/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc # User specific aliases and functions module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc module load openmpi-x86_64 module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45 module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45 Then, I re-did the steps from step 8 of the instruction. But when I conducted ./Allwmake, it gave me this: ERROR: ParaView not found in /home/jaq526/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/paraview-3.12.0 Now, I have no idea on this |
October 27, 2013, 04:14 |
#24 |
Bruno Santos
Rep Power: 128 |
OK, first of all, let's do some clean up on the "~/.bashrc" file. Change this:
# Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi source $HOME/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc # User specific aliases and functions module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc module load openmpi-x86_64 module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45 module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45 Code:
# Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi # User specific aliases and functions module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45
Last edited by wyldckat; October 27, 2013 at 04:15. Reason: Fixed broken [CODE] marker |
October 27, 2013, 09:46 |
#25 | |
Yijiu Jiang
Rep Power: 13 |
Bruno, I modified the .bashrc. But there is not any message when I start a new terminal after I did the .bashrc modification. Now, the file is as follows Code:
# .bashrc # Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi # User specific aliases and functions module load openmpi-x86_64 source /home/jaq526/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4 foamCompiler=ThirdParty WM_COMPILER=Gcc45 Last edited by wyldckat; October 27, 2013 at 15:38. Reason: Added [CODE][/CODE] |
October 27, 2013, 15:45 |
#26 | |
Bruno Santos
Rep Power: 128 |
I think so! Let's go by parts. First take care of confirming if OpenFOAM is well built, by following the step #8. If possible, package the "make.log" file as explained in step #9, and attach the file to your next post, because I want to confirm if everything is OK on OpenFOAM's end. Then for step #11, run makeParaView like this: Code:
./makeParaView -qmake $(which qmake-qt4) > make.pv.log 2>&1
October 28, 2013, 11:39 |
#27 | |
Yijiu Jiang
Rep Power: 13 |
Hi Bruno, I re-did the steps as you told me. The make.log and make.pv.log are packaged and attached here. But seems haven't solved the problem. The error "ERROR: ParaView not found in /home/jaq526/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/paraview-3.12.0" still exits when I conduct ./Allwmake. Please help to check the log file. Thank you. |
October 28, 2013, 17:03 |
#28 |
Bruno Santos
Rep Power: 128 |
Hi JYJ,
qmake-qt4 wasn't found, which is why it didn't even try to build ParaView. Try running these two commands: Code:
which qmake-qt4 which qmake If the second one does show something, then you can run: Code:
./makeParaView -qmake $(which qmake) > make.pv.log 2>&1 Best regards, Bruno
October 28, 2013, 23:15 |
#29 | |
Yijiu Jiang
Rep Power: 13 |
Yes, Bruno. You are right. qt-4 hasn't been built successfully. I tried to find out the problem today. I found this information in mkqt.log Code:
You might need to modify the include and library search paths by editing QMAKE_INCDIR_X11 and QMAKE_LIBDIR_X11 in /home/jaq526/OpenFOAM/ThirdParty-2.2.0/qt-everywhere-opensource-src-4.6.4/mkspecs/linux-g++-64. Code:
MAKEFILE_GENERATOR = UNIX TEMPLATE = app CONFIG += qt warn_on release incremental link_prl QT += core gui QMAKE_INCREMENTAL_STYLE = sublib QMAKE_CFLAGS = -m64 QMAKE_LFLAGS = -m64 include(../common/g++.conf) include(../common/linux.conf) QMAKE_LIBDIR_X11 = /usr/X11R6/lib64 QMAKE_LIBDIR_OPENGL = /usr/X11R6/lib64 load(qt_config) |
October 28, 2013, 23:27 |
#30 |
Yijiu Jiang
Rep Power: 13 |
Here is the mkqt.log. You can see the error which I mentioned above.
