[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X
Like Tree20Likes
Old   August 20, 2013, 16:09
Assistant Moderator
Bernhard Gschaider
Originally Posted by dav.dap83 View Post
Yes, I have.
Perhaps it may be more helpful to upload the log file.
Only looked at the first log file. For some reason it doesn't find pointHit.H (which is quite essential). Remove $FOAM_SRC/OpenFOAM/lnInclude and recompile (the lnInclude will be rebuilt).
After writing the last paragraph it just occurred to me: pointHit.H is one of these files with a major case "brother": PointHit.H. Are you sure you're on a case-sensitive filesystem and if yes: maybe you unpacked the sources on a case-insensitve filesystem before moving them to the case-sensitve one.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 20, 2013, 19:43
Davide D.
dav.dap83 is on a distinguished road
That's exactly what happened. Now I've unpacked the sources into a case-sentitive filesystem and the compilation succeeded.
Thank you
dav.dap83 is offline   Reply With Quote
Old   August 20, 2013, 20:24
Assistant Moderator
Bernhard Gschaider
Thank you
Which instructions did you use? If it is on the Wiki: could you add a warning about this problem to the part about unpacking? (I think misunderstandings are best cleared by those to whom it was unclear. "I wouldn't have had this problem if THIS had been there")
Old   August 20, 2013, 20:57
Davide D.
You mean this wiki? http://openfoamwiki.net/index.php/Ho...enFOAM_v21_Mac
In tr first attempt (that didn't work) I just extracted the tar files by double-clicking in the Downloads folder, and them dragged and dropped the folders inside the case-sensitive disk image. In the second attempt (this worked) I downloaded the tar files directly inside the disk image, and then unpacked them via terminal.
Old   September 27, 2013, 12:24
Oscar Mayr
oscarsailing is on a distinguished road
Hello Everybody,
I just manage to install OF-v2.2 and I was running the first tutorials...
I came across this issue with snappy which make me struggle a lot in the tutorial "wigleyHull"
Oscars-MacBook-Pro:wigleyHull JARVIS$ snappyHexMesh
dyld: Library not loaded: libptscotch.dylib
  Referenced from: /Users/JARVIS/OpenFOAM/OpenFOAM-2.2.0/platforms/darwinIntel64GccDPOpt/lib/openmpi-macport/libptscotchDecomp.dylib
  Reason: image not found
Trace/BPT trap: 5
how do I solve it? openmpi was installed correctly and
/Volumes/OpenFOAM-v2.2/OpenFOAM-2.2.0/platforms/darwinIntel64GccDPOpt/lib/openmpi-macport/libptscotchDecomp.dylib
seems to be correctly placed...
sorry the ignorance
I look forward to your reply on this issue.
Oscar
oscarsailing is offline   Reply With Quote
Old   September 27, 2013, 16:20
Assistant Moderator
Bernhard Gschaider
Originally Posted by oscarsailing View Post
Hello Everybody,
Trace/BPT trap: 5
Reread the error message: it looks for libptscotch.dylib (not libptscotchDecomp.dylib) which on my machine (path may slightly vary due to different compiler) lies in /Volumes/Foam/ThirdParty-2.2.x/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport/
That is part of the ThirdParty-compilation. Maybe there was a problem there.
sorry the ignorance
Oscar
"And the Oscar for the most polite question goes to .... ". Sorry. Could not resist. I guess you don't find that funny and of course you're right
Old   October 3, 2013, 12:08
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
I think I made it compile with 4.2 with the attached patch. Wanted to report it to the upstream but I first wanted to verify whether this is a fix to a MacOnly-problem
Bernhard
Attachment 23326
Dear Bernhard,
Excuse my ignorance but where does the attached patch of yours, posted in #54, have to be applied?
Regards,
César
cesarcg is offline   Reply With Quote
Old   October 3, 2013, 13:49
Assistant Moderator
Bernhard Gschaider
Originally Posted by cesarcg View Post
Dear Bernhard,
Excuse my ignorance but where does the attached patch of yours, posted in #54, has to be applied?
Regards,
César
If there is a newer version of the general patch and you used that: no
Old   October 5, 2013, 05:49
Jonathan byrne
jonathanbyrn is on a distinguished road
I am having problems compiling the third party libraries. It could not find the makefile and header file for scotch and ptsscotch.
../../etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM
WARNING: required include file 'scotch.h' not found!
I went to the makefile folder and copied Makefile.inc.i686_pc_linux2.shlib-OpenFOAM-64 to the name it was looking for. This pushed the compilation a little further but i'm still getting complaint about -lrt and the header files.
ld: library not found for -lrt
WARNING: required include file 'ptscotch.h' not found!
I'm using the most recent 2.2.1 downloads. Is there another version of the third party source code I should be using?
Any help would be greatly appreciated!
jonathanbyrn is offline   Reply With Quote
Old   October 5, 2013, 06:56
Jonathan byrne
So I was using the first patch, not the updated one. Now it is creating the osx makefile. It still isn't compiling though:
openmpicc -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict=__restrict -DCOMMON_TIMING_OLD -DSCOTCH_PTSCOTCH -DSCOTCH_VERSION=6 -DSCOTCH_RELEASE=0 -DSCOTCH_PATCHLEVEL=0 dummysizes.c -o ptdummysizes -lz -lm
make[2]: openmpicc: Command not found
make[2]: *** [ptdummysizes] Error 127
make[1]: *** [ptscotch] Error 2
make: *** [ptscotch] Error 2
should the build have linked openmpi to /usr/local/bin or should I have installed openmpi through macports?
Old   October 6, 2013, 11:12
Assistant Moderator
Bernhard Gschaider
I use openmpi from MacPorts.
