[OpenFOAM.org] OpenFOAM build on Intel Xeon Phi
Like Tree13Likes
Old   May 29, 2013, 18:40
Default OpenFOAM build on Intel Xeon Phi
asaijo is on a distinguished road
Hi, foamers.
Today, I'd like to report my experience on building an OpenFOAM native MPI solver on Xeon Phi (Intel's co-processor and accelalator parts of the next world fastest supercomputer.)
Building OpenFOAM for Xeon Phi is bit tricky, but not difficult.
1. Make Zlib and Flex for Xeon Phi
2. Set OpenFOAM bashrc/setting.sh to linux64Icc and INTEL MPI
3. Make wmake only
4. Add -mmic to wmake/rules/linux64ICC/{c, c++}
5. Compile OpenFOAM libraries. If compilation fails, add Zlib/Flex path to Make/options
6. Compile solver applicaitions. You'll get many undefined function errors. Then use mpiicpc compiler (not icpc) and add -Wl,rpath-link flag for appropirate library's path by manual.
Finally, I got icoFoam for Xeon Phi. Perhaps there is an easier and canonical way.
I use Xeon Phi 5110P model. It has phisically 60 cores appeared as virtually 240 cores by Intel's Hyperthreading technology and 8GB GDDR5 memory.
The benchmark case is 3 dimensional caivty flow (modified from icoFoam's tutorial case) and I varied the MPI processes from 30 to 240.
Benchmark conditions:
Modified icoFoam tutorial cavity case (OpenFOAM-2.2.0)
3D cavity problem, deltaT = 1e-4, 50 time steps
Problem size: SMALL: (90x90x90) LEFT AXIS , LARGE: (175,175,175) RIGHT AXIS
CXXFLAGS = -mmic -O2 -no-prec-div
Domain decomposed by scotch
This is the result:
http://www.cfd-online.com/Forums/att...1&d=1369863305
You can compare figures with your own results.
Running an OpenFOAM solver on Xeon Phi without any source code modification is possible. But if you want the performance coressponding to the price, you should optimize your code.
Cheers.
-- asaijo
asaijo is offline   Reply With Quote
Old   May 30, 2013, 00:04
luchen
luchen2408 is on a distinguished road
hello,asaijo, I am intrested in your computer, can you tell me how do you set the configuration for the computer? is it the same as in normal computer? have you conduct some simulations?what about the performace?
Besides, did you use NVIDIA Tesla K20 Architecture with CUDA-Option for simulation? did you compare the performance of NVIDIA Tesla K20 Architecture with CUDA-Option or the Intel Xeon Phi Technology? thanks
luchen2408 is offline   Reply With Quote
Old   May 31, 2013, 14:49
Hi, luchen2408.
The machine is normal and standard server, bought from local vendor.
Basic configurations has been set by the vendor. But I had to install a compiler, libraries and do extra tweaks for use.
I haven't used the K20X yet.
Regards.
Old   June 2, 2013, 09:54
luchen
hello,asaijo,thanks for your reply, can I take the Xeon Phi computer as a normal computer with many cores? and can I intall the software openfoam like an normal computer and use the same command in a normal multi-cores computer? thanks
Old   June 3, 2013, 00:47
Qiao
kimbaol is on a distinguished road
hi, asaijo
I have got an Intel Xeon Phi card and want to build an OpenFOAM native MPI solver on it. I just did as your instruction, and got some problems. Can you tell me more details? Such as:
1. Make Zlib and Flex for Xeon Phi ----------This step is install Zlib and Flex on the host PC, am i right?
2. Set OpenFOAM bashrc/setting.sh to linux64Icc and INTEL MPI --i have done this step
3. Make wmake only
4. Add -mmic to wmake/rules/linux64ICC/{c, c++} -----i have done this
5. Compile OpenFOAM libraries. If compilation fails, add Zlib/Flex path to Make/options -------in directory ~/OpenFOAM/src, i run ./Allwmake, and got some errors, how did you add Zlib/Flex path to Make/options? Is the file Make/option refers to the file ~/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/Make/options?
