[openSmoke] libOpenSMOKE
Like Tree133Likes
Old   July 23, 2015, 11:49
Freedom
wenxu is on a distinguished road
Hello, everyone,
Could anyone tell me how can the variance of mixture fraction be normalized by this:
            Zvar_normalized = Zvar[celli] / (Z[celli]*(1.-Z[celli]));
I want to know how to deduce this normalization equation. Could anyone give me some hints?
Thank you in advance!
Best regards,
Wen
wenxu is offline   Reply With Quote
Old   July 23, 2015, 13:35
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Its Not the mixture fraction, it's its Varianz ... Zvar is defined between 0 and 0.25 (parabolic profile). No area weight ed interpolation possible.
See also http://www.holzmann-cfd.de/index.php...ameletModel2.2
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   July 23, 2015, 22:14
Freedom
Thank you for your reply. And sorry for my mistake. I have corrected it.
Regards,
Wen
Old   September 19, 2015, 09:24
Freedom
Dear Tobi,
May I kindly ask two questions about the libOpenSMOKE:
(1) About the enthalpy defect: I do not know how you generate the flamelet library with different enthalpy defects, that means do you modify the boundary condition of the temperature flamelet equation or add a source term to the that equation?
(2) About the actual enthalpy (H): How to calculate the actual enthalpy at the inlet as that in the H initial file?
dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform -17992.9;
boundaryField
coal_air
type fixedValue;
value uniform -2.19608e+06;
ch4
type fixedValue;
value uniform -17992.9;
co_flow
type fixedValue;
As I already know, we can calculate the actual enthalpy as: H = phi + Hfuel (fuel side); H = phi + Hoxidizer (Oxidizer side). Here, the Hfuel and the Hoxidizer can be looked up from the flamelet library. But how to evaluate the phi value at these two different inlets? (I have this confusion because I think the enthalpy is the variable should be calculated but not a already calculated variable in the solver.)
Best,
Wen
Old   September 28, 2015, 06:10
Tobi's Avatar
Tobias Holzmann
Dear Wen,
(1) the enthalpy defect is a source term added in the flamelet equations (not in the openFOAM solver). The flamelet equations are not solved in openFOAM. These eqn are solved within the binary files and you can add a defect, that means a delta enthalpy to the adiabatic condition.
(2) The actual enthalpy at some cell is calculated using a passive scalar transport equation (not what you mentioned). The equation is (in SIMPLE):
fvScalarMatrix hEqn
    fvm::div(phi, H)
  - fvm::laplacian(turbulence->muEff()/sigmat, H)
If you solve non-adiabatic systems a radiation term is included. Check the H.Eqn file. The equation with phi is the calculation of the enthalpy defect that is caluclated using the mixture fraction (it is Z and not phi) and the adiabatic enthalpy of fuel and oxidzer. Check the thermodynamic lib.
The adiabatic values of the inlet are the adiabatic enthalpies of fuel and oxidizer and is shown at the beginning of the libOpenSMOKE solver. Run it once, abort, get the values of the adiabatic enthalpy, insert them into the H file and restart.
Keep foaming,
Tobias Holzmann
Old   September 28, 2015, 06:25
Freedom
I do not know whether the enthalpy defect is set as a source term or as the boundary condition in the fuel and oxidizer sides (the common choice), because it is a binary file. But I know that the total enthalpy on the fuel and oxidizer side is a calculated value if we use FlameMaster solver. Of course, the method you implemented is right.
Thank you for you hints, I already know that.
Best regards,
Wen
Old   September 28, 2015, 07:07
Tobi's Avatar
Tobias Holzmann
Dear Wenxu,
you ment the enthalpy defect within the flamelet equations (so flame-master, binaries of libOpenSMOKE, cantera)?
I think it is a source term and not a boundary condition because if you compare flamelets of the same scalar dissipation rates and different enthalpy defects you can see that the temperature profile is moved (somehow with a defined value --> delta distribiution).
