Problems with compile OpenFoam
Old   July 12, 2012, 05:47
Angry Problems with compile OpenFoam
Cecily
Black-Pearl is on a distinguished road
Hi CFD-Online-Users,
i have big problems with the installation of OpenFoam. I have read some topics about this but nothing could help me. Because I open a topic for me.
When ever I tried ./Allwmake after installation openfoam211 following this error:
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
I have openfoam installed with using a virtual box on Windows 7.
Have anyone a solution to my problem????
Thanks
Black-Pearl is offline   Reply With Quote
Old   July 12, 2012, 06:50
Retired Super Moderator
Bruno Santos
Greetings Black-Pearl,
Which instructions are you following?
Best regards,
Bruno
Old   July 12, 2012, 06:56
Cecily
Hello Bruno,
i following the instructions from the openfoam-website (Ubuntu Deb Pack Installation).
Old   July 12, 2012, 07:10
Bruno Santos
You mean this page: http://www.openfoam.org/download/ubuntu.php - correct?
If so, then you don't need to run "Allwmake"! Simply follow the instructions on that page!
Switch to another page only if that page tells you to.
Old   July 12, 2012, 07:12
Cecily
Yes. Exactly this link.
Did you mean that my installation is correct without Allwmake?
And its correct that Allwmake not run???
Old   July 12, 2012, 07:57
Bruno Santos
Like I wrote, simply follow the instructions on that page, because those instructions will install an already built version of OpenFOAM, ready to be used!
"Allwmake" is only part of the instructions for building from source.
Old   July 12, 2012, 08:01
Cecily
Super. You saved my day.
I tried to solve this "problem" about a long time :-)
Thank you very much!
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 13:54
OpenFOAM Installation Ubuntu 9.04 Problems Sumontro OpenFOAM Installation 8 July 21, 2009 22:40
[General] OpenFoam - problems MateuszZb ParaView 8 July 21, 2008 17:16
Problems downloading Openfoam related documents srinath OpenFOAM 3 June 16, 2008 11:14
