August 9, 2012, 11:35 |
#21 |
Rep Power: 16 |
Thanks a lot, Bruno. It still doesn't work. The log is attached. Can you figure out what's wrong?
August 9, 2012, 11:38 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
This is very strange... OK, try these commands:
cd $WM_THIRD_PARTY_DIR cd metis-5.0pre2 wclean libso GKlib wmake libso GKlib
August 9, 2012, 12:08 |
#23 |
Rep Power: 16 |
It was failed to make GKlib and the problem seems due to "cannot find -lm".
August 9, 2012, 12:14 |
#24 | |
Bruno Santos
Rep Power: 128 |
sudo apt-get install build-essential flex bison cmake zlib1g-dev qt4-dev-tools libqt4-dev gnuplot libreadline-dev libncurses-dev libxt-dev
August 9, 2012, 13:34 |
#25 | |
Rep Power: 16 |
August 9, 2012, 15:25 |
#26 |
Bruno Santos
Rep Power: 128 |
I've been reviewing the previous posts on this threads... are you certain this is active in your shell:
export LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
Can't get older versions of OpenFOAM | fabioc | OpenFOAM Installation | 4 | February 7, 2012 09:13 |
for every member help me please to install OpenFOAM | dima133 | OpenFOAM Installation | 1 | January 8, 2012 16:36 |
how to install openfoam on ubuntu 1.4 ? | seyedashraf | OpenFOAM Installation | 8 | August 23, 2011 05:50 |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 15:15 |
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found | fossy | OpenFOAM Installation | 1 | August 28, 2009 04:06 |