Therefore I think its not a boundary condition
Keep foaming,
Tobias Holzmann
Old   March 4, 2016, 05:30
Tobi's Avatar
Tobias Holzmann
Hey all,
I am really working hard on my flamelet generator and I programmed more than 10.000 lines till now. For me the binarys of libOpenSMOKE are in gerneral somehow a comparison of my calculations. However I found some problems in the binary code.
  • The calculated strain rate (at the beginning) is in my opinion wrong. The calculation is done using this equation:
\chi_{st} = \frac{as \cdot \mathrm{exp}(-2 \cdot (\mathrm{erfc}^{-1}(2\cdot Z_{st}))^2)}{\pi}
During the flamelet calculation we use the stochiometric scalar dissipation rate and we also know the stochiometric mixture fraction. Therefore we can calculate the strain rate as that we will use for modeling the scalar dissipation rate across the flamelet.
After a few hours of debuging, because my code is not giving the same strain rate, I figured out that in libOpenSMOKE the strain rate is calculated using the c++ function erfc. This function is the complimentary error function but in the function above, we have the inverse complimentary error function. Using this, we get different values of as. I am not sure how much this will influence the calculation but it is in my opinion a wrong calculation.
FInally, I am not sure about the stochiometric mixture fraction calculation. For pure fuel's I am getting the same results but if I add some inert gas to the fuel, my calculation differs from that of lib-open-smoke.
It would be very nice if someone could check this with fluent or some other software.
Example:
Fuel:   Y_H2 = 0.3  Y_N2  = 0.7
Oxi:   Y_O2 = 1
  • The calculation of the stochiometric mixture fraction is given by:
Z_{st} = \left[1 + \frac{\nu Y_{F,1}}{Y_{O_2, 2}}\right]^{-1}
Y_{O_2,2} is the mass fraction of O2 in the oxidizer stream
Y_{F,1} is the mass fraction of fuel in the fuel stream
\nu is the stochiometric fraction and is related to the needed oxigen o_{min}to burn the fuel completely (stochiometric mixture).
The needed oxigen can be calculated using the mass fraction of the elements.
In this way I am calculating the stochiometric mixture fraction. Can someone proof the way I am calculating that? Thanks in advance.
Tobi
Keep foaming,
Tobias Holzmann
Old   December 26, 2016, 08:14
Mukesh Adlak
Adlak is on a distinguished road
Hello everyone,
i have compiled flamelet model in openfoam-4.x but while running the tutorial case i am getting the following error :
--> FOAM FATAL ERROR:
Not implemented
    From function flameletThermo::Z()
    in file flameletThermo/flameletThermo.C at line 160.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::flameletThermo::Z() at ??:?
#3  ? at ??:?
#4  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5  ? at ??:?
Aborted (core dumped)
Last edited by wyldckat; December 26, 2016 at 17:21. Reason: Added [CODE][/CODE] markers
Adlak is offline   Reply With Quote
Old   January 13, 2017, 06:28
Mukesh Adlak
Hi Tobi, Hope your holidays were awesome,
I have compiled flamelet model in openfoam-4.x but while running the tutorial case i am getting the following error :
Not implemented
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#3 ? at ??:?
#5 ? at ??:?
Old   January 13, 2017, 08:45
Tobi's Avatar
Tobias Holzmann
You do not have to post it everywhere - I already got the notification
Keep foaming,
Tobias Holzmann
Old   February 6, 2017, 02:37
Mukesh Adlak
Hi Tobi,
I am using ur flameletPimplefoam in openfoam-2.3.x for supersonic combustion but after some iterations it is diverging. Z and Zvar values go in thousands. Can u help me out ?
Old   February 6, 2017, 02:40
Tobi's Avatar
Tobias Holzmann
Maybe it is based on the fact that the solver has no supersonic implementation or it is based on your mesh, boundary conditions or whatever. In addition I do not support old versions anymore.
If it is not possible, try the flameletFoam from Hagen Müller.
Keep foaming,
Tobias Holzmann
Old   March 31, 2017, 04:48
Default Density calculation
  #514
MorenoGeerts is on a distinguished road
Hi Tobi,
First of all: thank you for all the work you have done on the flamelet solver!
I have a question about the rho calculation in the thermophysical model.
Am I correct in assuming that rho is looked up in the flamelet table?
