[OpenFOAM.org] Install OpenFOAM-2.1.1 on Fedora 17 |
August 11, 2012, 07:52 |
#21 | |
hadi abdollahzadeh
Rep Power: 14 |
now what should I do for editing the make.log? |
August 11, 2012, 09:57 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Hadi,
I guess the easiest is to run the commands as explained in the official instructions - start reading from the section "Getting Started": http://www.openfoam.org/download/source.php#x6-37000 A quick test is to run: Code:
icoFoam -help Oh, as for ParaView, simply follow the instructions starting from section "Compiling Paraview 3.12.0 and the PV3FoamReader Module": http://www.openfoam.org/download/source.php#x6-35000 Best regards, Bruno
August 11, 2012, 11:06 |
#23 | |
hadi abdollahzadeh
Rep Power: 14 |
I'm so stupid, so I really do apologize to you for tacking your time.
when I run this order I see this error: Quote:
August 11, 2012, 11:51 |
#24 |
Bruno Santos
Rep Power: 128 |
Hi Hadi,
I didn't test this myself before... anyway, as root run: Code:
yum install cmake Code:
./makeParaView -qmake $(which qmake-qt4) Bruno
August 11, 2012, 12:32 |
#25 | |||
hadi abdollahzadeh
Rep Power: 14 |
hi Bruno
August 11, 2012, 12:48 |
#26 |
Bruno Santos
Rep Power: 128 |
Hi Hadi,
edit: I forgot to mention: start a new terminal and do these steps in this new terminal. I'm testing this as well and found out that ParaView won't build properly without some more help. Run these commands: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's/ClearAndSelect = Clear | Select/ClearAndSelect = static_cast<int>(Clear) | static_cast<int>(Select)/' ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h ./makeParaView -qmake $(which qmake-qt4) -no-config Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake Bruno PS: created wiki page where this is now documented: http://openfoamwiki.net/index.php/In...M-2.1.1/Fedora
Last edited by wyldckat; August 11, 2012 at 13:04. Reason: see "edit:" and "PS:" |
August 11, 2012, 13:35 |
#27 |
hadi abdollahzadeh
Rep Power: 14 |
I thank you very much and hope that one day I can repay the favor you.
I wish the best for you. thanks and thanks very much |
August 11, 2012, 13:55 |
#28 |
Bruno Santos
Rep Power: 128 |
You're welcome! Have fun using OpenFOAM
And don't forget: details are reaaaally important when it comes to using OpenFOAM
August 19, 2016, 12:42 |
#29 |
Linyan X
Rep Power: 10 |
August 20, 2016, 18:49 |
#30 |
Bruno Santos
Rep Power: 128 |
Please provide more details, namely:
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
install openfoam in fedora | Ahmed Khattab | OpenFOAM Installation | 32 | September 23, 2011 12:11 |
