July 27, 2012, 07:45 |
OpenFOAM1.6-ext compile notes
Rep Power: 16 |
Hi Foamers,
Pure OpenFOAM-1.6-ext compile went nearly as in the movies, a lot of development during the year. I added also the branch ”mixingPlane_RC1”. Some notes from compiling found. Swak4Foam-0.2.0 compilation does not go through with when multiple processor are used (WM_NCOMPPROCS=8 on OF compiling), in other words, “export WM_NCOMPPROCS=1” is needed on before “AllMake.stage5”. Second notes related to qt-libraries. When the ThirdParty QT is used the “QT_DIR” and “QT_BIN_DIR” must be defined, so that paraFoam works. Without this definition the following message appeats when I try to start the ParaFOAM Code:
“/home/Pekka/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.14.1 /platforms/linux64GccDPOpt/lib/paraview-3.14/paraview: symbol lookup error: /home/Pekka/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.14.1 /platforms/linux64GccDPOpt/lib/paraview-3.14/libpqCore.so: undefined symbol: _ZN9QMetaType15registerTypedefEPKci ” BR/Pekka |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 | gwierink | OpenFOAM Installation | 0 | April 5, 2011 04:38 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 17:22 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 13:24 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
