Openfoam 2.1 installation in ubuntu 12.04
Old   April 30, 2012, 09:29
Default Openfoam 2.1 installation in ubuntu 12.04
jsm
JSM
jsm is on a distinguished road
Dear All,
I am Fluent user till now. I am more interested in learning openfoam. First I tried in virtual box - ubuntu 11.04 & openfoam 2.1.
It looks more interesting. So I installed ubuntu 12.04 64 bit in my desktop with dual booting. Now I want to install openfoam 2.1.
Here I have question. Is it OK to install openfoam in ubuntu 12.04. Or shall I need to wait for some more time. Openfoam offcial website didn't tell anything about ubuntu 12.04 installation.
Also I want to compile the source pack instead of debian pack. Could anyone tell me about the procedure and in future how to update openfoam for bug fixes. I already read the source pack compiling procedure in website. But I want to know your experience and issues in this.
Thanks in advance
With regards,
JSM
jsm is offline   Reply With Quote
Old   April 30, 2012, 10:14
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I don't know about the differences of source pack and repository release. I've installed OF as described at the repository release page http://www.openfoam.org/download/git.php
This worked quite well. Updating is quite easy (when using the git-repository)
Just change to your installation directory (/home/user/OpenFOAM/OpenFoam-2.1-x)
and type
git pull
this downloads only the files, that changed since your last update or when you installed OF. After that, just compile the sources again with
./Allwmake
GerhardHolzinger is offline   Reply With Quote
Old   April 30, 2012, 10:50
jsm
JSM
Hi Gerhard
Are you installed in Ubuntu 12.04 64 bit version? I want to install source pack -http://www.openfoam.org/download/source.php.
If I install source pack installation, then can I use "git pull" to get the latest bug fixes? Question might be silly. But I don't know about this.
With regards,
JSM
Old   April 30, 2012, 11:29
Gerhard Holzinger
I currently use ubuntu 10.04 LTS 64 bit. As I said, I don't know exactly the difference between source pack and repository release. So I hope an experienced user will answer this question.
The OpenFOAM homepage states on this site http://www.openfoam.org/download/ that the repository is updated regularly.
Those users compiling from source can receive regular updates to OpenFOAM by downloading the Git repository distribution of OpenFOAM. Known as 2.1.x, this version is managed and updated daily by the OpenFOAM Foundation and can be conveniently “pulled” using the Git distributed revision control system.
It seems as if the source pack is updated less frequently than the repsitory.
Source Pack
Version 2.1.0, released 19/12/11
versus
Git Repository
Version 2.1.x, updated regularly
Old   April 30, 2012, 11:57
Retired Super Moderator
Bruno Santos
Greetings to both!
I didn't mention anything here before because Gerhard hasn't be wrong, at least as far as I can tell.
So as an experienced user I can say that: yes, Gerhard is correct and 2.1.x is the version of OpenFOAM that has frequent updates, but there are two important details to keep in mind:
  • As already stated, doing "git pull" is not enough to get the updates. It should be at least:
    git pull
    ./Allwmake
  • The git version is usually advised only to more experienced users, namely those who have already built the "source" package a couple of times and feel more comfortable with building OpenFOAM.
    The reason is simple: the latest git version doesn't always build and work as intended. Updates are sometimes done in a fashion that can lead to you having a working solver in one day and not working after the update. Technically, it will be because the solver wasn't properly working before... but also because sometimes there are quick updates that aren't fully tested.
One last tip - run the following command before Allwmake:
export WM_NCOMPPROCS=4
Where 4 is the number of cores (parallel processes) to be used during the build process, so it will build faster.
Best regards,
Bruno
Old   April 30, 2012, 14:55
jsm
JSM
Hi Bruno,
Thanks for your information. Now I understood the difference between source pack and repository pack. I will install openfoam 2.1 from source pack and compile it. I think it will be good starting point.
From your reply, I concluded that Openfoam 2.1 can be installed in Ubuntu 12.04 64 bit without any issues.
I will try and let you know the details.
With regards,
JSM
Old   April 30, 2012, 14:58
jsm
JSM
Hi Gerhard Holzinger,
Thanks for your comments and quick response
With regards,
JSM
Old   May 2, 2012, 04:38
Gerhard Holzinger
Best regards,
Bruno
This really boosted compilation.
Old   May 2, 2012, 17:55
Bruno Santos
Hi Gerhard,
In case you're wondering the impact of number of cores vs time it takes to build, here's an old blog post of mine: Build times for OpenFOAM 2.0.x code with Ubuntu 10.10 with its gcc 4.4.5
Best regards,
Bruno
Old   May 6, 2012, 16:19
Default Alternative: install oneiric instead of precise
Wesley T.
Wesley is on a distinguished road
Not everybody is comfortable building from the source code. It is not bad for OpenFoam, but it can be a bit daunting if it is the first time you are trying to compile.
It appears the version compiled for the previous version of Ubuntu (11.10, oneiric ocelot) will work on version 12.04 (precise pangolin)
If you followed the instruction on the instruction on the openfoam ubuntu page:
http://www.openfoam.org/download/ubuntu.php
The repository for openfoam was put into your list for your package manager.
If you are using synaptic (I assume the other package managers behave in a similar manner):
  • launch synaptic
  • click on "Settings" in the menu bar
  • click on "Repositories" in that menu
  • in the "Software Sources" window that pops up, click on the tab for "Other Software"
  • select/highlight the line that says "Independent"
  • click "Edit..."
  • Change the line for "Distribution" from "precise" to "oneiric"
That worked for me without the need to compile myself. I have tried the icoFoam tutorial, but other simulations yet.
I hope some people find this to be helpful.
Wes
Wesley is offline   Reply With Quote
Old   May 6, 2012, 18:21
Bruno Santos
Hi Wesley,
Good instructions! But I'm not 100% certain if Synaptic is installed by default in 12.04. Therefore, the quickest thing to do would be this:
sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu oneiric main > /etc/apt/sources.list.d/openfoam.list"
This command line is for replacing the first two command lines from here: http://www.openfoam.org/download/ubuntu.php
Best regards,
Bruno
Old   May 7, 2012, 05:56
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hi Wesley,
Best regards,
Bruno
You are right, it is not part of the official installation (the Ubuntu Software Center is the standard package manager GUI).
~roman
romant is offline   Reply With Quote
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 05:29
openfoam installation javad814 OpenFOAM 7 January 27, 2012 12:31
openfoam installation for algeria (dz) abbes OpenFOAM Installation 4 July 18, 2011 20:16
Installing OpenFOAM 1.6 on Ubuntu 10.4 sda OpenFOAM Installation 5 May 27, 2010 21:19