Old   October 7, 2013, 08:02
Jonathan byrne
Thanks for getting back to me Bernhard, I really appreciate the help. I had macports openmpi installed but the macports check in /etc/config/settings.sh wasn't working for me. The -s flag in "which -s port >/dev/null" was returning 1 even though it was there. I removed it and it started using the macports version.
Everything in the thirdparty folder is building now but when something calls mpi, it blows up:
A requested component was not found, or was unable to be opened. This
means that this component is either not installed or is unable to be
used on your system (e.g., sometimes this means that shared libraries
that the component requires are unable to be found/loaded). Note that
Open MPI stopped checking at the first component that it did not find.
Host: jonserver
Framework: ras
Component: proxy
[jonserver:03894] [[24804,0],0] ORTE_ERROR_LOG: Error in file /opt/local/var/macports/build/_opt_mports_dports_science_openmpi/openmpi/work/openmpi-1.7.2/orte/mca/ess/hnp/ess_hnp_module.c at line 360
This folder doesn't exist and I can't see it being specified in any of the environment variables. Should these files exist or are they created dynamically?
In desperation I tried installing openmpi from source and using the systemmpi flag. It recompiled the third party libraries correctly but now I get this error:
--> FOAM FATAL ERROR:
Trying to use the dummy Pstream library.
This dummy library cannot be used in parallel mode
From function UPstream::init(int& argc, char**& argv)
in file UPstream.C at line 37.
FOAM exiting
My apologies if these are trivial configuration errors but I have no experience using openmpi and i'm having a difficult time debugging them.
Old   October 7, 2013, 08:48
Assistant Moderator
Bernhard Gschaider
Host: jonserver
Framework: ras
Component: proxy
FOAM exiting
Usually the problem with that kind of error message is that you're using one OpenMPI-implementation but there are environment variables that point to another. Check environment variables with MPI and OPAL in the name. Especially OPAL (if that is set unset it with .... unset)
Old   October 7, 2013, 09:14
Jonathan byrne
I grepped my environment and the mpi paths seem to be correct:
printenv | grep -i mpi
MPI_ARCH_PATH=/opt/local
LD_LIBRARY_PATH=/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46/gperftools-svn/lib:/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46/paraview-3.12.0/lib/paraview-3.12:/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport:/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport:/opt/local/lib:/Users/jonathanbyrne/OpenFOAM/jonathan-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/site/2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/dummy
MPI_BUFFER_SIZE=20000000
WM_MPLIB=MACPORTOPENMPI
FOAM_MPI=openmpi-macport
DYLD_LIBRARY_PATH=/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport:/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport:/Users/jonathanbyrne/OpenFOAM/jonathan-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/site/2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/ThirdParty-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib:/Users/jonathanbyrne/OpenFOAM/OpenFOAM-2.2.1/platforms/darwinIntel64Gcc46DPOpt/lib/dummy:
There are no references to OPAL in my environment. Is there anywhere else I should look?
Old   October 7, 2013, 15:54
Assistant Moderator
Bernhard Gschaider
You did the same ("printenv | grep -i opal")? Then this isn't set (don't remember he exact name of the variable ... it is set somewhere)
Two more things to check:
- that none of the old mpi-libs is in the LD_LIBRARY_PATH and/or DYLD_LIBRARY_PATH
- if you run "openmpirun -h" without the etc/bashrc being sourced, does it give you the same error or the help messages? If it works OK then the problem is one of the variables the script sets
Old   October 7, 2013, 17:11
Jonathan byrne
I tried your advice and openmpirun worked before and after sourcing bashrc. It turns out $WM_PROJECT_DIR/bin/tools/RunFunctions is hardcoded to call mpirun instead of openmpirun, which was broken on my system. I changed it and now it is working. Thanks for your advice!
Old   October 7, 2013, 18:54
Assistant Moderator
Bernhard Gschaider
Ah. I rarely use the RunFunctions. Maybe I should adapt them in the patch as well
Old   October 26, 2013, 04:10
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Hi Bernhard, I'm back. I think i succeeded in building everything. The only error I get is this:
make[2]: `libptscotchparmetis.dylib' is up to date.
cp parmetis.h ../../include
cp libptscotchparmetis.dylib ../../lib
+ make prefix=/Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0 libdir=/Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport includedir=/Users/rube$
mkdir /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-macport
cp -f ../bin/[agm]* /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
cp: ../bin/[agm]*: No such file or directory
make: [install] Error 1 (ignored)
cp -f ../bin/d[agm]* /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/bin
cp -f ../include/*scotch*.h /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/include/openmpi-macport
cp -f ../lib/*scotch*.dylib /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46DPOpt/lib/openmpi-macport
cp -Rf ../man/* /Users/rubendibattista/OpenFOAM/ThirdParty-2.2.2/platforms/darwinIntel64Gcc46/scotch_6.0.0/share/man
+ make realclean
(cd libscotch ;      make realclean)
Is this a problem?
rdbisme is offline   Reply With Quote
Old   October 28, 2013, 18:40
Assistant Moderator
Bernhard Gschaider
+ make realclean
Is this a problem?
No. If you see the scotch-libraries with "ls $FOAM_EXT_LIBBIN/$FOAM_MPI" all should be fine
Old   November 9, 2013, 13:29
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hello ppl,
I followed http://www.optimulation.com/2013/03/...n-lion-10-8-3/
the video on the above link to install openFOAM on mac.
- surfaceaFeatureExtract (is not working - it is very important for me)
so any suggestion how to get this working
- ParaView is not working ( probably think i have install new version ?)
Kind Regards,
Hasan K.J
Alhasan is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