Thanks very much!
kimbaol is offline   Reply With Quote
Old   June 3, 2013, 07:14
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Dear Asaijo.
thanks for sharing your results. really interesting, and I'm impressed by them.
also, for the sake of comparison, are you using the standard fvscheme and fvsolution?
thanks in advance, i'd love to put my hands on one of those beauties...
http://www.leadingedge.it/
Naval architecture and CFD consultancy
Last edited by sail; June 3, 2013 at 07:17. Reason: haven't read accurately enough what whas written by the OP
sail is offline   Reply With Quote
Old   September 13, 2013, 01:18
Default Is 5110p really worth it?
kokizzu is on a distinguished road
Asaijo, can you tell me how the performance using maximum processor core without xeon phi and with xeon phi, i want to know if Xeon Phi really worth it.
kokizzu is offline   Reply With Quote
Old   October 15, 2013, 14:13
Robert
lordvon is on a distinguished road
Update:
The 'ld' linker has a problem with the .o files being compiled with -mmic flag. If I get rid of the -mmic flag, the ld command does not give the error. Of course, this is not what we want to do. Do I need to set ld architecture somehow???
I ran into the following " could not read symbols: File in wrong format" problem while trying to compile using the steps in the first post (I am on step 5, and I did add zlib and flex to Make/options to get rid of those errors).
I went into the OSspecific/POSIX/ directory to compile it manually, but it made no difference.
ld -r -o /home/lordvon/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64IccDPOpt/lib/libOSspecific.o Make/linux64IccDPOpt/sigFpe.o Make/linux64IccDPOpt/sigSegv.o Make/linux64IccDPOpt/sigInt.o Make/linux64IccDPOpt/sigQuit.o Make/linux64IccDPOpt/sigStopAtWriteNow.o Make/linux64IccDPOpt/sigWriteNow.o Make/linux64IccDPOpt/regExp.o Make/linux64IccDPOpt/timer.o Make/linux64IccDPOpt/fileStat.o Make/linux64IccDPOpt/POSIX.o Make/linux64IccDPOpt/cpuTime.o Make/linux64IccDPOpt/clockTime.o Make/linux64IccDPOpt/memInfo.o Make/linux64IccDPOpt/fileMonitor.o Make/linux64IccDPOpt/printStack.o
ld: Make/linux64IccDPOpt/sigFpe.o: Relocations in generic ELF (EM: 181)
Make/linux64IccDPOpt/sigFpe.o: could not read symbols: File in wrong format
make: *** [/home/lordvon/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64IccDPOpt/lib/libOSspecific.o] Error 1
I am using Red Hat Enterprise Linux Server release 6.4 (Santiago)
Please help!
sigFpe.o compiled fine, by the way via:
SOURCE=signals/sigFpe.C ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O2 -no-prec-div -DNoRepository -IlnInclude -I. -I/home/lordvon/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/home/lordvon/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude -fPIC -mmic -c $SOURCE -o Make/linux64IccDPOpt/sigFpe.o
lordvon is offline   Reply With Quote
Old   October 20, 2013, 04:58
Default Cannot compile
Dennis
Dennis3 is on a distinguished road
Hi everyone,
First of all I would like to say thank you for sharing the information.
I have a problem compiling OpenFOAM to work on Xeon Phi. After that I added -mmic to the c and c++ file in wmake/rules/linux64Icc/, the compilation fails and I receive this error message everywhere in the log:
icpc: command line error: option '-xHost' not supported
If I remove -mmic everything works fine, anyone know that the problem is ?
