September 19, 2012, 16:32 |
ParaView Installation
Paul B
Rep Power: 14 |
I am attempting to install OpenFOAM 2.1.1 on the Redhat scientific version of Linux. I receive this error when I attempt execute the command wmSET: -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/etc/config/settings.sh: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/etc/config/aliases.sh: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory I also get this error when I run ./Allwmake from the PV3Readers directory. vtkPV3Foam.C:194: error: âpartIdâ was not declared in this scope vtkPV3Foam.C:194: error: âforAllâ was not declared in this scope vtkPV3Foam.C:195: error: expected â;â before â{â token vtkPV3Foam.C:179: warning: unused variable âselectionâ vtkPV3Foam.C:828: error: expected â}â at end of input make: *** [Make/linux64GccDPOpt/vtkPV3Foam.o] Error 1 + cd PV3FoamReader + mkdir -p Make/linux64GccDPOpt + cd Make/linux64GccDPOpt + cmake ../.. PV3FoamReader/Allwmake: line 12: cmake: command not found + make make: *** No targets specified and no makefile found. Stop. Any help on how to proceed would be much appreciated |
September 19, 2012, 18:26 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings pbarc and welcome to the forum!
Either way, the dedicated project to OpenFOAM +RedHat Linux and derived versions is CentFOAM: http://sourceforge.net/apps/mediawik...itle=Main_Page Associated to this subject, there is at least this thread: http://www.cfd-online.com/Forums/ope...tml#post359479 Good luck! Bruno
September 20, 2012, 11:23 |
Paul B
Rep Power: 14 |
Thanks for the help Bruno,
I am running the 6.x version. The problems seem to be when I run makeParaview. During the output it says that: etc/tools/ParaViewFunctions: line 422: cmake: command not found Starting make make: *** No targets specified and no makefile found. Stop. I have installed the most recent version of cmake locally and added the dir of cmake to the .bashrc file. But when I execute the command which cmake it says no cmake in (then list a bunch of directorys) but I checked the directory that cmake is in and it is listed in the directories that the which command says it is not in. Any ideas? Thanks, Paul |
September 23, 2012, 12:39 |
Bruno Santos
Rep Power: 128 |
Greetings Paul,
Sorry for taking so long to answer you, but only today did I get around to test this. You'll find the resulting instructions from my endeavor at http://openfoamwiki.net/index.php/In...HEL#CentOS_6.3 Skip to point #7 for building CMake and ParaView. Best regards, Bruno
September 24, 2012, 10:52 |
Paul B
Rep Power: 14 |
Thanks Bruno,
So I now have Paraview and cmake built, but when I run the wmSET command an error shows up saying: >> $ wmSET $FOAM_SETTINGS -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/etc/config/settings.sh: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/etc/config/aliases.sh: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamEtcFile: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory -bash: /data/app/OpenFOAM/OpenFOAM-2.1.1/bin/foamCleanPath: No such file or directory If I skip the wmSET and go onto ./Allwclean and ./Allwmake, Error 2 shows up while building: [ 64%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/moc_pqPV3FoamReaderPanelImplementation.cxx.o [ 70%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkPV3FoamReader.cxx.o In file included from /home/pbarc/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/postProcessing/graphics/PV3Readers/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx:43: /home/pbarc/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/postProcessing/graphics/PV3Readers/PV3FoamReader/PV3FoamReader/../vtkPV3Foam/vtkPV3Foam.H:64:23: error: className.H: No such file or directory /home/pbarc/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/postProcessing/graphics/PV3Readers/PV3FoamReader/PV3FoamReader/../vtkPV3Foam/vtkPV3Foam.H:65:22: error: fileName.H: No such file or directory ... Reader/vtkPV3FoamReader.cxx:349: error: âdebugâ is not a member of âFoam::vtkPV3Foamâ make[2]: *** [CMakeFiles/PV3FoamReader_SM.dir/vtkPV3FoamReader.cxx.o] Error 1 make[1]: *** [CMakeFiles/PV3FoamReader_SM.dir/all] Error 2 make: *** [all] Error 2 Any idea on to why that may happen? Thanks, Paul |
September 24, 2012, 11:11 |
Bruno Santos
Rep Power: 128 |
Hi Paul,
Start a new terminal and try the last block once again, without the wmSET command, i.e.: Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake Code:
which paraview The reason why wmSET worked in such a very wrong way was probably because you didn't follow the instructions from the beginning, where the settings are being defined in a different way. Best regards, Bruno
September 24, 2012, 11:45 |
Paul B
Rep Power: 14 |
I ran ./Allwclean and ./Allwmake without running wmSET and the installation seems to have worked and I was able to open paraFoam while running the first tutorial.
Thanks for your help Bruno! |
paraview 3.12 |
ParaView installation problem on Suse 11.4 | victorz | OpenFOAM Installation | 4 | February 6, 2012 18:26 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 19:13 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 13:59 |
