Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7
Old   September 26, 2012, 07:57
Default Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7
Wley is on a distinguished road
Dear All,
Being a newbie in Linux I am trying to install Openfoam-ParaView on Scientific Linux 5.7. I would be grateful to a forum member who could provide me with a hint to solve a problem with ParaView 3.12.0 installation.
I have to compile OpenFOAM and ParaView from source packages. After downloading OpenFOAM-2.1.1.tgz and ThirdParty-2.1.1.tgz, unpacking them I have finally succeeded in compiling OpenFOAM (after installing gcc-4.7.1).
Now, however, I am struggling with the compilation process of ParaView. First, I installed cmake (version 2.8.9) and Qt (version 4.7.3). Nevertheless, something is still wrong with the installation process of ParaView. I attach the make.log file and would be very grateful if someone could tell me what the problem is and how I can manage it.
Thank you!
Wley
Wley is offline   Reply With Quote
Old   September 26, 2012, 10:53
treima is on a distinguished road
perhaps this is no the answer you expected and I think there are others who can help you here.
But if you canīt manage it to install Paraview, you can download the binaries from the homepage and work with these.
http://www.paraview.org/paraview/resources/software.php
regards
treima
treima is offline   Reply With Quote
Old   September 28, 2012, 07:06
Retired Super Moderator
Bruno Santos
Greetings to all!
@Wley: I've been testing and writing instructions on how to build OpenFOAM and ParaView in several Linux Distributions. Last night I finished writing instructions for CentOS 5.8 + OpenFOAM 2.1.1 and ParaView 3.12.0: http://openfoamwiki.net/index.php/In...HEL#CentOS_5.8
But there are big differences in versions, at least related to Gcc and Qt. Since you're trying to build with Gcc 4.7.1, ParaView needs a small fix:
cd $WM_THIRD_PARTY_DIR
sed -i -e 's/ClearAndSelect = Clear | Select/ClearAndSelect = static_cast<int>(Clear) | static_cast<int>(Select)/' \
ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h
I got this from the instructions for Fedora 17: http://openfoamwiki.net/index.php/In...dora#Fedora_17
As for Qt: it's better to use Qt 4.6.4, because there is a very annoying bug in Qt 4.7.3: https://bugreports.qt-project.org/browse/QTBUG-18910
You'll find on the first link on this post instructions for easily getting and building Qt 4.6.4 and ParaView with. Along with the fix I mentioned afterwards, you should get a working installation after a few hours of compiling
Best regards,
Bruno
[OpenFOAM] Paraview display problem jiejie ParaView 4 October 13, 2013 22:29
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 05:29
Installation paraFoam - still problem nhl OpenFOAM Installation 7 June 22, 2010 10:22
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 07:39
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