Dennis3 is offline   Reply With Quote
Old   October 24, 2013, 14:20
Default cpu comparison
kostyfisik is on a distinguished road
May be I am wrong, by I will try compare results. There is some data
http://www.hector.ac.uk/cse/distribu...am/node17.html and from topic starter
Xeon Phi for 50 time steps
grid size - 90^3 - 175^3
best time - 200s - 1500 s
Hectors 4 core of AMD 2.8GHz dual-core Opteron 5 time steps
grid size - 100^3 - 200^3
time - 795s - 8800 s
Hectors 1024 core of AMD 2.8GHz dual-core Opteron 40 time steps
grid size - 200^3
time - 1490 s
So, single Xeon Phi card for OpenFOAM is compatible with 1024 core cluster (for this benchmark)
kostyfisik is offline   Reply With Quote
Old   May 12, 2014, 02:58
Hi, i have done step 1 and 2..
how to do the third step?
3. Make wmake only
Old   May 15, 2014, 22:27
Unhappy
  #12
Hi, i got an error while doing these steps:
# CentOS 6.5
# OpenFoam 2.2.2
2. change etc/bashrc
export WM_COMPILER=Icc
export WM_MPLIB=INTEL_MPI
3. clean old compilation
source etc/bashrc
wcleanAll ; wcleanLnIncludeAll ; wcleanMachine
4a. add -mmic
edit wmake/rules/linux64ICC/c
cFLAGS      = $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -fPIC -mmic
4b. add -mmic
edit wmake/rules/linux64ICC/c++
c++FLAGS    = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -mmic
4c. remove -xHost (conflict with -mmic)
vim wmake/rules/linux64Icc/c++Opt
c++OPT      = -O2 -no-prec-div
5. build for XeonPhi
./Allwmake
the errors:
icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O2 -no-prec-div  -DNoRepository -I/root/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.2.2/src/OSspecific/POSIX/lnInclude   -fPIC -mmic -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64IccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o Make/linux64IccDPOpt/solidEquilibriumDisplacementFoam.o -L/root/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64IccDPOpt/lib \
             -lfiniteVolume -lOpenFOAM -ldl   -L/lib -lm -o /root/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64IccDPOpt/bin/solidEquilibriumDisplacementFoam
x86_64-k1om-linux-ld: cannot find -lfiniteVolume
x86_64-k1om-linux-ld: cannot find -lOpenFOAM
make[2]: *** [/root/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64IccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1
make[2]: Leaving directory `/root/OpenFOAM/OpenFOAM-2.2.2/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/root/OpenFOAM/OpenFOAM-2.2.2/applications/solvers/stressAnalysis'
make: *** [stressAnalysis] Error 2
make: Target `application' not remade because of errors.
Old   May 17, 2014, 15:06
Retired Super Moderator
Bruno Santos
Greetings to all!
@kokizzu: I don't have access to a Xeon Phi, so I have no experience with it.
Nonetheless, I have a lot of experience building OpenFOAM from source code, so here's what I can say regarding your latest post: when build OpenFOAM, usually the very first error that occurs is the one that tells the whole story. If you run Allwmake like this:
./Allwmake > log.make 2>&1
you'll get a complete log file named "log.make" with the output of running this script. Then you can more easily search for the first error or errors. If you provide the output for the first error or errors, it'll be much easier to help.
Best regards,
Bruno
Old   May 18, 2014, 07:31
Default undefined reference to `__intel_sse4_atol'
  #14
Hi, I'm building OpenFOAM for Intel MIC (Xeon Phi), but i got this error:
icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository -I.. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/twoPhaseMixture/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/interfaceProperties/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/incompressible/turbulenceModel -I/root/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/fvOptions/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64IccDPOpt/porousInterFoam.o -L/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib \
             -ltwoPhaseMixture -linterfaceProperties -ltwoPhaseProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -lOpenFOAM -ldl   -L/lib -lm -o /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/bin/porousInterFoam
ld: warning: libimf.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libtwoPhaseMixture.so, not found (try using -rpath or -rpath-link)
ld: warning: libsvml.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libtwoPhaseMixture.so, not found (try using -rpath or -rpath-link)
ld: warning: libirng.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libtwoPhaseMixture.so, not found (try using -rpath or -rpath-link)
ld: warning: libintlc.so.5, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libtwoPhaseMixture.so, not found (try using -rpath or -rpath-link)
/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libtriSurface.so: undefined reference to `__intel_sse4_atol'
My setup:
vim etc/bashrc
export WM_MPLIB=
vim wmake/rules/linuxIcc/c
cFLAGS      = $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -KPIC -mmic
vim wmake/rules/linuxIcc/c++
c++FLAGS    = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -KPIC -mmic
vim wmake/rules/linuxIcc/c++Opt
source etc/bashrc
./Allwmake
Is it because I don't have Intel MKL installed?
