problem in installation in OpenFOAM-2.1.x on Red Hat |
February 20, 2013, 23:46 |
#41 |
nagendra verma
Rep Power: 13 |
Dear Sir,
Thankyou very much I have completed all these steps successfully. I am attaching a pics of last command Allwmake. Thanks nagendra |
February 21, 2013, 06:01 |
#42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Nagendra,
I'm glad it's finally working! Best regards, Bruno
February 25, 2013, 00:00 |
#43 |
nagendra verma
Rep Power: 13 |
Dear Sir,
Now I want GPU Plugin for OpenFOAM 2.1.x I have downloaded SpeedIT Classic toolkit from this link http://speedit.vratis.com/index.php/...d.html#content but here it is not mention here for which OpenFOAM version this toolkit we can use. where it will support OpenFOAM 2.1.x Thanks nagendra |
February 25, 2013, 05:22 |
#44 |
nagendra verma
Rep Power: 13 |
Dear Sir,
I am Installing GPU Plugin for OpenFOAM name is 1.2 Classic. In first step written like Go to your path for FOAM applications cd $WM_PROJECT_USER_DIR But when I am running command cd $WM_PROJECT_USER_DIR Its giving cd: /home/others/trainee/OpenFOAM/trainee-2.1.x: No such file or directory In etc/bashrc file export WM_PROJECT_USER_DIR=$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION while I am writing echo $WM_PROJECT_USER_DIR /home/others/trainee/OpenFOAM/trainee-2.1.x but there is no trainee-2.1.x directory. I think need to create trainee-2.1.x directory in /home/others/trainee/OpenFOAM/. Thanks nagenrda Last edited by nagendra verma; February 25, 2013 at 06:30. |
February 25, 2013, 08:13 |
#45 |
Bruno Santos
Rep Power: 128 |
Hi Nagendra,
Sorry, I've never used the SpeedIt plugin, so I don't know how it works. But I do have some limited experience with Symscape's GPU plug-in: http://www.symscape.com/gpu-1-0-openfoam The detail is that you will need to build the Single Precision version of OpenFOAM, instead of the default Double Precision. There is also Cufflink, but it only works with Extend's variant of OpenFOAM named 1.6-ext: http://code.google.com/p/cufflink-library/ But is the GPU plug-in critical to your work? Because it is still very limited and only in some cases will you be able to draw any performance improvements At least AFAIK... Best regards, Bruno
February 26, 2013, 00:53 |
#46 |
nagendra verma
Rep Power: 13 |
Dear Sir,
On echo $WM_PROJECT_USER_DIR giving /home/others/trainee/OpenFOAM/trainee-2.1.x but there is not any directory trainee-2.1.x cd $WM_PROJECT_USER_DIR giving cd: /home/others/trainee/OpenFOAM/trainee-2.1.x: No such file or directory echo $FOAM_USER_LIBBIN /home/others/trainee/OpenFOAM/trainee-2.1.x/platforms/linux64Gcc44DPOpt/lib cd $FOAM_USER_LIBBIN giving cd: /home/others/trainee/OpenFOAM/trainee-2.1.x/platforms/linux64Gcc44DPOpt/lib: No such file or directory while lib directory available in ~/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc44DPOpt$cd lib/ why these things happening. Thanks nagendra |
February 26, 2013, 04:27 |
#47 | |
Bruno Santos
Rep Power: 128 |
Hi Nagendra,
Sorry about that, I didn't see the other details you had posted. The reason why you're getting those error messages is because:
Bruno
February 26, 2013, 06:29 |
#48 |
nagendra verma
Rep Power: 13 |
Dear Sir,
I have followed upto step-6 on running command my_icoFoam I am getting FOAM FATAL ERROR. and one more thing $FOAM_USER_LIBBIN did not create. cd $FOAM_USER_LIBBIN cd: /home/others/trainee/OpenFOAM/trainee-2.1.x/platforms/linux64Gcc44DPOpt/lib: No such file or directory I am attaching make.log file for my_icoFoam command. Thanks nagendra |
February 26, 2013, 06:33 |
#49 |
Bruno Santos
Rep Power: 128 |
Hi Nagendra,
Sorry about that, I forgot to mention that the example for adding temperature to icoFoam usually only creates the "$FOAM_USER_APPBIN" folder, because it creates only an application. Nonetheless, if you do want to create the last remaining folder, you can simply run: Code:
mkdir -p $FOAM_USER_LIBBIN Best regards, Bruno
Source Pack Installation OpenFOAM Version 2.1.0 on Redhat Linux | Indrajit | OpenFOAM Installation | 1 | April 1, 2012 04:39 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
Installation Fluent 6.3 into Red Hat Linux System | rashid | FLUENT | 1 | March 1, 2008 08:57 |
Problem in running CFX in red hat linux | Q | CFX | 0 | March 30, 2006 09:11 |
