October 24, 2012, 10:28 |
ThirdParty2.1.1 on Ubuntu 12.10 64bit [solved]
#1 | ||||
Davide Cagnoni
Rep Power: 15 |
Hi everybody
I'm trying to install OpenFoam from source in my newly installed (from a formatted system) Ubuntu. I followed the instructions from http://www.openfoam.org/download/source.php step by step, and the OpenFoam part seems to work ok, while the Paraview compilation seems to finish not successfully. Also, the PV3FoamReader module fails. Here's an excerpt of how the makeParaview script output terminates: Quote:
Again, when I try to run the usual blockmesh-icofoam-parafoam sequence, the first two run smoothly while parafoam gives the following error: Quote:
Thank you a lot in advance, davide P.S. i'm using the following versions of software: Quote:
October 24, 2012, 11:16 |
Rep Power: 14 |
why do you build OpenFoam from source and donīt you install the Deb Pack? |
October 24, 2012, 11:51 |
Davide Cagnoni
Rep Power: 15 |
October 24, 2012, 15:38 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I've written instructions for both modes some weeks ago : http://openfoamwiki.net/index.php/In...u#Ubuntu_12.10 Best regards, Bruno
October 24, 2012, 18:38 |
#5 | |
Davide Cagnoni
Rep Power: 15 |
I'll try out asap P.S. worked out perfectly thanks a lot ! Last edited by davide_c; October 24, 2012 at 19:47. |
October 25, 2012, 03:45 |
Bruno Santos
Rep Power: 128 |
Hi Davide,
I'm glad it worked. For the lack of a better word: it's a hack. The modification is necessary because Gcc 4.7 is a lot more picky about the source code, demanding better coding standards Best regards, Bruno
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 05:43 |
Ansys 12.0 on Ubuntu 10.10 64bit | Krischan | ANSYS | 1 | April 26, 2011 05:44 |
Installing OpenFOAM 1.7.0 on Ubuntu Hardy 64bit | nuovodna | OpenFOAM | 2 | July 1, 2010 10:24 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
ubuntu 9.10 64bit - wmake missing headers | soeren87 | OpenFOAM Installation | 5 | November 11, 2009 11:01 |