the libimf.so was found here
/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic/libimf.so
/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/ia32/libimf.so
/opt/intel/composer_xe_2013_sp1.1.106/compiler/lib/intel64/libimf.so
/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/libimf.so
/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/ia32/libimf.so
/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64/libimf.so
where should I put the -rpath or -rpath-link flags?
or should i run
/opt/intel/composer_xe_2013_sp1.2.144/bin/compilervars_arch.sh mic
first?
Old   May 18, 2014, 14:20
Bruno Santos
Try running the last command like this instead:
source /opt/intel/composer_xe_2013_sp1.2.144/bin/compilervars_arch.sh mic
This way the environment variables are loaded onto the shell environment.
Beyond this, it does look like you're reaching the step #6 on the first post by asaijo:
Try these commands:
cd $FOAM_SOLVERS/multiphase/interFoam/porousInterFoam
mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository -I.. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/twoPhaseMixture/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/interfaceProperties/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/incompressible/turbulenceModel -I/root/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/fvOptions/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64IccDPOpt/porousInterFoam.o -L/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib \
-ltwoPhaseMixture -linterfaceProperties -ltwoPhaseProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -lOpenFOAM -ldl   -L/lib -lm -L/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/ -o /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/bin/porousInterFoam
This essentially does what asaijo specified, namely:
  1. Go to the solver's source code folder.
  2. The last 2 lines before the error messages you got, have the complete link command that wmake uses.
  3. Use mpiicpc for building the solver, instead of icpc.
  4. I didn't use the "-Wl,rpath-link" option and used instead:
Old   May 23, 2014, 16:32
Hi, I've tried that, but still the same errors occured, when I added
-I/opt/intel/impi/4.1.3.049/mic/include/
after -mmic, it shows:
wclean mpi
wmake libso mpi
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file UIPread.C
could not open file mpi.h for source file UIPread.C due to No such file or directory
Making dependency list for source file UOPwrite.C
could not open file mpi.h for source file UOPwrite.C due to No such file or directory
Making dependency list for source file UPstream.C
could not open file mpi.h for source file UPstream.C due to No such file or directory
Making dependency list for source file PstreamGlobals.C
could not open file mpi.h for source file PstreamGlobals.C due to No such file or directory
SOURCE=UOPwrite.C ;  mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository   -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOptINTEL_MPI/UOPwrite.o
SOURCE=UIPread.C ;  mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository   -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOptINTEL_MPI/UIPread.o
SOURCE=UPstream.C ;  mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository   -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOptINTEL_MPI/UPstream.o
SOURCE=PstreamGlobals.C ;  mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -xHost -O2 -no-prec-div  -DNoRepository   -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOptINTEL_MPI/PstreamGlobals.o
ld: skipping incompatible /opt/intel/impi/4.1.3.049/mic/lib/libmpigc4.so when searching for -lmpigc4
ld: skipping incompatible /opt/intel/impi/4.1.3.049/mic/lib/libmpigc4.a when searching for -lmpigc4
ld: cannot find -lmpigc4
make: *** [/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/dummy/libPstream.so] Error 1
If I tried without using MPI, it shows something like this:
make: *** [/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOSspecific.o] Error 1
Hi, thanks for replying, here's my full configuration for the last error:
yum install boost-devel
cd ~/OpenFOAM/OpenFOAM-2.3.0
# edit etc/bashrc
export WM_MPLIB=
source etc/bashrc
# edit wmake/rules/linux*Icc/c
cFLAGS      = $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -fPIC -mmic -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/
# edit wmake/rules/linux*Icc/c++
c++FLAGS    = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -mmic -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/
# edit wmake/rules/linux64Icc/c++Opt
CC          = mpiicpc -std=c++0x
# edit wmake/rules/linuxIA64Icc/c++
CC          = mpiicpc
# edit wmake/rules/linuxIcc/c++
# edit wmake/rules/*Icc/c
# edit wmake/rules/*Icc/c++
# add on LINK_LIBS
-L/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/ -L/opt/crtdc/micgnu/lib/
source /opt/intel/impi/4.1.3/mic/bin/mpivars.sh
./Allwmake > errors.log 2>&1 &
tail -f errors.log
Last edited by wyldckat; May 26, 2014 at 10:23. Reason: merged 3 posts that were a few minutes apart
Old   May 24, 2014, 05:05
Hi, i got exactly same problem, and I tried using this command:
cd ~/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX
mkdir Make/linux64IccDPOpt/
SOURCE=signals/sigFpe.C ; icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O2 -no-prec-div -DNoRepository -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/containers/Lists/UList/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/containers/Lists/UList/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/bools/bool/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/pTraits  -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/ints/label/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/direction/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/chars/char/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/ints/int/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/strings/word/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/strings/string/ -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/primitives/hashes/Hasher/ -fPIC -mmic -c $SOURCE -o Make/linux64IccDPOpt/sigFpe.o -I../../OpenFOAM/primitives/ints/uLabel -I../../OpenFOAM/primitives/ints/uint -I../../OpenFOAM/db/error -I../../OpenFOAM/db/IOstreams/Sstreams -I../../OpenFOAM/db/IOstreams/IOstreams -I../../OpenFOAM/primitives/Scalar/scalar -I../../OpenFOAM/primitives/Scalar/floatScalar -I../../OpenFOAM/primitives/Scalar -I../../OpenFOAM/primitives/VectorSpace -I../../OpenFOAM/primitives/Scalar/doubleScalar -I../../OpenFOAM/primitives/strings/fileName -I../../OpenFOAM/primitives/strings/keyType -I../../OpenFOAM/primitives/Swap -I../../OpenFOAM/containers/Lists/List -I../../OpenFOAM/primitives/contiguous -I../../OpenFOAM/db/IOstreams/token -I../../OpenFOAM/memory/refCount -I../../OpenFOAM/db/typeInfo -I../../OpenFOAM/global/debug -I../../OpenFOAM/db/runTimeSelection/construction -I../../OpenFOAM/memory/autoPtr -I../../OpenFOAM/containers/HashTables/HashTable -I../../OpenFOAM/memory/Xfer -I../../OpenFOAM/containers/Lists/FixedList -I../../OpenFOAM/primitives/hashes/Hash -I../../OpenFOAM/primitives/strings/wordRe -I../../OpenFOAM/containers/LinkedLists/user -I../../OpenFOAM/containers/LinkedLists/accessTypes/LList -I../../OpenFOAM/containers/LinkedLists/linkTypes/SLListBase -I../../OpenFOAM/containers/Lists/PtrList -I../../OpenFOAM/memory/tmp -I../../OpenFOAM/containers/LinkedLists/accessTypes/LPtrList -I../../OpenFOAM/containers/Lists/IndirectList -I../../OpenFOAM/containers/Lists/UIndirectList -I../../OpenFOAM/containers/Lists/BiIndirectList -I../../OpenFOAM/global/JobInfo -I../../OpenFOAM/db/dictionary -I../../OpenFOAM/db/dictionary/entry -I../../OpenFOAM/containers/LinkedLists/accessTypes/ILList -I../../OpenFOAM/containers/LinkedLists/accessTypes/UILList -I../../OpenFOAM/containers/LinkedLists/linkTypes/DLListBase -I../../OpenFOAM/db/IOstreams/Tstreams -I../../OpenFOAM/primitives/strings/lists -I../../OpenFOAM/db/dictionary/primitiveEntry -I../../OpenFOAM/db/IOstreams/StringStreams -I../../OSspecific/POSIX/cpuTime -I../../OpenFOAM/include -I../../OpenFOAM/primitives/ints/long -I../../OpenFOAM/db/IOstreams