October 29, 2013, 19:01 |
#31 |
Bruno Santos
Rep Power: 128 |
Hi JYJ,
I know I've had this problem before... and it ended up in not having to do anything with the X11. Check the contents of the file "qt-everywhere-opensource-src-4.6.4/mkspecs/common/g++.conf". The references to "gcc" and "g++" should indicate "gcc44" and "g++44" or whichever name your custom build of GCC is using, such as "gcc-4.5" and "g++-4.5". Best regards, Bruno
October 30, 2013, 11:44 |
#32 | |
Yijiu Jiang
Rep Power: 13 |
Bruno, This problem has been solved. I really appreciate your help in the past days. Thanks. Best regards, Yijiu |
June 10, 2015, 13:53 |
$MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.6.3 no yes
#33 |
Hasan K.J.
Rep Power: 15 |
Hello Everyone,
I have tried to install OpenFOAM on my personal Drive on my Cluster OpenFOAM 2.1.0 worked but when running simulations some simulations are just stuck on iterations I have no clue as to why (Problem 1) and here is the test Log Code:
Executing /panfs/panasas01/aero/mk14466/OpenFOAM/OpenFOAM-2.1.0/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: newblue3 OS: Linux version 2.6.32-220.23.1.el6.x86_64 ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /panfs/panasas01/aero/mk14466/OpenFOAM yes yes $WM_PROJECT_USER_DIR .../aero/mk14466/OpenFOAM/mk14466-2.1.0 no no $WM_THIRD_PARTY_DIR ...ro/mk14466/OpenFOAM/ThirdParty-2.1.0 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR ...aero/mk14466/OpenFOAM/OpenFOAM-2.1.0 yes yes yes $FOAM_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN .../2.1.0/platforms/linux64GccDPOpt/bin no no $FOAM_USER_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin no no $WM_DIR ...k14466/OpenFOAM/OpenFOAM-2.1.0/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib yes yes yes $FOAM_SITE_LIBBIN .../2.1.0/platforms/linux64GccDPOpt/lib no no $FOAM_USER_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib no no $MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.5.3 yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.4.7 /usr/bin/gcc gzip 1.3.12 /bin/gzip tar 1.23 /bin/tar icoFoam 2.1.0 ...M/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. Done Code:
Executing /panfs/panasas01/aero/mk14466/OpenFOAM/OpenFOAM-2.2.0/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: newblue3 OS: Linux version 2.6.32-220.23.1.el6.x86_64 ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /panfs/panasas01/aero/mk14466/OpenFOAM yes yes $WM_PROJECT_USER_DIR .../aero/mk14466/OpenFOAM/mk14466-2.2.0 no no $WM_THIRD_PARTY_DIR ...ro/mk14466/OpenFOAM/ThirdParty-2.2.0 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR ...aero/mk14466/OpenFOAM/OpenFOAM-2.2.0 yes yes yes $FOAM_APPBIN ...-2.2.0/platforms/linux64GccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN .../2.2.0/platforms/linux64GccDPOpt/bin no no $FOAM_USER_APPBIN ...-2.2.0/platforms/linux64GccDPOpt/bin no no $WM_DIR ...k14466/OpenFOAM/OpenFOAM-2.2.0/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-2.2.0/platforms/linux64GccDPOpt/lib yes yes yes $FOAM_SITE_LIBBIN .../2.2.0/platforms/linux64GccDPOpt/lib no no $FOAM_USER_LIBBIN ...-2.2.0/platforms/linux64GccDPOpt/lib no no $MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.6.3 no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.4.7 /usr/bin/gcc gzip 1.3.12 /bin/gzip tar 1.23 /bin/tar icoFoam 2.2.0 ...M/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. Done Code:
$MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.6.3 no yes how to make this an yes If you require anything else please do let me know. Thanks for your time and Efforts, Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
clusters, installation |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
OpenFOAM 2.2.0 installation on ICC (Intel C++ Compiler) | vishal3 | OpenFOAM Installation | 3 | April 26, 2013 21:00 |
OpenFOAM 2.2.0 installation on scientific-linux | kulkarni Harshawardhan | OpenFOAM Installation | 1 | March 20, 2013 14:38 |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 05:29 |
OpenFoam 2.0.0 installation + ICC + Rocks Cluster | chinper | OpenFOAM Installation | 5 | July 13, 2011 17:00 |