I am a bit confused due to the "flameletThermo.C" file in which rho is returned as p*psi() and psi is calculated as 1/RT in the perfect gas equation of state. But in pdfFlameletThermo.C "density_reynolds" is looked up and used in calculations for psi. However, I do not seem to be able to determine the place where the rho-field is connected to the looked up value.
A related question: in the validation syngas flame you use the following values for the pure mixture:
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1005;
Hf 0;
transport
As 1.67212e-06;
Ts 170.672;
How did you determine the molWeight and Cp value? Or are they not used in the simulation at all?
MorenoGeerts is offline   Reply With Quote
Old   March 31, 2017, 06:31
Tobi's Avatar
Tobias Holzmann
  • The density is looked up from the table and then used in the calculation. As you can see in the thermodynamic model.
psiCells[celli] = RhoReynolds[celli]/pCells[celli];
  • The pressure is constant and therefore using the return function which is psi*p gives the density again
  • So everything is fine
  • The stuff in the thermodynamic files does not matter because we do not use any value here. Its just a dummy, we do not use it.
MorenoGeerts likes this.
Keep foaming,
Tobias Holzmann
Old   March 31, 2017, 06:49
Thank you for the clarification!
So that means that also none of the following parameters of thermotype matter, except "type pdfFlameletThermo;"
thermoType
mixture pureMixture;
transport sutherland;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Old   March 31, 2017, 07:21
Tobi's Avatar
Tobias Holzmann
Correct.
It is just needed for the object we construct but in the new thermodynamic we made in that model, everything is based on the Look-Up-Table:
  • cp
  • mu
  • rho
  • lambda
  • species mass fractoin
I hope I didn't forget anything. Since 3 years I am programming on a flamelet creator. The last few month I did not do anything but maybe in a few centuries I will finish it
Keep foaming,
Tobias Holzmann
Old   May 23, 2017, 13:02
Default Wall boundary condition
  #518
Hi Tobi,
I have a question about the implemented boundary conditions in the pdfFlameletThermo.C file.
I don't get why the boundary condition for fixed temperature should coïncide with a fixed enthalpy BC with value 0 as the following error message suggests:
FatalErrorIn
"pdfFlameletThermo<BasicFlameletThermo, MixtureType>::update()"
<< "Boundary conditions are wrong: "
<< "fixed temperature BC must be fixed enthaplie BC with value 0;"
<< abort(FatalError);
I think that a wall would have a zero gradient BC for H and a fixedValue one for T, because the enthalpy H is not necessarily 0 at a wall. It is an easy alteration (for me/you/...) to change/add this condition, but maybe I'm overseeing something.
What do you think about this requirement?
Thank you!
Old   May 23, 2017, 17:51
Tobi's Avatar
Tobias Holzmann
it was my implementation. The reason for that is very easy. It is based on the fact that libOpenSMOKE has some special treatment for fixedValue BC for the temperature. Based on the temperature the application calculates an enthalpydefect and thus choose the appropriate LUT. It was not working in the official one so I debugged a few things here. The enthalpy fixed value = 0 does not influence the solution. it is just a dummy for further treatment in the code.
I have everything in my thesis. Unfortunately it is in german. Even the usage of the log-normal in the properties will change a lot of things . To make it short:
Fixed T: With T, Z, Z'', chi at face find enthalpy defect at face.
Based on the enthalpy defect, calculate the enthalpy at the face.
Keep foaming,
Tobias Holzmann
Old   May 23, 2017, 17:53
Tobi's Avatar
Tobias Holzmann
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Numerical treatment of the source term in combustion equations Tobi Main CFD Forum 37 September 15, 2020 14:42
[openSmoke] flameletSmoke + new ODESolver (by Alberto Cuoci) Tobi OpenFOAM Community Contributions 1 November 21, 2017 19:24
Unsteady solver with Flamelet Model (libOpenSMOKE) francesco_capuano OpenFOAM Running, Solving & CFD 11 November 26, 2013 05:50
LibOpenSmoke, getting the species in ParaFoam Christoph_84 OpenFOAM 1 May 31, 2012 15:42