but got the exact same error:
ld -r -o /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOSspecific.o Make/linux64IccDPOpt/sigFpe.o Make/linux64IccDPOpt/sigSegv.o Make/linux64IccDPOpt/sigInt.o Make/linux64IccDPOpt/sigQuit.o Make/linux64IccDPOpt/sigStopAtWriteNow.o Make/linux64IccDPOpt/sigWriteNow.o Make/linux64IccDPOpt/regExp.o Make/linux64IccDPOpt/timer.o Make/linux64IccDPOpt/fileStat.o Make/linux64IccDPOpt/POSIX.o Make/linux64IccDPOpt/cpuTime.o Make/linux64IccDPOpt/clockTime.o Make/linux64IccDPOpt/memInfo.o Make/linux64IccDPOpt/fileMonitor.o Make/linux64IccDPOpt/printStack.o
that seems overwritten by this command:
SOURCE=signals/sigFpe.C ;  mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -O2 -no-prec-div  -DNoRepository -DFOAM_USE_INOTIFY -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude   -fPIC -mmic -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/ -c $SOURCE -o Make/linux64IccDPOpt/sigFpe.o
Old   May 28, 2014, 01:22
Since the "-L/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/" doesn't work at all..
we're adding all ".so" files on "cFLAGS" part on the "c" and "c++" file, for example:
mpiicpc -std=c++0x -Dlinux64 -DWM_DP -wd327,525,654,819,1125,1476,1505,1572 -O2 -no-prec-div -DNoRepository -IlnInclude -I. -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/root/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -mmic -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/ -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64IccDPOpt/expandDictionary.o -L/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib -lOpenFOAM -ldl -L/lib -L/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic -L/opt/crtdc/micgnu/lib/ -lm -o /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/bin/expandDictionary -Wl,/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/libimf.so,/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/libsvml.so,/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/libirng.so,/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/libintlc.so.5,/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/intel64/libPstream.so,/opt/crtdc/micgnu/lib/libz.so\
and the error on the ld part was solved by make a symbolic link "/opt/mpss/3.2.1/sysroots/x86_64-mpsssdk-linux/usr/bin/k1om-mpss-linux/k1om-mpss-linux-ld" as "/usr/bin/ld"
some warning disappear, but some warning still shows up:
x86_64-k1om-linux-ld: warning: libirng.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/intel64/libPstream.so, not found (try using -rpath or -rpath-link)
x86_64-k1om-linux-ld: warning: libdynamicMesh.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libautoMesh.so, not found (try using -rpath or -rpath-link)
x86_64-k1om-linux-ld: warning: liblagrangian.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libautoMesh.so, not found (try using -rpath or -rpath-link)
x86_64-k1om-linux-ld: warning: libfileFormats.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libautoMesh.so, not found (try using -rpath or -rpath-link)
x86_64-k1om-linux-ld: warning: libdsmc.so, needed by /root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libutilityFunctionObjects.so, not found (try using -rpath or -rpath-link)
*snip* very long long mpiipcp command *snip*
/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/postCalc.o: In function `Foam::tryCalc(Foam::argList const&, Foam::Time const&, Foam::fvMesh const&)':
(.text+0x1520): undefined reference to `Foam::calc(Foam::argList const&, Foam::Time const&, Foam::fvMesh const&)'
pastebin for the error file: http://pastie.org/9227330
any possible solution for solving those errors?
