January 24, 2013, 09:42 |
#21 |
I am getting the same problem with 2.1.1. Is there a known fix for this ?
January 24, 2013, 16:56 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Praveen,
I had to re-read the whole thread in order to understand you question ... so my question back to you is: did you try the instructions given along the thread? If so, what was the outcome? You can also try building OpenFOAM 2.1.1 from the source code: http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL Best regards, Bruno
January 25, 2013, 01:44 |
#23 |
I am having trouble even running ldd
[praveen@turing obliqueShock]$ ldd $(which blockMesh) /home/praveen/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: error while loading shared libraries: /home/praveen/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/lib/libmpi.so.1: ELF file OS ABI invalid |
January 26, 2013, 15:55 |
#24 |
Bruno Santos
Rep Power: 128 |
Hi Praveen,
Sorry, but I don't have time this weekend to try and replicate this error. As I wrote before, it's best that you re-build OpenFOAM from the source code. The link in the previous post provides instructions for both major versions of CentOS et al. Best regards, Bruno
CentFOAM Python Script Installation: Error | socon009 | OpenFOAM Installation | 2 | May 26, 2012 10:36 |
Upgrade CPU or GPU which one is better | RTAF | Hardware | 1 | January 27, 2012 10:06 |
check wmake in CentFOAM | pit | OpenFOAM | 12 | November 24, 2010 17:59 |
CentFOAM updated/cleaned | linnemann | OpenFOAM Installation | 0 | June 1, 2010 16:40 |
Upgrade P4 1.5 to P4 2.6 | JJJ | FLUENT | 3 | May 29, 2004 11:30 |