Old   May 28, 2014, 03:51
at last.. (/^__^)/
this one works:
.SUFFIXES: .c .h
cWARN        =
cc          = icc
include $(RULES)/c$(WM_COMPILE_OPTION)
cFLAGS      = -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/ $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -fPIC \
-mmic -I/usr/include -Wl,/opt/crtdc/micgnu/lib/libz.so
ctoo        = $(WM_SCHEDULER) $(cc) $(cFLAGS) -c $$SOURCE -o $@
LINK_LIBS   = -Wl,-rpath-link,/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/,-rpath-link,/opt/crtdc/micgnu/lib,-rpath-link,/root/OpenFOAM/OpenFOAM-2.3.0/platf
orms/linux64IccDPOpt/lib/intel64/,-rpath-link,/root/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/ -L/opt/intel/composer_xe_2013_sp1.2.144/compiler/lib/mic/ -L
/opt/crtdc/micgnu/lib/ $(cDBUG) -L$(IA32ROOT)/lib
LINKLIBSO   = $(cc) $(cFLAGS) -shared
LINKEXE     = $(cc) $(cFLAGS) -Xlinker --add-needed -Xlinker -z -Xlinker nodefs
.SUFFIXES: .C .cxx .cc .cpp
c++WARN     = -wd327,525,654,819,1125,1476,1505,1572
include $(RULES)/c++$(WM_COMPILE_OPTION)
ptFLAGS     = -DNoRepository
c++FLAGS    = -I/opt/intel/impi/4.1.3.049/mic/include/ -I/opt/crtdc/micgnu/include/ $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC \
Ctoo        = $(WM_SCHEDULER) $(CC) $(c++FLAGS) -c $$SOURCE -o $@
cxxtoo      = $(Ctoo)
cctoo       = $(Ctoo)
cpptoo      = $(Ctoo)
/opt/crtdc/micgnu/lib/ $(c++DBUG) -L$(IA64ROOT)/lib
LINKLIBSO   = $(CC) $(c++FLAGS) -shared -Xlinker --add-needed -Xlinker --no-as-needed
LINKEXE     = $(CC) $(c++FLAGS) -Xlinker --add-needed -Xlinker --no-as-needed
wyldckat likes this.
Old   June 9, 2014, 00:31
Default OpenFOAM2.3.0 on Xeon Phi with OpenMPI1.6.5 (could not read symbols)
  #20
manredd is on a distinguished road
Dear All,
I would be very grateful if you tell me how you specifically fixed the following problem:
wmake libso mpi
'/home/manumachu/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/openmpi-1.6.5/libPstream.so' is up to date.
+ OSspecific/POSIX/Allwmake
Found <sys/inotify.h> -- enabling inotify for file monitoring.
ld -r -o /home/manumachu/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOSspecific.o Make/linux64IccDPOpt/sigFpe.o Make/linux64IccDPOpt/sigSegv.o Make/linux64IccDPOpt/sigInt.o Make/linux64IccDPOpt/sigQuit.o Make/linux64IccDPOpt/sigStopAtWriteNow.o Make/linux64IccDPOpt/sigWriteNow.o Make/linux64IccDPOpt/regExp.o Make/linux64IccDPOpt/timer.o Make/linux64IccDPOpt/fileStat.o Make/linux64IccDPOpt/POSIX.o Make/linux64IccDPOpt/cpuTime.o Make/linux64IccDPOpt/clockTime.o Make/linux64IccDPOpt/memInfo.o Make/linux64IccDPOpt/fileMonitor.o Make/linux64IccDPOpt/printStack.o
make: *** [/home/manumachu/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64IccDPOpt/lib/libOSspecific.o] Error 1
Best Regards
Manredd
manredd is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 15:03
openFoam, Intel Phi, without intelcompiler/intelmpi m0guib OpenFOAM Installation 2 November 3, 2014 08:05
CFX Solver using Xeon Phi (Intel MIC) card cvh CFX 4 September 12, 2014 13:34
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
